8m x 8m x 3m Garage/Workshop
NUTTSGT
Northern Central Ohio
That is what our DBs looks like. This is a 15 slot unit.
2 slots for 2 pole Main isolator
2 slots for Earth Leakage switch
1 slot 40A circuitbreaker = stove
1 slot 20A CB = geyser
2 slots 15A = plugs grage and upstairs
2 slots 10A = lights garage and upstairs
1 slot 40A = future entertainment area
2 slots timer for garden lights
That should leave 2 spares just in case I want to run a dedicated line for my welder.
That's why I love these builds in another country. We get to see "out of the norm" stuff. :beer:
H
hermanj
Port Elizabeth, South Africa
No I am no electrician, but I am 'THE' electrician.
I will do all the boxes, condute and DB. But then get a profesional to then connect up the power ftom the main DB to the new one. Check all my lives are lives, neutrals are neatral and earths are well.......earths and then hopefully certify the whole installation at a fraction of the cost it would have been if he had to do the complete job.
First 1.5m of the cavities were filled today and the Rib and Block was delivered, but I was trying out the new bumper in the Baviaans Kloof so will only share some pics tomorrow. Almost could not get the Jeep up thr driveway because the R and B was just dumped at the bottom of the driveway.
NUTTSGT
So they only fill the cavities a little at a time ? I guess that would make sense if there's no bracing to hold the brick in place.
H
hermanj
The cavity ties (i did post a pic) ties the 2 walls together, but the cavity with the reinforcing in is too small for the vibtator, so they use a metal rod to get the air out. If they would make it the full 3m height, it would be too difficult to know when all the air is out.
NUTTSGT
Ah yeah, I remember you posting something about not using a ******** and using a rod instead.
H
hermanj
This is what the Baviaans looks like.
If anybody visitis South Africa..... I know you all want to go up Table mountain, visit Robyn Island, lgo ans see some wales, then there is the big hole at Kimberly and the list continues, but do not overlook a trip into the Baviaans. It is beautifull and untouched by man. I added the link. Hope it works.
http://www.baviaanskloof.za.cx/
Also saw some animals, not likethe Kruger park, or Addo, kudu, Bushbuck, a few huge tortoise and lots of Baboons.
We had a picknick basket, so halfway through the trip we found a nice shady tree, it was 27 deg C by then and had a few snacks and a little something cool for the throat.
H
hermanj
So after playing with my wife's toy ( the Jeep) in the Baviaanskloof yesterday and leaving the builders over to themselves, I am back todat to take some more pics and anoy the builders with my constant keep the site clean. Not that it really helps.
This is the R&B delivered to the bottom of my driveway. This is pretty significant to the builders as it is a fairly steep 40m to the building site at the top of the driveway.
This is about halfway up. Now you can start to see the building in the top courner.
The actual building site.
The lintels also arrived yesterday for spanning the garage doors. I desided to fit both doors with what we call caravan doors. Extra height to allow Jeeps with roofracks and Jerry cans to drive straight in.
1/2 Cup
Member Emeritus
Shepparton. Victoria. Australia
Keeping the site clean really helps a builder with health and safety issues, better productivity as the are not spending time looking for stuff and its a much nicer environment to work in. Keep up the great work.:thumbup:
H
hermanj
And up they go. Plan is to pack the roof on Saturday.
Tried to explain if they start on the other sides wall they will de working in the shade, but they have their ways and clearly this novice builder has NO IDEA :lol_hitti
H
hermanj
Got tired of bending pipes over my leg so manufactured this little bending tool. Can change the wooden insert to change the radius.
Bending spring into the PVC pipe, hook it into the bender and easy done. 100% the same neat bend every time.
H
hermanj
These are the ribs. They spanthe full 8m. They are packed about 510mm appart. The steel reinforcing faces upwards.
The blocks are then packed into the 510mm gaps. As you can see they have flanges that ly onto the ribs.
You run your electrical pipes along the cavities. There are some special blocks for placing your electrical connection boxes.
Once everything is packed, steel mesh is layd over the top and a 50mm concrete slab is cast tying everything together. The whole structure has to be propped for 14 days to give the concrete time to dry. Getting lighter and stronger.
The bottom then gets plastered to become the ceiling.
katotter
South Africa
I need to keep following along, this rib/block is beyond me right now.
Best way of explaining it is that it is the same as the American way of casting concrete. But where the US guys use plywood for forming and rebar for reinforcement. This is a plywood and reinforcement in one and it stays there. Personally I do not like using this method, but its the cheapest way of doing a co crete first story floor.
katotter
South Africa
Liking the progress Herman. Daai manne lê stene asof hulle betaal word ;)
I am still to read what you going to do with the floor? Tile? Polish? Screed?
I toled, but will not use ceramic again. Porcelain would have been better.
H
hermanj
Going to screet it as I will be doing a lot of weldiing and grinding in there. Like I said I am in the process of building an Atom type car. Spatks are only the small thi gs that will drop on the floor. There are still hammers, spanners and pieces of off cut steal
H
hermanj
Guys working till the shadows get looooong.
Pipes for the lights and upstairs in before it gets bricked up.
Cramic tiles for the other garage once the clean up starts.
What does polishing cost and involves?
katotter
South Africa
I am not sure about pricing. But I am sure if you get someone to do it they will **** you. I know the machine you use is cheap to rent and not that hard to do yourself. It looks like a huge floor buffer you would see at you local Pick 'n Pay polishing the floors. Instead of a buffing wheel, it has three random oscillating diamond cup wheels. That spins and grinds the floor level. Personally I love this look, but my prep was meant for tiling so I had to go with it.
Steel floating a screed in your case might be the answer. Thats a tough work surface for your car building.
Looking good.
H
hermanj
Our new press shop's floor was done like that, but I never saw how they did it.
Will still investigate this option. Looks nice to see the polished up stones in the concrete.
katotter
South Africa
That is what I like about it, you can see all the odd bits and bobs, I once saw half a bank card, a nail, orange peel and odd stuff like that, makes for good conversation whilst having beers with your mates.
H
hermanj
Thanks, that looks doable. Just don't have to be in a hurry. Do one get all the different grades of grit when you hire the machine?
Any idea how long a 60m2 floor will take?
It is pretty rough at the moment.
katotter
South Africa
Don't know,
Don't know,
Mine was rough too. I am pretty sure you can start with any surface and end up smooth.
madoc1
spicewood, tx
looking good! a question-you say you will pour a 50mm thick floor on the blocks. that sure seems like a lot of concrete. why so much?
H
hermanj
Apparently they have no structural strength. They are just there to give the concrete support while it dries.
They are like very loosely pavked cenent bricks. About 10 broke during the delivery process.
H
hermanj
Merry xmas to all the GJ junkies.
Could not believe it, but my builder arrived this morning all be it with a brand new crew.
Plastering the outside, so the damp proofing can be done and the back filling then be done.
Alvetro
Nogal on a public holiday. Great build you have there. From another local GJ junkie in the mother city.
Alwie
H
hermanj
O. Capetown.
They promised to restart tomorrow again, but this was a surprise when they arrived. I was very glad because I want the backfilling to get done to support that big tree again. It is still standing on luck and a few huge ratchet straps.
Alvetro
Best of luck for the rest of the build and compliments of the season to u and the family.
Care share more info on the "atom" build u have in the other garage ?
H
hermanj
Builders only left now. Complete rear wall was also plastered.
I am a huge VW supporter and wanted to build something with a VW powertrain.
Also looking at the future there might be a buisness in being able to produce a comettative racer for around R100k about $10K. That is doable if you use a single donar car.
So the eXso ( Don't want to use the Atom name) will be something with minimalistic body panel wise, but
Also getting rid of all the costly things like push rod suspension, fly by wire accelerator and superchargers.
It will be able to accomodate from a 1400 Polo engine to a 2000 20v Turbo Audi engine, just depends on you wallet.
So far I have built and fitted the engine and rear uprights. Discs all round and dual master cylinders with balance bar.
This is a 1800 Jetta engine, I will just bolt a Turbo to this engi e to start off. Should be good fot 150 kW and a lot of fun at about 500kg.
Stop the project to build a 7 Birkin. The 3rd Lotus 7 replica I am building. Both the other 2 were scratch builds. First one powered by 1600 Kent and 2nd one 1600 16v Toyota powered. The Birkin is powered by a 1600 20V Toyota, can understand why I want to build something with a VW powerplant.
The first one
The second one
And the Birkin
H
hermanj
Very easy, it only weighs about 200kg without the engine and fluids.
Strap the back to the roof rafters with big ratchet straps. Lift the front with my engine hoist. Then pull the table out and lower it down to the ground.
It is currently on the ground as I am finalizing the electrical. Tried to do it on the table, but was awkard, just too far to reach to the centre of the car and my engine hoist could not lift heigh enough to get the e gine in. Subsequently I have found it much easier to drop the car over the engine and then lift the e gine into position when fabricating the engine and gearbox mounts I had to in and out the engine 8 times in one day.:shocking:
H
hermanj
Doing the electrical is a little more complicated than the other cars. I have all the creature cumforts like wipers, water sprays, fog lights and the engine is fitted with a functunal VVT. Also powersocket for things like GPS and iPod charging.
