Grant Gunderson
While doing a bit more research into the Steelman method of converting the 3Phase AC motor of the lathes Motor / Generator setup to Single Phase, I found a really good manual on installing Steelman's H-A-S static phase converters... this site does a really good job of describing the steps needed to modify a 3 Phase motor to run on single phase. In this case 240V.
The first challenge with this conversion, is you need a 12 wire motor. Problem is most 3Phase AC motors only have 9 leads coming out out it. As is the case with Reliance VS drive this lathe uses. This is shown clearly on it's name plate:
The first step was to take the M/G apart and separate the internal star point.
This then gives you 12 leads. The first part of this thread on PM does a good job of describing that process. I documented that full process earlier in this thread. Starting HERE.
I used an Ohme meter to identify each of the leads as per the diagram in step2 above. With this done, I reinstalled the motor, and then wired the terminal panel. There is a lot of wiring going on in the terminal panel, so I did my best to keep it as organized as possible. I first connected the wires from the Lathes DC motor.
I then connected the leads from the DC generator portion of the M/G unit and laced the wires together to keep things tidy.
Next up was the main AC voltage in from the lathes main contactor panel. When I original ran the wire, I based it on the length of the original factory wire. In order to fit everything into one connection box, I replaced the factory vertical box, with a larger horizontal one. Thus created a problem, the AC main leads are too short!
So I ran 3 new leads from the main contactor panel.
In doing so, I spent some time looking at the panel and trying to better understand it.
If I am correct in my thinking, there is a transformer for a light by the main switch on the front of the machine, a 208-220V coil... not total sure what its purpose is in starting the M/G. There is two heaters, both #1375. Before starting this project, I had no idea what heater's where in relation to a AC motor. Turns out they are a thermal overload safety device to protector the motor. Am I correct in thinking that these protect against long term over current situations, where as a fuse only protects against short circuits? Regardless, I need to figure out what the value of these heater units are. It is also worth noting that only leads T1 and T2 to the motor have heaters on them. T3 does not, so when I connect the lathe to the mains I will only be connecting it via L1 and L2 for this conversion and only T1 and T2 will be transferring power to the M/G unit.
