Minimum shop bathroom size
zkdiesel
chicagoland cornfields
Last minute delima. What’s smallest shop bathroom size I can get away with for a sink, and a toliet? Will have slop sink mounted on exterior wall outside of bathroom for main cleanup
mike93lx
Richmond, VA
and Last minute delimawide . What’s smallest shop bathroom size I can get away with for a sink, and a toliet? Will have slop sink mounted on exterior wall outside of bathroom for main cleanup
Skip the sink. ******* only needs about 32" wide 48" deep if you do an out swing door.
If you want a sink, add 24" to width.
PoorUB
Fargo, ND
Yep, skip the sink if you are adding a slop sink outside the bathroom.
3x5 seems like it would work, but you will need to go outside to change your mind!
Depends on whay you want to use it for. Bathroom duties only? Then 3x5. If you will be changing from work to street clothes you might want more room.
nolimits76
Oklahoma
This is GJ, no one does the minimum, lol.
Seriously though. What is up with making bathrooms tight? I'd never do it. Also, you need to consider the space you have available and what makes sense. That said, here are some guidelines.
Shiftless
East Bay SFO
I was introduced to this combo when I first went to Japan, long ago.
When you flush, the tank fill water flows through the spigot on top where the sink is. You can then wash your hands and the slightly soapy water goes into the tank to use for the next flush.
Yeah, no hot water, but it’s simple and saves space and water too.
NUTTSGT
Northern Central Ohio
Measure a gas station bathroom and check out the layout.
For what you do, have you considered the shower ? Not only for showering but emergency decon, eye flush or anhydrous accidents.
southalabama
Brewton AL
This is over a urinal in a Bass Pro. I thought about pulling my camera out and grabbing a pic for years before I finally got the opportunity and prayed no one walked in.
Jeff Ivers
Oklahoma
My first house had a sink/toilet bath off the master bedroom. Width was just barely wider than the toilet. Sink (wall hung, no vanity) was in front of the toilet and if a person was at the sink, one could not be sitting on the toilet. The person sitting on the toilet faced the door opening that was just barely past the sink. It has been a lot of years, but I swear the dimensions must have been about 28 by 48-50 inches. I particularly remember this because of the day mom and dad were visiting and mom decided to use that facility only to drop her jade necklace down the toilet. Lovely job to pull the toilet and take it to the back yard to upend to retrieve the necklace!
rharman
SoCal
I've always felt that layout/combo results in a very awkward reach for the sink.
Do like the water savings though
rcsracing
Pittsburgh, PA
With a similar thought - appropriate size if including a corner shower? nolimits76 - those sketches are helpful!
In my shop planning, I'm thinking similar to OP, just with a 36x36 corner shower added. Toilet+sink. Slop sink outside of bathroom.
I don't want the absolute smallest Tommy Boy bathroom, but like some other commenters, I don't want extra bathroom storage space.
charbar
Midwest
Mine is roughly 5x10 feet with a *******, 4ft counter top with sink and also has my well panel and a small pressure tank inside. Probably didn't need to be quite that big but it just worked out that way. Plenty of room to change clothes or anything like that if you wanted or else hold two women when we are having parties (since women cant go to the bathroom themselves for some reason)
Friend of mine has a bathroom that I would say is probably 3x6 and has a ******* and a 2x2sink in it. Barely enough room to open the door. It is pretty cramped.
stick70
I tried to do 4x4 since I have a house bath that size. Turns out the sink and the toilet drains were too close for code. Ended up at 5x5, square made sense for the layout of the building.
nadogail
Coronado, CA
I remember a restroom in a bar where the urinal was a grid over a depression in the floor; there was no need to aim.
rcsracing
Pittsburgh, PA
Yea, I think 5x5 would work for a half bath, but add the corner shower (which looks to be 36-38" radius from the corner. Then what? 5x7? 6x8?
mike93lx
Richmond, VA
My last house had a 5x8 master. Toilet, 30" vanity and 42" corner shower. Door had its own dedicated space, but an out swing would replicate that.
Enough room for activities, for sure
u2slow
BC
In restaurants and such, I'm starting to see individual washrooms no bigger than a toilet stall with a miniature hand-washing sink hung on the side wall. Seems fine if you have a real utility/slop sink separately.
driftpin
I think the toilet and sink opposite each other is probably the most-narrow, and most practical use of space. We just did that for a half-bath in a laundry room, where a partition wall separate the W/D from the half-bath.
Leaflessshadetree
Don't ask.
I made mine larger than needed. I keep it warmer than the rest of the building (for a couple years it was the only heated room) so it was nice having a cabinet for some supplies. I also use it as a winter paint booth for small projects.
bluedog225
Texas
Smallest? Look at a boat or RV. Or just build the crapper against the wall and put up a room divider. You can frame out the room later, or not.
dcg9381
Austin, TX
Look up "wet bath" in a truck camper. I guarantee that's the minimum!
lolaetype
North Western Arkansas
If you are looking for the minimum I'd do a 3'X5' toilet room with a pocket door. Since that means you will have water and sewage for the garage, I'm assuming you will also have some kind of deep sink, either a stainless restaurant style or a laundry tub in the garage. Do your hand washing there.
EDIT: I see Nadogall had the same idea. Oh, and don't forget the magazine rack, decent lighting and a shelf for spare rolls of TP.
