I told him to unhook them from the load side of the gfi while doing it to make sure its isolated from rest of the circuit.![]()
Okay. I will get a new GFCI and do that.
By the way, I ohmed the line side just for fun and it did make a sound.
Perhaps this indicates a problem upstream?
Interestingly, when the GFCI is flipped and connected, there are 3 other light switches and an outlet that work. But, when I flip the breaker, they don't work.
So there must be some kind of accessory circuit that branches off and supplies power to these 4 things before it hooks up with the GFCI. Just thought that was interesting.
Could it still be upstream from the GFCI if I am getting 120V on the line side and all of those other things work?
Sounds like an issue downstream/load side of gfi.Okay. I will get a new GFCI and do that.
It was the hot and neutral from the line side
Thats your fault in the circuit weve been looking for,can you unhook the wires in each box to isolate which part of the circuit has the short?
Did you see my next post? There is a buzz between hot and neutral, neutral and ground and hot and ground.
This isn't normal?
As long as nothing is plugged in you should have nothing showing between them.
If you had something plugged in the worst case scenario should be continuity between the black and white because a circuit is being completed.
Having continuity between the black and ground is a dead short.
Has anything been mounted/screwed or nailed on a wall recently in that area?
Always start with the simple stuff.![]()
So I would be looking for a problem in the wire between the GFCI and the breaker correct?
Ok so the load side didn't buzz.
So we're back to the GFCI correct?
Nope
Ok, so please confirm:
With the just the line of the GFCI hooked up, you turn the power on at the breaker and the GFCI won't reset, correct? GFCI's cannot be reset without incoming power.
If that's the case, go to a known good outlet in the house, remove the outlet and install that GFCI and see if it will reset.
Yes that is correct. I will pick up a new GFCI tomorrow and if it doesn't work I will do this
Okay. I have some updates and pics. I checked all the outlets. A couple were cracked and the ground on the garage outlet look fried. I replaced two overall. The GFCI still wouldn't work
So then I bypassed the GFCI and ALL the outlets worked fine!
So, I am stuck now. I attached some pics of the box and lines coming out and how I wired up the GFCI
In the pic of the box, the wires that comes out of the bottom are 120V between them. So I hooked these to "line". The top two were hooked to load. I checked all connections, wire nuts, etc and everything was fine. One thing I noted was that when my nephew flipped on the GFCI, the LED flashed RED for a sec then went off. The other GFCI didn't do this (the original one).
So what now?
Did you confirm that the hot and neutral you hooked up to the outlet came from the same piece of Romex?
I.E. were they both in the same jacket?
That's why I want you to try the outlet on another known good circuit first.
So Wylie what is your recommendation as the next step? New GFCI?
Ok. I'm pretty much ready to give up on this. I got a new GFCI and it still won't work.
I mentioned that accessory circuit before that still works when the GFCI is off but doesn't work when the breaker is off.
I pulled those switches apart too and the dual one near the front door is a hot mess. Nothing is burnt is fried, but T=this one confused the **** out of me so I basically didn't even both to study it. The other two looked ok but the one thing I did notice was that none of the light switches had the ground attached to the switch. They were just wired together.
Unless anyone has some magical ideas I'm about ready to jump the GFCI so the other outlets work. Can I do this?
I mentioned that accessory circuit before that still works when the GFCI is off but doesn't work when the breaker is off. It contains the light switch in the bathroom, the dual light switch in the hallway and the single light switch near the kitchen. The switch on the right and the switch near the kitchen control the same light. Plus the outlet near the kitchen light switch is in the circui.
I pulled those switches apart too and the dual one near the front door is a hot mess. Nothing is burnt is fried, but T=this one confused the **** out of me so I basically didn't even both to study it. The other two looked ok but the one thing I did notice was that none of the light switches had the ground attached to the switch. They were just wired together. Here's some pics.
Why would that matter?
The GFCI doesnt give a hoot about whats going on on the line side...
The OP confirmed the feed to the GFCI is fine....
I suspect you either have a neutral shorted to ground somewhere or neutrals from two circuits tied together somewhere. Probably the latter.
I always thought that GFCI only sensed the load side, but I've read several sources that indicate a upstream combination of neutrals from multiple circuits can be a problem. It should be easy enough to verify if this is the problem. Fixing it if it is the problem might not be quite as easy. It may be hard to track down where the neutrals are combined if you can't readily identify the endpoints of all wires involved at every electrical box involved.
I believe that I would try to identify which wire coming into the first outlet is direct from the breaker panel (assuming it's coming directly to that box and not being fed from one of the other boxes). Then I would temporarily disconnect all of the other circuits and attach just the wire directly from the breaker panel to the line lugs on the GFCI. Cap everything else off, turn the breaker on, and see if the GFCI will reset. If it does, then flip the break back off, leave the switches and other non GFCI upstream circuits disconnected, hook the downstream outlets to the load lugs of the GFCI, and turn the breaker back on. If it still works, you know you've got something with the switches and can start really investigating that path. With the 3 way switches, I would be willing to bet that somewhere you've got the neutral lines of 2 circuits tied together somewhere.
