Ok I am working on my subwoofer enclosure and I am having a hell of a time trying to figure out what to do to get the cloth to lay right. I haven't tried to lay it yet but I don't think it won't look very good with the sharp edges. I have included a few photos of the box as it sits with the trim rings about where they will be when the box is build.
I am also going to try to put a chevy logo in the center of the box near the top and backlight it. I am probably going to fiberglass the whole top.
There will be a box or something built to decrease the volume of the box also.
I am trying to get the box to flow really good and the center will be inset from the subs.
I am thinking I need to
1)cut the vertical pieces on the sides so they are about half as deep as they are. so they would be shallower
2) Cut a notch into the center of the box between the two trim rings
3) Radius the edges on the top of the pieces (about the same curve as the trim rings)
Sorry if I can't explain very good but I'll do my best to answer any questions. Looking for some help here as I'm lost. To sum it up how should I modify this box to make the fiberglass look good and flow good with it's put on (IE No hard edges except ones that can't be seen)
