zmotorsports
Final pictures of the weekend's work.
While the paint was drying on the axle I began to bleed the brakes and pull new brake fluid through my entire brake system as I do this every other year on my Jeep, as well as all my other vehicles for that matter.
Another routine maintenance item on the list was to replace the rear brake pads. These have held up well and in 129k miles this is the second set I have replaced. I noticed they were getting a little thin during the last LOF service so I had a new set of pads sitting on the bench ready to be installed. I pay particular attention to my brakes before our annual SW Colorado Jeep gathering as the long steep grades that we must ascend to around 13k feet elevation, we also have to descend and with 1k foot plus drop-offs brakes are not something I want to worry about.
New anti-rattle clips installed with a little synthetic brake grease applied. I also pull the guide pins from the caliper brackets to clean and lube them as well. This ensures the caliper slides on the pins properly.
The synthetic brake grease I started using on my brake hardware recently. One note here, be careful how much lubricant that is applied to the brake guide pins as you don't want to apply so much that it gets into the bottom of the guide pin bore. What can happen is when the brakes get hot the extra lubricant can expand and therefore push the caliper pin outward applying pressure to one of the pads moreso than the other resulting in uneven wear as well as more heat as it is applying half the brake pads for that particular corner.
Brake caliper and pads installed and brake pedal depressed a few times to seat the pads against the rotor.
Lastly before putting tires back on I add a small bead of Torque Seal to the brake fasteners. This creates a visual indicator of the fasteners for quick checks.
Yesterday I spent about 6 hours rebuilding shocks, touching up some paint, going through the front brake components and putting everything back together as well as a detailed inspection of the chassis and powertrain in preparation for several RV/Jeep gatherings and rallies that we have coming up over the next several months.
Thanks for looking.
Thanks for looking.
I will be needing new tires more than likely before this coming winter as mine have gotten down to around 1/4"-9/32" in the 36,500 driven miles and probably close to another 13~ish thousand towed miles. They have worn great and have been an excellent tire but I have been eyeing the new Mickey Thompson Baja Boss A/T in a 37x12.5x17 that was just released and it looks like another nice "hybrid" tire, plus it actually has the 3-Peak winter rating so I have been contemplating trying them out next time. Trying new tires always makes me nervous because it is a lot of money to be laid out and then the possibility of them not being as good as what you removed, but then they can be better too.
