Curious how the jack shaft would affect operation in day-to-day.
Sent from my IN2015 using The Garage Journal mobile app
Should work fine. I built one for the post. On the 150 I restored.
The way the previous owner had that middle pulley set up, I can't picture anything but the chuck spinning faster. The smallest pulley step on all three pulleys is facing up.
The jackshaft pulley small step needs to be facing down. The motor pulley and spindle pulley should face up.
Ok, just added one to the list!Picked up a new project today. Already has a jack shaft pulley in the post. Been looking for a mohawk for quite a while.
Welcome Steve!I have a Craftsman 101 Series Floor Model Drill Press that I acquired since it was missing some parts. I was able to source everything I need with the exception of the elusive spindle, aka, quill cover. I know that there is a plastic version that someone created on eBay but I would like to find an original. Any assistance would be great. New to the group. Thanks for letting me join.
I went to pick up some paint for a couple projects and saw this Rustoleum Black Stainless Steel. It looks very close to some oe motor paint colors and not too far off of the darker drill press paint. Cap color, though, is never an exact indicator of actual contents.
I usually chuck a precision rod (a drill bit will work) and measure on that. Or I measure on the taper after the chuck is removed. I don't think the safety collar is the best place to check runout.Thanks for posting. I'm starting to lean heavily toward the Flat Soft Iron, as I just like the way it looks and is close enough to original "in spirit" for my taste.
I tried to test for runout on my particular machine. I'm not sure if I'm doing this exactly right, and I'm using a cheapie $15 dial indicator, but it appears to only show 0.007" runout. I'm assuming this is pretty good. Hopefully I don't mess it up after taking it all apart and putting it back together again.
Cleaned up the Mohawk today. Just have to shear a piece of polished stainless for the front at work on Monday.
Bought it to completely restore and flip. But this one just got a user cleanup. And will get mounted to the bench. I would regret selling this one. It runs like a champ.
I don't recall ever using the tilt feature of the table, so I can't comment.For those with the early 50s tilt table, does it accurately hold angles, or do you use/prefer an angled drill press vice instead?
Frank, out of curiosity, the drill presses you have are mounted on pedestals. Perhaps youve addressed it, but what is the purpose of having your DPs on those pedestals? Are they mobile?
Picked this up today simply because the seller agreed on $20. I may just clean it up and part it out on eBay, but impossible to resist for that price.
Seems like half the 150s out there have the bolt on receptacle box with switch, I couldn't get that off fast enough.
Helluva deal
Greta find. Not that I would know any better, but that motor looks "beefier"
Appears the date code is 1966.
The feed handles are the 1/2 13 style.
It is indeed an acme thread and great eyes Frank, the feed stop nuts have no rapid adjust.
Band cleaned up nicely though.
I had the table clamped up last night with JB Weld and I'll see what I can do about fading in the repaired crack. There is a reason it was $20.
PO had that custom receptacle and switch hard wired into the motor, was there no on/off switch on these outside mount capacitor motors?
No, those later aluminum motors did not come equipped with switches. Sears sold optional add-on switches and other options.Appears the date code is 1966.
I've had plenty of both styles of Jacobs chucks, but never have been able to determine which was used when. I do think that your smooth-sleeve chuck may be original to that machine. And you're correct... catalog illustrations did not always reflect reality.The owners manual (not that the illustrations in the owner's manual always accurately depict reality) for this model DP shows the ribbed Jacobs 633C, this one is smooth. Because of the early 50s feed stop lock nuts and this smooth Jacob's Chuck it appears this press has had parts pulled from other machines.
Also, at some point were the table lock and headlock handles given a black oxide like finish by Sears?
Yes, I think all those taper lock handles (and some other parts on later 150s) had a black finish. That finish will always come off in vinegar/citric acid... not sure about evaporust.
Hoorn something similar happed to me. I saw a Craftsman drill press on Craigslist with the vari-slow attached **** it was gone.
Yep, most of us have been there. What really hurts is when you are first and it gets sold out from under you.
The steering wheel is indeed an oddity for the drill press However, you may be surprised what THOSE bring on ebay as well.You are so right. When I bid over $100 he had not told me yet that he already had a buyer lined up. I just assumed a bunch of offers were pouring in at that time and I wanted to make my offer appealing. When he told me I was second in line, that waiting period was very difficult.
That steering wheel was a pretty eccentric addition to the feed hub. Frank, have you seen worse?
Hi. I've found a CL post in my local area for a Craftsman 150 drill press. I'm looking for a drill press I can drill mild steel and aluminum with, and probably never holes bigger than 1/2". It looks okay, though it hasn't been used in a long time. It's a benchtop model, which I would prefer for my space, and is black or very dark grey, not super rusty, and has a 1/3 HP "Companion" motor on it. The owner says it only has 1 pulley, not two, and that it runs well. Is this something worth buying for his $145 asking price? I offered $100 and he seemed uninterested, but says I'm also the highest offer and he's been getting lowballed around $50 all day.
I looked at this thread a little bit, but I don't know much about these presses and it looks like the late-model 150 with only 1 pulley, he didn't mention anything about variable speeds.
Hello and welcome! Without pictures we cant accurately answer your question but sounds like you made the right offer ? Next to craftsman table saws, drill presses seem to have the most uninformed sellers or dreamers when it comes to pricing...a mint one with Varislow may be priced at $50 while the next one on ebay with a broken varislow and rusting in a scrap pile may be priced at $500 for over a year (true story)... Post some pictures of the ad when you can but crop the pictures out so all you post is just the picture, no classified location information.
Welcome!Sure thing.
Here's some of the ad images. He didn't post any showing a spindle speed chart or the pulleys, or any close-ups of the chuck.
