2021 Lowe's deals/sales/clearance thread
Ager Venator
Roanoke VA
As of now, store #419 in Roanoke, VA has four of the yellow air hoses in stock but without a price tag. I took one to the front to confirm the price.
I also found one of the contractor cords, again without a price tag. That went home with me.
jimbos1ice
IL
Happy New Years everyone, definitely recommend hitting your store and see what stuff is starting to fall on clearence, really there is a considerable amount but nothing to jump over YET...
Not pictures but here’s a few things on a light clearence cycle.
- VARIOUS BOSCH BIT SETS THAT CLIP INTO THE CASES
- BOSCH NAILSTRIKE AUGERS AND PADDLES
- CRAFSTMAN BIT CASES
- SEVERAL IRWIN DRILL BIT SKUS INCLUDING FORSTNER BITS
HERES A FEW THINGS I SNAPPED PICTURES OF, the METABO HPT CORDLESS SAW IS DEFINITELY SOMETHING TO PAY CLOSE ATTENTION TO
Also some welding helmets starting to cycle as well
homeschool
Forgot to post these a couple days ago. Jackson MI store.5514058feb36f2cee5324abac7521023.jpg394b69aadae8e2f19829b53f68717c5b.jpg03aab49a7387e0ef90af5b93ef6a018e.jpg
dude.lebowski
WA
Fwiw, my buddy got that KOBALT air compressor for $127 2 years ago. He reminds me of this frequently. Go figure.
jimbos1ice
IL
Yea they still had a handful in stock hoping they fall under $200, they had a larger compressor dropping in price too
jhelrey
MN
No Kobalt compressors around me... I also got one for $150ish about 5 years ago but mine only does 155PSI.
krod
KOBALT 60 gal 2 stage is on clearance for $354. XC602000 sku: 905520
Use Brickseek to find a store with remaining stock. Mine had 2. Now they have one ;)
speedpro
I snagged one of those 30 gallon compressors for $200 about six weeks ago. They are slowly dropping randomly at the stores, so keep an eye out. Same thing with the 60 and 80 gallon compressors.
may0naise
Arizona
Keep an eye out on the clearance racks down the middle isle. All of the AWP brand tool bags and pouches are clearance for about 50-75% off, I picked up the electricians bag for $5 (https://www.lowes.com/pd/AWP-Polyester-Electrician-Tool-Pouch/1001156090). Also check for Simpson ties, I got a box of these for 3 cents each, there were a few other types similarly priced, but as I just use them for random stuff around the house the flat ones seemed most versatile as I can bend them to other shapes I may need.
Dh3256
Note the specs on that one are 7.6 cfm @ 90 psi and may not be enough to run a sandblaster, sprayer, or larger draw air tools. 12 to 16 cfm @ 90 psi is more typical for a 60 g compressor.
The 80 g is 11.9 cfm @90 psi, a little better but still rather low for that size of compressor tank.
mfewtrail
That compressor posted above is 11cfm @ 90psi. Go to it on Lowes site and zoom in on the 360 picture, then look at the tag. ;)
https://www.lowes.com/pd/Kobalt-60-Gallon-Two-Stage-Electric-Vertical-Air-Compressor/1000542193
67 camaro
Thanks guys I was able to pick up the 80 gallon compressor. Upgrade from my single stage 60 gallon that I’ve had since 04
finn
The UP, God's country
I picked up one of the $316 (less 5%) two stage compressors the afternoon. The web site said none in stock, but the in store inventory found two.
I am severely space constrained at the Arizona house, so the larger 60 gallon was not practical (I need some portability).
I had almost accepted that one of the oilless “silent” compressors would find a home in my tiny garage, but I suspect much of the “silent” part is in the intake system mufflers, which appear to be a simple helmholtz resonator, which I should be able to cobble together.. the silent compressors are generally 70 dBa or below, compared to 78 dBa for this two stage belt driven oil filled compressor.
Dh3256
The link says "Air Delivery SCFM @ 90PSI (CFM) 7.6" under specifications.
I do see a label on the 360 picture, but the resolution is insufficient for me to read the pressure, and it looks like an overlay. It almost looks like a CAD drawing, I'm not sure that is an actual photo of the compressor. They also may have used a different picture or a different model for the picture, the photos are not necessarily representative of the actual product, per their terms. The specifications are what they consider to be correct, but it's certainly possible the specs listed on the product page are incorrect.
If anyone gets this one, it would be interesting to measure the air flow and confirm if the published specification is correct and if it matches the label and specifications provided with the product.
Rich M.
Timonium, Maryland
I bought the Kobalt 30 gallon air compressor about 2 years ago for $400, which seemed to be a good deal, especially since at the time they were selling for over $500.
I guess if we all had a crystal ball and time to wait, our saving ability may increase. On the other side of the coin, the deals may never materialize.
mfewtrail
This is the label I mentioned. I should have probably specified the label is visible in the 2nd 360* view picture in the lineup there.
tomwil
Wash DC area.
Fortress68
Norfolk, VA
I found them listed on brickseek near me, but the Lowe's website says sold out... anyone have luck calling and confirming?
Moosefire
Detroit
I guess I dont understand how brickseek works. I searched both part numbers you posted, then searched kobalt compressors and I found nothing related to what you just posted... im guessing it is me, but what am I doing wrong?
Sent from my SM-N960U using Tapatalk
Fortress68
Norfolk, VA
I see a guy selling multiple new units for $500 now locally on craigslist... guess he scalped them before I could get one.
casmurbax
Wilton, NY
I am not sure about sharing the link from brickseek on here, but here is a picture of how it should look for you when you search.
gamp945
The SureCan 5-gallon and 2.2 gallon gas cans dropped again at my store - just $5 and $4, respectively. Great deal for a great made-in-USA gas can!
https://www.lowes.com/pd/Scepter-USA-5-Gallon-Plastic-Gasoline-Can/1000772364
https://www.lowes.com/pd/SureCan-2-2-Gallon-Plastic-Gasoline-Can/1000033475
Incidentally, I noticed that my store has the Chinese gas cans they replaced the SureCans with stacked to the rafters. I checked stock at various stores and some of them have *thousands* of them in stock. WTF? Did I miss the memo about needing to store gasoline?
Zestomite
Southern California
A couple kobalt flashlights
Fatboy148
They had one at my local store when they dropped to just below $600. I went and looked and couldn't bring myself to buy it. Looking at the castings, it just screams "Made In China". At $300., I would suffer through looking at it but a check on Brickseek says they raised the price back to $799. :(
Crabman
Alexandria, VA/Dameron, MD
One local store had 2 on Brickseek, they went $399-$299-then to $199 yesterday. I could not get over there but was going to go today. Back up to $799.
I could have looked at it for $199 for sure.
So thanks to the folks who posted the compressors.
TracerRound
North Carolina
muibubbles
nj
those utility knives come up as pvc pipe for me when I enter it in brickseek. That also happened with one of the air compressors. I assume that means they phased it out an reused the product number?
those calipers are also still full price by me.. wish i could find them, i could definitely use a couple more!
loranger
DFW, TX
Where were the two way radios located? My store has 7 but no one can find them.
Sent from my SM-N960U using The Garage Journal mobile app
The radios were on one of those random hangers in the now compressor aisle. Lowes around me are moving everything around and now have the compressors in one of the aisles not with the tools.
Brickseek link for the knives. You have to use the internet number not the item or model number. The internet number is the very last set of numbers on the address link.
https://brickseek.com/lowes-inventory-checker/?sku=1003172370
Caliper brickseek link:
https://brickseek.com/lowes-inventory-checker/?sku=50175967
XJPat
Central Jersey, Merica
Do you have the five gallon? The reviews are pretty bad for a gas can. Just curious if it is that hard to use.
Sent from my KFDOWI using Tapatalk
gamp945
Oops - just noticed that my link for the 5 gallon went to the new Scepter brand instead of the clearance SureCan. Here is the correct link for the 5 gallon SureCan:
https://www.lowes.com/pd/SureCan-5-Gallon-Plastic-Gasoline-Can/1000033473
The reviews are pretty great. The only bad reviews I see are people complaining about the spout breaking. I don't know if these people have misused them, but they come with a 3-year warranty. Also, unlike Chinese products, you can actually purchase replacement parts directly from the manufacturer. A replacement spout costs $8.
