Scissor truss question
markomarko
Regarding my scissor truss gable end engineering plans. Is my gable end scissor truss being delivered with a flat bottom piece of lumber on it? It’s being delivered Monday and I’m trying to wrap my head around it. I circled the piece in question.
M
markomarko
Yes that is what I’m expecting to do. I just wasn’t sure what that was on the engineering they sent me. It was throwing me off.
mike93lx
Richmond, VA
Why would there be a scissor truss on the end wall. Seems like a standard truss matching the roof line and a standard wall would be a he11 of a lot easier.
That makes it hard to properly brace the trusses and tie in the ceiling. Check out the link I provided above.
The Gable framing needs to match the ceiling profile
Firebrick43
West central Indiana
M
markomarko
Another thing I just thought of. If I balloon frame, what’s keeping the exterior walls from kicking out since there’s no double top plate under the scissor truss?
PCustoms
VT
Huh?
Double top plate isn't about walls kicking out, it's about proper load transfer from roof to wall framing.
You have 8+ feet of 2x material continuously framed up and attached to the truss, which is tied back to the rest of the roof trusses. Why would the wall "kick out"?
mike93lx
Richmond, VA
Huh?
You have 8' feet of 2x material continuously framed up and attached to the truss, which is tied back to the rest of the roof trusses. Why would the wall "kick out"?
And there is almost no downward load on that wall.
@markomarko it feels like you are getting way ahead of yourself on this build. You have trusses showing up but don't know how to frame the walls. How was the building designed?
PCustoms
VT
firebirdparts
Kingsport, TN
That’s not a truss pictured, so it’s very weak. That is why you need that brace.
Just to be clear, I am intending my response to be on topic. I am not making commentary on balloon framing but rather delivery
M
markomarko
Thank you for all the reply guys. Me and my friend put up all my standard trusses today. I framed out the gable end rake. I ended up doubling up the 2x on the gable end overhang so the r6 will **** up to it and then the next set of 2x for the overhang will be able to catch the vinyl soffit.
My friend and I will be putting up the scissor trusses tomorrow. We did everything just the two of us with a third friend helping out halfway through the day. The first gable end was very heavy to lift but it’s all set.
mike93lx
Richmond, VA
How are you transitioning to the scissor truss? Laying one against the standard, adding blocking to the standard or something else?
M
markomarko
It's not in the truss plan?
If they didn't include one for that purpose, I think you're installing blocking
It is not in the truss plan. We only received center and gable trusses.
mike93lx
Richmond, VA
Looks like it's time for blocking.
I'd use the same size lumber as the bottom chord of the scissor truss and mount it, aligned with the scissor truss bottom chord, to the standard truss. Tie in the bracing to that.
Firebrick43
The ceiling is very much a part the system.
Bracing can be used in lieu of the ceiling diaphragm if properly placed on the lower chords. There should be a bracing diagram with the trusses unless you told the engineer you were putting in a ceiling
M
markomarko
How we placed the scissor after the standard. We will have to figure out how to place a ledge for the Sheetrock to catch onto on the standard truss.
MongoTA
CT
The part circled in red is to help the truss designer with layout, it's likely that it should have been deleted from the end drawing.
Boss Hog
Someone on the board referred me to this question. I designed trusses for close to 40 years, so I can answer this one for sure.
I realize the trusses are already set as I'm writing this. But others will likely find the thread using the search function, and I want the correct answer on here.
The line you circled is a generic bearing symbol. It is absolutely not a part of the truss.
In my not-at-all humble opinion, this is poor truss designing. The gable truss should have been designed to be structural, so it could support itself until the balloon framed wall was built under it. A gable truss with studs only is not designed to support itself.
SusKatCas is 100% correct in what he posted about how gables with scissor trusses should be framed. If it was a smaller gable - Like 16' or so - It wouldn't bother me. But this one is large enough that it should be framed correctly.
M
markomarko
So you knew it needed to be ballon framed but didn't? Those couple of king studs are doing a lot of work
I put up 4 lvl’s as the king studs going up vertically. They are screwed in with structural screws and tied in very well at the top.
BobnCO
That looks pretty f’n good to me. When I started framing many moons ago, (tact homes) they were very often framed with “the hinge”.
Bert_
NW Iowa
Kind of a hybrid. Not really balloon framed, but definitely not an unsupported plate all the way across either.
bob smith1
that end wall should NOT have a scissor truss on it at all! And what Mike proposed is not right either. What are you building?
C-S-H
You still need to build support for the top ends of your king studs to take wind forces on the wall. The truss co. seems to have shook off the lateral design of the wall if you read the fine print. Imagine the gable end wall as a floor supported by the floor diaphragm, and roof or ceiling diaphragm, and at least 25psf load. The wind load on the top half of the gable end wall ultimately needs to find its way to the eave wall diaphragms. Maybe you could design some diagonal struts, but the load is high on the order of a ton.
M
markomarko
The top ends of my king studs are shot to the bottom of the scissor truss which in return is horizontally braced to the other scissor trusses all the way though the house into the standard trusses. If the wind is going to knock down the gable scissor wall it’s going to knock down the entire second floor…
C-S-H
From what I am seeing in your photo, you have a wall with 2 hinges in it. The lower hinge is stabilized, and forces taken, by the king studs. The top of the king studs are delivering force to the upper hinge. The upper hinge is stabilized by parallel struts, so essentially the entire wall is stabilized, and wind forces taken, by the ceiling drywall. We usually design a dedicated structural system that carries the gable end wall wind load to the eave wall diaphragms. The system is the roof diaphragm, a dedicated ceiling diaphragm, or struts.
I like your work so far. You obviously have a high level of craftsmanship. When they sell you the roof trusses, they want to sell you the false trusses on the gable ends. This is helpful in that it shortens the span for your 2x studs under wind load, but you must brace the hinge in the wall. The alternative is to use full-height studs with proper connection to the lookouts and to the roof diaphragm.
