05snopro440
It doesn't seem like those 2" long 1/2" anchors meet the requirements for securing to the floor by the manufacturer. While it would be secured, that could give a false sense of security.On the "bolt it down" topic: if you want to retain the ability to move a 4-post around your shop but bolt it down while in use, these are what I recommend.
Red Head 1/2 in. x 2 in. Zinc-Plated Steel Concrete Drop-In Anchor (1-Pack) 50126 - The Home Depot
Get the Red Head 1/2 in. x 5/8 in. Steel Concrete Drop-In Anchor 50126, metal anchor is crafted with steel for strength and can be installed below concrete surfaces at The Home Depotwww.homedepot.com
When you pull the bolts to move the lift, you're left with nothing protruding from the floor. When you bolt it down, these anchors provide plenty of strength/rigidity. I only use two bolts/anchors per column on my 9K 4-post.
I'll echo what others have said, when lowering, you absolutely have to hold the lock rod all the way open and focus on ensuring that all four corners are lowering. The only way something like this happens (to this extreme extent) is by inattention when lowering the lift.
The manual lists this: "Concrete shall have compression strength of at least 3,000 PSI (20684 kPa) and a minimum thickness of 4” (102 mm) in order to achieve a minimum anchor embedment of 3 ¼” (83 mm). NOTE: When using (¾” x 5 ½”) (13 x 140 mm) long anchors; if the top of the anchor exceeds 2 ¼” (57 mm) above the floor grade, you DO NOT have enough embedment."
They also provide a minimum torque that needs to be achieved tightening the anchors.
