8m x 8m x 3m Garage/Workshop
H
hermanj
Port Elizabeth, South Africa
It is. Was a after thought for a braai area under cover and then the dog's kennels ended up in there.
With a bit of "lap en pap" there are no leaks.
Coming down now once the new garages are
H
hermanj
Yes sand, sand everty where. Fortunately it has been raining at least once a week so the dust is not too bad.
Also the building is happening right on the other side of the house/living area.
H
hermanj
Yeasterday started of as a sunny windy day and then the heavens opened up for 2 hours.
Enough time to get 2 sides up to floor height. 5 coarses with brickforce ond cavity ties on every layer
1949 caddyman
Arizona
So the brick wall is going to be the side of the slab? Will there be any bracing of the wall during the concrete pouring?
katotter
South Africa
What is the purpose of the brick ties then? If you reinforce the cavity and fill it up with concrete you surely wont have any damp to run off from it (that is the main purpose of the tie in a cavity wall).
I like the progress. Keep the pics coming. Also ******* down here making business slow.
H
hermanj
Just to tie the inner and outer wall to each other.
Getting plastic sheeting on the outside to stop the damp and coarse stone with agricultural drain. What ever that means. Also new to me.
H
hermanj
So the builders had a surprise for me. They came to work. Luckely the rain subsided.
West wall
East wall
Pulled up only the outer walls to stop the sand from caving in.
In the east wall you can see 3 pvc pipes installed.
One 25 mm pipe to bring in the main power cable - 16mm square and then 2 x 20mm pvc pipes. One to take power to future garden lights and one for power future entertainment area,closer to the pool.
H
hermanj
You have to. They are moving now so fast if I don't take a pic every night as I get home I miss a whole lot of progress.
Almost did not get the pipes into the walls.
Need to buy the toilet or I will end up chopping a 110mm hole into a steel reinforced concrete filled double brick wall. Need to put it in the correct spot and the builders build around outlett pipe.
Mach5
Phoenix, AZ
Nice looking yard. Brick must be very cheap in SA, since the entire back wall (above the retaining wall) is made from that stuff.
I've never been there. From the foliage in the pic, I imagine the weather to be pretty temperate...perhaps like the weather here in the U.S. midwest?
Oh, and I agree with the prior post -- the brick is "killer."
Do you plan to leave it solid, or is there a lintel/window or two in the works?
H
hermanj
Only one layer of brick. That has been pulled up to retain the sand. Thr 3 walls you are seing are all serious retainer walls. Still going to get steel reinforcement in the cavity and then filled with concrete. So no chance for a window anywhere.
Bricks are R3000 per 1000 and it is about R10 to the Dollar. What is your price per thousand?
Like I said plastering everything to make it as light efficiant as possible.
katotter
South Africa
R3000 per 100 for mampara bricks? They ****** you buddy. I paid R1560 per 1000.
As for the comments on brick being the cheapest way, that is true, concrete is expensive due to the rock and cement prices. Labour is also generally cheap as it is unskilled labourers laying bricks.
H
hermanj
No building again today as a result of the RAIN.
They did come and deliver the compactors today.
Price of bricks are based on supply and demand. Lots of building due to a new shopping complex and the Nouga harbour and the new wind farm.
H
hermanj
Well my die hard builders endured and by 12 it was a lovely day.
Built the centre column up to floor height.
Then compacted the floor.
Then 100mm of crusher run was compacted.
And then another 100mm of sand and compacted.
Then the reinforcing went up against the walls.
