Show us your welding projects
Honch
Danville, IN
Thanks for all the feedback everyone, there is something satisfying about making something useful from a bunch of random pieces.
its funny because the two people I texted pictures of this to, both thought the foam was a piece of steel as well.
Bigblue&Goldie
Add me to the list of people who thought you were cutting steel with a hot wire......
Also, I wish I had your 12pt hardware laying around!
Honch
Danville, IN
Honch - feel free to post a separate thread on your hot wire.
I guess here is as appropriate as anywhere since I welded the frame together for it.
I bought a folding card table from "The Walmart" and made the framework out of some spare Unistrut. The wire is Kanthal commonly used in everything from heating elements to vape pipes, because of the latter it can be purchased for around $7.00 for 25 feet. I have been using the same piece of Kanthal for five years its very durable. I used some small eye hooks with nylon grommets to attach the wire and I just attach a battery charger to power it. I zip tied a small 110v fan to the upright to blow the smoke away.
The "C" section of the Unistrut fits perfectly over the the edges of the table. The framework is held together by a slip joint on the bottom. I sectioned a piece of the Unistrut to make an interference fit. I can pull the two halves apart and fold the table to store it.
I made the throat fairly tall so I could section the pieces I cut out. For example a typical gun case may be four inches deep in one half. After I cut a section out Ill take two inches off of it and glue it back in the opening. I use construction paper for patterns, the wire does not get hot enough to cut through it so you can run the wire against it for a nice cut. I normally run it at 2 amps and when the wire gets gummed up Ill take the foam away, hit it with 50 amps and it turns the gummy foam to ash. Open cell foam doesn't react well to any higher amperage, the heat from the wire melts the foam before it touches it and makes for ugly cuts.
This was the first case I used it for.
This is a more recent one.
I have done some camera cases as well as specialty tools, I just didn't bother taking pictures of them.
Mr.N
Mpls, MN
https://i.postimg.cc/j2jXRhY2/IMG-0196.jpg
https://i.postimg.cc/9MCbnhxG/IMG-0197.jpg
https://i.postimg.cc/MGyt5TY6/IMG-0192.jpg
https://i.postimg.cc/nz228P5N/IMG-0206.jpg
https://i.postimg.cc/prXg37W6/IMG-0320.jpg
Honch, it's not often a post gets my attention like yours...
Yeah, now I have to make this 'tool', thank you for posting!
Honch
Danville, IN
H--nice job.
Sweet foam cutter. Great idea on the folding table. Very nice finished projects.
Me too! I was like dafuq until I saw the hot wire.
Honch nice work on all of that stuff! Love the stool and the cases are well done.
Jay
Thanks for all the feedback, over the years I have been able to get so much good information from so many smart and talented people on this forum, its nice to be able to give something back.
brawls43
Minneapolis
Honch, how do you get the 1 piece look for that top piece? Is there a seam somewhere that's just hard to see? Great looking cases!
Honch
Danville, IN
I use a long knife to slit the foam along the cut line and slide the Kanthal through the foam. The Kanthal is twisted on the ends and just slips through the gap in the hook and its quickly tensioned by the wheel on the top.
WoodsTruck
The wire I use has a shorter life span or I run it too hot.
I power mine with a small transformer and have an inline power switch built in. I do like the fan idea.
Monza Harry
Windsor ON
Honch I used to work at a place that had a "Hot Wire Cutter" for High Density Styrofoam and that used 0.023" Dia. Stainless MIG wire, any experience, observations, or pointers you'd care to share on this? Harry
Honch
Danville, IN
When I built the cutter four years ago, I strung the Kanthal on it and it and I am still using the same piece. I don't even know where I put the rest of the roll, so sorry but I don't have experience with anything else.
I was going to use 0.020" stainless safety wire, but my son had bought the Kanthal for some college project and never used it. I believe the commercial cutters use NiChrome wire. The Kanthal is corroded and gums up easier than it did when I first put it on.
I'm sure there is all kinds of math with wire resistance, length, optimal temperatures and power sources that could be done, I just used stuff I had.
BukitCase
Oregon
Harry, I think you meant .023 mig wire - besides Kanthal, you could likely use stainless mig wire - it typically has over 10% nickle and a couple other elements besides iron. Nichrome heating wire issimilar, as is the positive electrode in type K thermocouple wire - that wire can withstand 1100 degrees C, so should hold up fine. If you find some type K wire, the yellow insulated wire (positive) is Chromel, about 10% chrome. That's the one you would strip and use for a hot wire cutter... Steve
bczygan
DETROIT! Arsenal of Scrappers
Bent up a couple of trays from 16 Ga cold rolled. 5x19x2 finished size.
Little handles go on ends.
Cold rolled is getting expensive. $25 for a 24"x60" piece.
4 big SS handles are for SS BBQ grill I am fabricating.
One big SS handle is for 21x8x8 1/2 SS toolbox I will be fabricating.
Bill
Gerald O
NC
MGB turbo manifold. Made from 1-1/4" 304 stainless steel schedule 40 pipe and 3/8" plate. First I modeled it with movable plastic sections made on the 3D printer. Plate parts were sent out to be laser cut.
Gerald O
NC
Thick schedule 40 pipe took 2 passes to fully weld.
The turbo flange was last to get welded. Had to use solar flux on it because I couldn't back purge.
Gerald O
NC
Mostly done now. Still need to run the flanges over the belt sander to re-surface.
LXCam
Very nice G that’s looking great. If you don’t mind sharing where’d you source the schedule 40 from. I’ve got a custom job coming up and something that thick would definitely help my poor tig skills out tremendously.
Gerald O
NC
https://www.aceraceparts.com/
I wouldn't say that the sch 40 makes it easier. It's too thick to weld in a single pass so you have to use a lot of argon to do every weld twice, including back purging. And it holds a lot of heat and takes forever to cool.
They also have sch 10 which is still pretty thick but you could weld it in a single pass.
I went with the sch 40 to better handle the heat cycling from the turbo, since 304L isn't the best for high heat. If I could have got all the parts in 321 stainless then I'd have gone with the sch 10.
txvwnut
Bedford, Texas
The next question is where'd you get that cylinder head? They didn't have cross flow heads 40 years ago when I was working on them.
DeeDubz
Socal
I made a shelf for my Traeger.
Gerald O
NC
Thanks all! I'm just an occasional weldor and this was my first stainless steel project, so I know y'all are being kind.
Gerald 0 - very nice job on the manifold!
Do you have a build thread on the MGB?
There's a build thread on the engine on another site:
MGB crossflow EFI project
There have been aftermarket crossflow heads for a long time but they are rare. Originally they were made by HRG Derrington in England but those were out of production decades ago. Now there is one made by Pierce Manifolds: https://www.piercemanifolds.com which is a near clone of the original Derrington heads.
Nicely done on the manifold.
Just curious. Why Sch40 and not sch10?
The temperatures can get very high in a turbo application which the 304 stainless is not ideal for. So I chose the sch40 as a bit of overkill to ward against cracking. It's pretty heavy though. Came out at 10lbs -- almost as heavy as the original cast iron manifold.
321 stainless is better at withstanding the heat cycling and I could have used sch10 with that, but I had a hard time finding all the right sized parts in that material.
Furby1184
East Bridgewater MA
Here's a few of my fab projects. A sign I built, the bumper I made "fab on the fly" no drawings. I'm currently rebuilding my Silverado. So far I have new stainless floors, new rockers with stainless inner rockers, new cab corners. Starting tomorrow I'm replacing the leaf springs, custom hangers, new shackles, extending the frame, plating and reinforcing the frame and building a custom flatbed
Furby1184
East Bridgewater MA
Here is my progress on my truck rebuild
