LeonardY
Southern California
Finished up repairing the back window on the convertible.
The old repair from years ago came loose once I re-glued the side and bottom in the heat. It was well over 105.
Cleaned and re-glued the top edge.
Letting it cure for a full 24+ hours before I put the top fully down. I hope it holds.
welder4956
Birmingham, AL USA
Finished cleaning the seat cushions on the boat, but did not have any grease so have to postpone the wheel bearing inspection. Also replaced the capacitor on a freebie 200 psi Campbell-Hausfeld portable air compressor. It helped, but still seems to be tripping on thermal overload before it gets to shutoff pressure.
niget2002
Josephine, TX
Nice work! You going to cover it with chicken wire or square mesh?
I'm only going to cover it if chickens start going through it.
I noticed last night that some of the chickens were squeezing under the bottom of the gate. The plan was to have the gate closer to the ground. I'm not sure if the concrete setting caused the frame to heave up a little, or if I just didn't dig deep enough holes. Either way, a 4x4 across the bottom of the gate is keeping the chickens in.
They've been inside the fence all day today with no escapees. If they start to escape then I have some square fencing I'll wire wrap onto the gate. At that point, I'll extend the square fencing down closer to the ground to remove the 4x4.
larry4406
Northern Virginia
More in my driveway using tools from my garage but continued working on the garden tractor. Frame cracked at front arm pivot so had to weld it.
mhm993
Changed the oil, brake fluid and front rotors on the track car. And found a brake pad—front pad, pretty new— where the friction material separated from the backer plate. Never had that happen before.
smackey05
Massachusetts
Changed the HID bulb in the wife's Audi. Of course the bulb was shattered. Had to fashion something up on the end of the vacuum to get the broken glass out of the headlight housing.
pepi
Woodstock, GA
I added a chicken run extension. The middle portion was built in my shop. Its hot af outside. I had my swamp cooler going all ahead flank to keep me cool. Wife helped me move it into position. The chickens are happy with the addition. I just got done painting it... man its hot outside.
I like chickens, my neighbor who has since moved,had about a dozen. Seeing them run around the back yard. I told him they looked like sail boats. Cheickens are a hoot ....
niget2002
Josephine, TX
I like ours, but we recently had to fence off part of the yard for them. They recently started roosting on the back porch and pooping on everything. Spent the weekend putting in the fence and power washing the patio.
Light stuff, (It was supposed to get hot, so I wasn't planing any thing heavy)
More oak tree trimming (the pole saw fix worked!), used goof off to remove some paint from a long aluminum case I picked up a couple of weeks back and opened the tent trailer and put the canopy poles in it - great fit! - general putting stuff away away, - did the initial fix on the camp "throne" that collapsed under a big guy's weight last year (straightened the "hooks" for the folding stand) but I do need to make an addition so it doesn't happen again...
Fix Until Broke
SE Wisconsin
Up here where snow plows are not needed due to the pre salting, salting and post salting of the roads around a single snowflake in the forecast, having the friction material come off the backing plate is a regular occurrence. It's happened half a dozen times on cars just in my household in the last 10 years. Typically they shoot out on you during a stop which makes for a sphincter tightening few seconds and teaches you not to tailgate!
Back when they used to rivet the friction to the backing plate this was much less common, but they're all glued on or have little divots where the friction material fits into.
In my garage today...got the bikes out and went for a 4.5 mile ride with my son, cleaned up the mower deck and mowed the lawn, found a damaged repair on an extension cord that was tripping the breaker for the garage.
softailgarage
Bullhead City, Az.
Picked up some base board and trim at Home Depot on the way home from work. Been re-modeling what once was the dining area now a bar area. Too damn hot to go outside and cut it.
ambenz
NW Chicago Suburbs
Some of the sueded naugahydes discolored when subjected to new
Yup...for some reason, my vinyl inserts did stain...maybe they are leather? When I purchased the seat covers from covercraft, they were toughted as vinyl inserts and leather sides...
Those are interesting clamps. Did you buy them specifically for this job or are you in the business of fixing convertible tops?
I was also curious about what type of glue is used to bond vinyl to glass?
My top is pristine but I also have this type of top and have never seen the glass delaminate off a top like that!
Kind of scary to know my top could do that, so I am a bit curious about the glue, clamps, and cause.
alex71
SE Florida
Leveled and bolted down the last two sections of pallet rack. Finished running electrical.
LeonardY
Southern California
The clamps are automotive trim clamps. I got them on Amazon.
I also used rare earth magnets to clamp the fabric together where it needed to be re-glued. That worked like a charm.
No, I'm not in the business. The top had de-laminated several years before. I looked for someone to repair it but no one would touch it. They all said the same thing. The repair won't last. They just wanted to replace the top. So I made an attempt back then. It held for about a year.
Fast forward to now.
I previously used 3M window gasket glue. But it wasn't meant for any type of structural applications. This time I used 3M Window Weld. It requires a primer be painted on the glass. Other's have had success with it. The top is fabric. There is some tooth to it. I found there is a seam around the window where the fabric is glued together. That had separated too.
As far as the reason. My mechanic (Only works on Volvo's) has seen it before. We both think it is due to the heat here and no humidity in Southern California. The glue simply dried out. I confirmed it when cleaning the old glue off. It was brittle. It's not that uncommon for glass windows to de-laminate.
It took about a week. Working in sections and making sure that the urethane had cured.
I plan to replace the top at some point.
I really hope your top doesn't do this.
Jarhead0408
Who knows?
The casters help with that now. I was draging it around to make room for other projects as the came and went.
Gotcha. I'll keep that in mind.
I bought a Lincoln 210-MP when they first came out but never had the time to start going with it. I've got a bit more time now so it's time to crank it up.
pepi
Woodstock, GA
Did a nice job, looks like they will be living large with the new digs.
Arne73
Well as I was reading a post by Rattle snake/Justin I bought a pair of led headlights for the driver project. Arrived quickly and got them installed. Plugged in an worked perfectly, ready for a night ride and to re-aim. I was glad I had a spare pair of old buckets cause I had to hack the heck out of them to get the new deeper LEDs to fit.
How do you like the performance of the LEDs?
I installed a pair of LED headlights last year and had similar fitment issues but I'm happy being able to see in the dark.FB_IMG_1596371703778.jpg
Forgottonia
edge of Forgottonia
I shortened the handle on a fancy brass fireplace scoop to turn it into a mini-dustbin for my bench. It was an excuse to use an old tap-and-die set I bought used a while back.
Ilikeike
Northern Ca.
Added in a new upper cabinet. So I had to unbolt the tall left cabinet, move it over and put the new upper in its place. Cut out a hole in the back fir access to an outlet. Then re-bolt everything together.image.jpgimage.jpg
And you have a good spot for all the free stickers that accumulate. :)
ckanderson
Electrician comes today to finish wiring up some stuff. Also I'm finishing up the demo work on the half bath/laundry room that was built on the back half off the garage. Turning a 9x14 foot space into a 9x20. Still small but is what it is
JDGolden
Most recent was a differential gear oil change on my camaro. Took forever to remove all of the old gasket. I put on a new Lubelocker gasket and Royal Purple gear oil. Boy, wouldn't been much faster with a lift.
