Whew......
The owner came and picked up his 2002 Silverado 2500HD last night. He was ecstatic over it. I couldn't get a read on him at first when he dropped it off nor over the phone when I called him to inform him it was done. When he dropped it off and we were going over the plan of what he actually wanted out of the truck he knew more about what he didn't want than what he wanted and it was hard to get a read on him as to what he was really after. Obviously, those items that we discussed as per the front leveling kit and steering were a given but I then took some liberties with the stuff we didn't discuss. Also, he was shocked that the exhaust was installed because the last he knew is that it would be a couple weeks out as I hadn't told him the exhaust showed up early. He was fully expecting to have to bring it back in a couple of weeks.
When he walked into the shop last night he lit up. That is why I love doing this so much. Some shops want to give their customers exactly what they need, I want to give people what they didn't even know they wanted.
Afterwards my son brought over his MIL's snowblower to have me help him with it. He knew it had carburetor issues but was still having a hard time getting it to run and said when he shut if off fuel spit out of the carb.
We put it up on the lift to work on it and I noticed right away it was quite wet around the exhaust muffler. He said it was smoking quite a bit after he installed a new carburetor on it. They had let it sit all summer long with ethanol fuel in it and the carb was plugged up solid so he had ordered a new one. When it arrived he installed it and that is when he noticed it smoking and spitting fuel upon shutting off.
I removed the carburetor mounting and primer housing to inspect to make sure the primer was functioning properly as well as I wanted to put my pressure pump on the fuel inlet of the carb and ensure the needle and seat were holding pressure before going too far into it.
The needle and seat were holding just fine with the new carburetor. We fired it up and only let if run a matter of seconds before shutting it off. As soon as I shut if off, fuel spit back out of the vent hose right onto my tool cart full of tools. I told my son to check the oil level. He pulled the dipstick and sure enough, way overfull. Bingo, the old carburetor's needle and seat had allowed the fuel to drain from the tank and filled the crankcase.
We drained the crankcase oil, or fuel rather.
Look at that fuel pour from the crankcase. Yuck!
After draining raw fuel, we refilled the crankcase with actual oil, cleaned the muffler the best we could and cleaned and blasted the spark plug then reassembled and ran it for a while (outside) until it quit smoking indicating that the raw fuel had been burnt off from the exhaust and combustion chamber. My son was on the right track doing the repair but didn't realize the crankcase had filled with fuel and the fuel being expelled when it was shut down was actually coming from the crankcase vent and not the carburetor. I was very proud of him for helping out his mother-in-law and for diagnosing it as well as he did, just didn't take the symptom to the next step. It was an awesome teaching moment when he saw the fuel in the crankcase and I saw the light bulb come on.
Overall a quick and easy job that I hadn't planned on for the evening but I was able to spend about an hour hanging out with my son in the shop so very much worth it.
