strength_and_power
- Joined
- Apr 26, 2015
- Messages
- 1,416
What is the ramp for? Pretty narrow considering it has to hold 6000 pounds.Starting tomorrow on a 20’ long 30” wide ramp for an upcoming job. It will need to support around 6,000#s. Got a fresh bottle of 90/10, a 44# spool of .045. Going to be getting after it with the Miller 350p set for pulsed spray transfer. Should be a good time.
Nice! I suspected a pallet jack was involved.We have 3 safes, each weighing 4,200#s plus an electric pallet jack that will be going up this ramp. Our pallet jacks are special order and are 21” wide with 30-36” long forks. A conventional pallet jack is 28” wide with 48” forks. The 2” x 1/4” wall square tubes are spaced for my load and drive wheels.
How high is this ramp going? Think the electric pallet jack will have enough traction? It seems like a pretty eloquent solution to the problem of elevating 4K
Were these safes are being placed, have the floors been engineered for them.
I would have so much custom made special material handling equipment if I moved safes for a living. We always built funky equipment for mountain top tower sites. Great setup for the safe in that first picture, pretty ingenious and a simple yet elegant solution to a serious obstacle. My long term goal is to be able to move about anything anywhere up to 10k pounds, then later move up to heavier things, right now I feel comfortable moving things about 5k pounds without much worry.
You need to learn to weld aluminum.
I thought the ramp was to move a safe??? Funny looking "safe" at thr bottom lol
Agreed.
I was going to say "I didn't know Victor made safes too." ..but it turns out there was a Victor safe company, so.. I guess some were disguised as tool room lathes.![]()
Push pull is the way to go, I started with a spool gun, bought a push pull, but haven’t set it up yet. I talked at length with a guy that builds aluminum boats for a living and that was all he used in his business.
8.8 install with truss kit on the wrangler
Nice job on the 8.8 mods and installation. Very nice sound looking welds.![]()
G--tough job. Looks like you reduced your ground clearance a bit.
Watched some youtube videos and taught myself how to weld stainless. Built down pipes, y-pipe and mid pipe on my twin turbo iroc. Down pipes are all 3", with 4" from the merge collector back. Multiple v-bands and brackets as well. I noticed a marked improvement from beginning to end, but I'm not going to redo the early welds.
Nicely done, especially being self taught learning on YouTube.
I've worked with some who've claimed to have been welding for years who cant weld as well as you've thrown down.
Nice car too, do you have a build thread anywhere?
Did you weld the cut fork as well?
I suppose without knowing the exact base material, you used "normal" wire (SG2/3) and a bit of preheat?
If you had a dedicated welding procedure, do you mind sharing it with us?
Thx for the feedback! I'm not sure that the forks are a ductile steel, but I haven't had them in my hands of course. Most I've seen are a high strength, high carbon steel, that require special precautions when welding, that's why I asked.
