Show us your welding projects
harley jim
Cleveland Tn..........out in the sticks
Last fall my broom handle broke. Wait, that's not accurate - the Chinese pot-metal threaded doohicky broke, rendering my broom much less useful than before. So, I made a replacement using bits from around the workshop, because why buy it when you can make it? 11ga plate and 3/4 SCH 40 pipe.
I got the main bracket done today and started to bend some repurposed flatbar straps to triangulate the broom head like a heavy-duty industrial broom. Was running 120 amps and pedal to the metal with 1/16" filler rod. Had to go down to a #6 stubby cup with over 1/4" stick-out to get into the deep valley. I can glue metal together all day long, but I am not a fitter/fabricator by any means, I'm surprised how flat it came out.
Fun fact: since my TIG machine is in my basement I don't have a dedicated weld table and I noticed that my "mobile" cheapo vice was missing a jaw screw and since the only screw I had that matched the thread was way too long I decided to make it my ground point - worked great!
I think it got enough penetration for a push broom :D Didn't bother to clean the mill scale off the back side and it bubbled-up. One tiny bit of burn through so I think I had the heat dialed in nicely.
Next was time to drill a cross-hole and I had a 5/16-18 carriage bolt and wing-nut to secure the handle. My "drill-press" is a 1950's Shop Smith 10ER set-up in vertical mode. Really need to find or make a speed reducer. Filing that hole to square was an exercise in patience since the pipe only allowed for about 3/4" stroke on the file.
There you have it! The longest post ever about a tiny little weld project that isn't even done yet :pimpflash
VR6ix, sadley this is where it starts, first it's the broom handle, then a wall hanger to put the broom on, then a new boot scraper and before you know it you have a one or two welding project a day habit. Guys like me fell down the hole really bad and cant go a whole day without welding something.
Great fix on the broom sir.
Sent from my SM-A102U using The Garage Journal mobile app
Jayman17
Seattle, Wa
I’m going to mentally file that broom handle fix so when my Chinese pot metal threaded handle breaks I can fix it.
I think we all know it will break it’s only a matter of when...:lol_hitti
Jay
TTMotorsports
Lucerne Valley, CA
Started on a 3" exhaust tube to rectangle turbo flange adapter today. a nice 12 bends per half to get it from rectangle to round. Luckily it's common in HVAC so I found lots of examples online to draw it and cut it out on my Plasmacam cnc plasma table. Also got the engine cage started on my 1968 Ford Prerunner Project.
txvwnut
Bedford, Texas
You should check out Ron Covell’s YouTube channel, he just did a series called rollation where he showed how to form exactly what you just made.
sqznby
Coastal NC
Is that for a T4 or T6 flange? Very creative way to go about doing it.
Happy to see you're back at it and looking forward to seeing more of your work:beer:
SteveH-CO
Southern Colorado
My Yamaha Grizzly ATV rack was missing the backstop piece - it snapped off during the PO's rollover (or some event).
So, I fabbed a heavier one from solid steel rod, welded it on, added a center support, and spray painted it with a Rustoleum textured spray paint that perfectly matched the OEM finish.
TC Moto
Texas
Here’s a rolling stand I built for my tubing bender
lis2323
Here's a rolling stand I built for my Swag tubing roller
lis2323
Rolling stand for my belt grinder
VR6ix
Onterrible, Canuckistan
Thanks for the kind words gents! :beer:
Here's the silly broom project update. It was based on the same idea as heavy-duty industrial brooms, but fabricobbled in my basement. Trying to bend the outriggers was a pain in the ***, so many compound angles and then trying to mirror-image the other side, I just wanted a broom that works!
Re: ground screw on vice... I don't have a welding bench. I have a couple wood benches, but they don't like welding projects so much. I've got a little scrap of expanded metal that I use as my welding platform for small jobs and hang it off the edge of the bench so things don't start burning. For this job I wanted to use a vice to reposition the main weldment multiple times and as I set-up I found the missing jaw screw and thought - "gee, why not just grab a screw that fits and ground off that?" There was zero good reason to do so. It's a cheap China vice so no worries given.
Up next is a grinder & paint, to make up for the welder I ain't! Will drill another screw lower-down from the first one as well. It makes the broom heavier and if i were to do it again I'd use aluminium instead, and make a clamping collar instead of drilling thru the broom stick for the outriggers up top - that might be the new weak-spot on this set-up.
ez-duzit
Marina del Rey
Ez you aught to be building more of those and selling them. That's a great looking cart
Thanks. I built a heavy duty steel frame with ball bearing wheels and casters, and repurposed an ancient Kennedy rolling tool chest, which I modified to house the electro/hydraulic power pack and store all the dies. The JD Square model 32 bender mounts on the column, swivels 360-degrees and locks, if necessary.
lis2323
I especially like the circular cutout for motor fan cooling. Great attention to detail [emoji481]
ez-duzit
Marina del Rey
l--thank you. The overall length of the assembled electro/hydraulic power pack was just a tiny bit larger than the inside width of the old Kennedy cabinet. So my solution was to allow the motor's end bell to just poke through, leaving room so I could close the door front without striking the hydraulic fluid reservoir, and allowing excellent air flow while operating.
I wired it to a switch mounted outside the cabinet for easy access.
Old Man Roger
Palm Coast Florida
Came out sweet Jim, now we're waiting for the tricked out trailer..lol Since you made the upholstery so nice, I think some nice stained wood with some chrome slats for the trailer bed would fit nicely.:pimpflash
bczygan
DETROIT! Arsenal of Scrappers
BukitCase
Oregon
You're welcome Bill; those caps should also work pretty snug with 0.109 walls, probably NOT with anything thinner than .109 or thicker than .120 - Quality of that brand seems pretty decent tho, if your "battery powered fingers" measure different I would probably stick to the brand while looking for the range of I.D. you have... steve
Honch
Danville, IN
Shop stool I worked on over the last two weekends:
The seat height is adjustable between 20"-30" on a 1" acme screw. There are two acme nuts in the vertical tube to keep the shaft movement to a minimum. All the tubing is 12" pieces that are 2"x2" 11 gauge. The bolts are aircraft engine mount bolts 1"x3' on the jamb nut and 1"x6" on the legs
shortykorte
Tallahassee, Fl
Ditto on stool. At first I thought that was a wire cutter powerful enough to cut steel plate then moving down to other pics realized it was foam.
