Rickster55
Happy New Year! Post those deals!
Fwiw, my buddy got that KOBALT air compressor for $127 2 years ago. He reminds me of this frequently. Go figure.Happy New Years everyone, definitely recommend hitting your store and see what stuff is starting to fall on clearence, really there is a considerable amount but nothing to jump over YET...
Not pictures but here’s a few things on a light clearence cycle.
- VARIOUS BOSCH BIT SETS THAT CLIP INTO THE CASES
- BOSCH NAILSTRIKE AUGERS AND PADDLES
- CRAFSTMAN BIT CASES
- SEVERAL IRWIN DRILL BIT SKUS INCLUDING FORSTNER BITS
HERES A FEW THINGS I SNAPPED PICTURES OF, the METABO HPT CORDLESS SAW IS DEFINITELY SOMETHING TO PAY CLOSE ATTENTION TO
Also some welding helmets starting to cycle as well
KOBALT 60 gal 2 stage is on clearance for $354. XC602000 sku: 905520
Note the specs on that one are 7.6 cfm @ 90 psi and may not be enough to run a sandblaster, sprayer, or larger draw air tools. 12 to 16 cfm @ 90 psi is more typical for a 60 g compressor.
The 80 g is 11.9 cfm @90 psi, a little better but still rather low for that size of compressor tank.
That compressor posted above is 11cfm @ 90psi. Go to it on Lowes site and zoom in on the 360 picture, then look at the tag.
https://www.lowes.com/pd/Kobalt-60-Gallon-Two-Stage-Electric-Vertical-Air-Compressor/1000542193
My store had about a dozen of these Thermacells for $5 each
I'm thinking of buying this from Lowe's. Any recommendations? https://www.lowes.com/pd/Thermacell-Hi-Vis-Mosquito-Repellent/1000760296
Sent from my SM-G950U using The Garage Journal mobile app
The link says "Air Delivery SCFM @ 90PSI (CFM) 7.6" under specifications.
I do see a label on the 360 picture, but the resolution is insufficient for me to read the pressure, and it looks like an overlay. It almost looks like a CAD drawing, I'm not sure that is an actual photo of the compressor. They also may have used a different picture or a different model for the picture, the photos are not necessarily representative of the actual product, per their terms. The specifications are what they consider to be correct, but it's certainly possible the specs listed on the product page are incorrect.
If anyone gets this one, it would be interesting to measure the air flow and confirm if the published specification is correct and if it matches the label and specifications provided with the product.
Use Brickseek to find a store with remaining stock. Mine had 2. Now they have one
I guess I dont understand how brickseek works. I searched both part numbers you posted, then searched kobalt compressors and I found nothing related to what you just posted... im guessing it is me, but what am I doing wrong?
Sent from my SM-N960U using Tapatalk
Where were the two way radios located? My store has 7 but no one can find them.
Sent from my SM-N960U using The Garage Journal mobile app
those utility knives come up as pvc pipe for me when I enter it in brickseek. That also happened with one of the air compressors. I assume that means they phased it out an reused the product number?
those calipers are also still full price by me.. wish i could find them, i could definitely use a couple more!
Do you have the five gallon? The reviews are pretty bad for a gas can. Just curious if it is that hard to use.The SureCan 5-gallon and 2.2 gallon gas cans dropped again at my store - just $5 and $4, respectively. Great deal for a great made-in-USA gas can!
https://www.lowes.com/pd/Scepter-USA-5-Gallon-Plastic-Gasoline-Can/1000772364
https://www.lowes.com/pd/SureCan-2-2-Gallon-Plastic-Gasoline-Can/1000033475
Incidentally, I noticed that my store has the Chinese gas cans they replaced the SureCans with stacked to the rafters. I checked stock at various stores and some of them have *thousands* of them in stock. WTF? Did I miss the memo about needing to store gasoline?
Sent from my KFDOWI using Tapatalk
