ZRX61
Put the bike up on the rear stand so I can clean all the **** off after being directed through a load of mud run-off by a cop yesterday.
I was reading that as Chevette, and wondering WTF you'd care.Took off the front bumper on the chevelle. I didn’t like the way it fit, working on getting it to align better. It may be a slightly bent bracket, slightly bent bumper (very subtle) and/or the bumper filler panel is slightly beat up too. Combination of all those make it look like it doesn’t fit correctly.
More of this chit ...
And.. started pricing my 2000hp 47/48re
Is that a standard 16 foot x 50 inch cattle panel ? 130 bucks ? around me they are 30.00 at tractor supply. you should get some 2x2 angle iron and fab up a bending brake. lots of vids on youtube how to make one.Did some mesh bending tests late this afternoon for the gabion baskets, mixed results. I'm probably going to have to buy a 3-4' black iron pipe and notch it very near the end to use as a bending handle. The giant pipe wrench sort of works but not enough clearance for its giant head, I'm wrecking the side of my workbench just making slight bends.
But the technique / idea is working overall. I need to bend it a full 90 but cannot. At most maybe a 30deg bend before I have to bend the other side. Then I'll have a really laid open \_/ shape. THen maybe I can flip it over and clamp the bottom to the table again and bend the sides inward with a lifting motion instead. AND due to the nature of the mesh, the bends have to be in small increments. 22LF of wire panel, a 6ga wire every 4", 7-10 bends of each wire, x two sides. That's 2500 bending motions. Yeesh
The 6' piece is longer than the distance between the table legs or I could bend it all way under the table. And I still have a 16'L piece that has to be bent as well.
Bending overall probably wasn't a good idea. I should have just diced the panels into their flat plane constituent parts and hog-ringed everything together. As it is now I have cut them down for bending and pretty much have to press on with bending, or else I need to spend another $130 to get another 16'L panel home.
Pics of the Chevelle please! Love a 66.Took off the front bumper on the chevelle. I didn’t like the way it fit, working on getting it to align better. It may be a slightly bent bracket, slightly bent bumper (very subtle) and/or the bumper filler panel is slightly beat up too. Combination of all those make it look like it doesn’t fit correctly.
cattle and hog are $32+. 4" pattern 'utility' panel is $72. I have to rent a 12' open trailer to get the panel home. $42.Is that a standard 16 foot x 50 inch cattle panel ? 130 bucks ? around me they are 30.00 at tractor supply. you should get some 2x2 angle iron and fab up a bending brake. lots of vids on youtube how to make one.
That's a good upgrade! I usually make the tongue longer and have a place to mount my ice box. Hmm, maybe off the back of the TT...Welded on 1 inch tubing to mount 20mm ammo cans on my utility trailer.
I tore my oil furnace half apart, finally discovering dead moussy right by the air filter, which is the lowest part of the system. So, the proper way I should have done this is; remove filter, pull dead mouse out with a hook.Not a damn thing. Spent too much time tracking down a dead critter under the house.
Spoiler alert. Didn’t find it. Now it smells like absolute death in half the house when the HVAC is running. So I’m thinking it’s in the ductwork somewhere. I inspected the ductwork and besides old repairs and old breaks, there’s no new signs of entry. At least not for anything big enough to smell THIS bad!
Some of my shipment arrived today (shop towels). Waiting on a replacement hub bolt to arrive as well as more anti seize and blue loctite. (Blue loctite for hub bolts and anti seize for hub mating surfaces). Apparently I am out of both? Can’t find either bottle. Either I’m out, or those were taken too when they stole from me. But what odd **** to steal!
On mine, the filter is the highest part. I’ve checked and rechecked.I tore my oil furnace half apart, finally discovering dead moussy right by the air filter, which is the lowest part of the system. So, the proper way I should have done this is; remove filter, pull dead mouse out with a hook.
SBC 350 with a Muncie 4-speed (M21)Pics of the Chevelle please! Love a 66.
That deserves straightening the bumper.SBC 350 with a Muncie 4-speed (M21)
Love it.SBC 350 with a Muncie 4-speed (M21)
The bumper bugs the **** out of me, I may just have to buy a new one.That deserves straightening the bumper.
They are just as pliable as if new. And I used the hell out of it when I was 5 or 6, been in a box for probably 40 years. Next up is the big dumptruck.Pretty nice! Kind of surprised the tracks are not gone...
Ford with alloy rims ?I wheeled the air compressor out to fill up my wife's car tires.... Again.
I need one of the 6x6 army vehicles with auto tire inflate for her. Haha. Just kidding, but it's weird that her right front tire always gets low and it does not follow the tire during rotations. It's consistently the right front.
