Tribalvision
Looks pretty good. Before you go smoothing it out, trim the edges and test fit the box.
I think I would give it at least one more medium coat of resin.
If you just coat it with resin it may cure but will feel sticky. Mat and cloth are treated with wax which well allow the resin to cure hard/smooth. They sell a wax additive you can add so it cures without being sticky
Sent from my <~ Galaxy SII ~€
Its hard to tell from the photos. It looks like the Mat is dry just inside the speaker on the right. At this point coating will not change anything because the resin is cured. If it feels sloppy in that area, just grind it out some and add another later or 2 to the area.
Feel for air pockets.if present, grind and repair. You want a solid box.
Not where the speaker is, just to the left of it where it slopes down towards the center. If is loose it will vibrate and crack
you need a larger alternator designed for higher output. With 3 amplifiers, it's only a matter of time until the stock one smokes. I recommend a 180-220 amp alternator and upgrade the Big 3...
yes, the big 3 is the underhood wiring. positive to starter, positive to alternator, alternator to ground. I used 1/0, but I'm drawing alot of current. You can probably use 4gauge and be fine. You can get it in nice colors to compliment your engine compartment. I also upgrade the engine and battery to chassis grounds too
