Maxcustody
UPDATE 2/14/22. Thank you ALL for the information and help in my decision.
I ordered an Eaton 7.5HP 80 Gal. air compressor. This is the one here:
eatoncompressor.com
I have been reading thru a ton of old threads on air compressors. I am trying to do all my research now and plan ahead, I only want to do this once and do it right.
After reading, I have found my current mobile compressor (old, but in good shape) Central Pneumatic 2.5 HP, 21 Gallon compressor does not have the correct CFM for the air impact guns I will have. So in researching I thought, no big deal get one will do the job................. and this is where the overload of information comes in.
I know there are a ton of good and not so good compressors in a large range of prices. Yes, I want to do this right and I guess I am contradicting my other statement of "buy once, cry once", however I am not a professional. For current and future needs, it seems a 3.5 or a 5HP, 60 gallon vertical will fit the bill and hopefully taken care of, will outlast me.........
It looks like Quincy would be a good option and they seem to have good reviews. I understand this needs to be hardwired to work correctly and be covered under warranty. I will have my electrician take care of this when he does the building wiring, then I know it will be done correctly. There are a couple of questions in regards to this. This is not electrical code related more of ease of use and safety questions. In my County and State, I do not have to have any permits etc.
- Being hardwired does it need an emergency shut off switch?
-magnetic motor starters with overload protection? Is this for single and two stage compressors? Is there a difference? I would guess the amp rating needs to be equivalent or higher to your compressor? Kind of lost on this one?? I keep reading the switch they come with does not last or is not sufficient for constant on/off use?
I will stop at this point and see where this goes and what suggestions and comments all of you may have. Thank you.
7.5 HP Quiet Air Compressor, Single Phase, 80 Gallon Tank, Vertical, Industrial
Eaton Compressor carries an impressive line of quiet air compressors, including this single phase 7.5 HP Quiet Air Compressor with 80 Gallon Tank.
