Above 1200 Sq/FT BoostingAZ's Garage & Woodshop
Boostingaz
Indiana
I spent the morning running some errands and then got some shop time.
There was a cat door that was just letting in mice and a draft so a hunt through the scrap pile fixed that.
Extra dust collection valve turned itself into a water hose hole. While I was out I picked up a water hose real on clearance at Menards so now I can quickly/easily roll up the hose when not in use and close the door.
I also picked up a little heater as it's been in the high teens the past few nights and I don't want frozen water. This is temporary. I have a ceiling mount Dyna-Glo Pro 240v heater on the way for the tack/water room. So in preparation for that I needed a bigger wire run to that room and a 30a breaker. Done, done, ready to hook up as soon as it arrives.
Boostingaz
Indiana
Wait....we?
You made that trip in that time frame with more than just the mouse in your pocket? That's impressive!
In the Waggy loaded to the gills. Whole Famn Damily, all 6 of us.
On the way there I had my Mom too, so 7!
Cost me about 200 bucks in fuel. Way! better than the $3k in plane tickets I already dropped for the upcoming spring break.
loganb
Omaha, NE
You've got blocking, what I'm guessing is the right size wire, connections made in a box, staples on the romex and clamp connections at the box instead of just sticking it thru the punch out...doesn't look bad! Honestly not sure if that run from box to heater by code should be a MC/armor cable whip or similar, but I'd have no issues calling it done for a barn at my place
Boostingaz
Indiana
I've got clamp connections on the box and at the heater, and it runs back to a 30a DP breaker.
Yea the exposed Romex is where I likely fail, it is technically probably a no no, but it's a barn and it's definitely not the only place where there is exposed to Romex. I have some flex conduit and box connectors for it but I don't think you are technically supposed to put Romex in metal either. I chose to leave it exposed rather than dealing with a possible overheat situation from it being in a shield. 🤷
It's like 16" to the box and then another 12" inches before it goes back into an insulated wall the rest of the way back to the panel. So it's not much.
loganb
Omaha, NE
As I understand it (and not an electrical code expert)....
There is no set height in the NEC for what is considered "protected" vs "unprotected" when it comes to exposed romex. Various areas/state may have different rules of X heigh above walls or finished ceilings, but those are also generally specific to dwellings. Barns and other non-dwellings are far more gray area in terms of what's required vs allowed or what's good practice vs not.
If it was mine, I'd have 0 concerns with that romex running from box back to wall and as long as it's high enough to not be a hazard for hitting it or animals reaching wouldn't be personally concerned with that run from box to heater. That appliance to box connection is just often done with flexible conduit but that's also dependent on amperage
Romex in conduit isn't expressly against the rules in the NEC to my knowledge, you just have to ensure the conduit is large enough. Around here it's really common to see in barns, pole barns etc with unfinished walls to have boxes mounted on the posts or blocking at normal height, then 3/4" or 1" EMT going up from those to 8' or so up and the romex exiting the conduit there. Helps provide protection to the wiring at the lower heights, then it's just run along blocking/purlin and stapled as required where it's not in danger of being hit
Boostingaz
Indiana
I was under the impression / thought (there is my first mistake, thinking haha) that Romex was not allowed to be in conduit, it had to be THHN solid wire. So I guess if you took the Romex jacket off and just ran each individual wire that would be "better" than snaking the whole Romex assembly? 🤷. But is the wire inside Romex specifically THHN or is the shielding different?
It's not in a place or position to really be snagged or touched so this point I'm just trying to update my brain database lol.
In other related matters I got my clearance rack hose reel up. Now my hose will stay nice and warm too and I can just pop it through my dust collector door when I need to fill water troughs. Quick connect on the spigot side to make disconnecting easy. I don't like to leave things plugged in when not I use.
This was brought on by the "animal sitter" left the hose stretched out in the back of the barn not drained and it froze solid. Took my two days to get it unthawed. This is what prompted this whole heater business. I was very excited to snag that heater on sale at Menards for $79 bucks though!!
rharman
SoCal
The "Romex in conduit" thing has been discussed MANY times. As I recall, it's allowed subject to certain wire size/amperage conditions but don't quote me. Also, it's been stated MANY times that you can't strip the jacket off and use the internal wire by itself as it's not rated.
Among many others here, @wyliesdiesels or @sparky 1971 can set you straight.
That new place is really keeping you busy....
Boostingaz
Indiana
Marshmallow in a can.
I just used two cans in the cabin to seal up where I joined the porch roof to the front wall. Half of it wound up on the floor!
Yes it is messy and sticky as hell! When they say we're gloves they mean it! I had a drip that was about to fall on the floor and grabbed it, sticky for days no matter what I washed with.
loganb
Omaha, NE
LOL
I've ruined so many pairs of pants and gloves that weren't meant to be disposable before I got smart and wore disposable gloves when dealing with that ****.
Boostingaz
Indiana
The foam works out to be about 5.30 per window or door. I figure that's a pretty darn cheap upgrade that may (or may not) save on some heating 🤷. It's only about $65 bucks to do the whole house.
loganb
Omaha, NE
I had to move operations to the basement. It would appear 19dg is too cold for staining 🤣
You mean the recently transplanted desert dweller stepped outside and nearly froze his balls off but he got turned back into the house before long term damage occurred? LOL
I can't blame ya though....you've got the space....interior finishing with water based isn't that smelly....doing it inside helps keep progress moving!
Boostingaz
Indiana
I was able to get two more jams stripped and two coated today. Sealer tomorrow. Then trim can go on these and we will be two more closer to being done, 21 more.
Boostingaz
Indiana
When it's not one thing it's another......
I finally took the time to fix my stove heater flue, yeah! Was going to load and fire it up last night and noticed some damn mice chewed up the blower cord 🤦. I cut it back to a "pigtail" so now there is nothing hanging to chew. I'll just plug it in with and extension cord when I want to use it.
Boostingaz
Indiana
I moved my clamps to behind the table saw as there is a small path that's kind of wasted. I can still walk behind the bench to grab what I need but this tucks them away a little better.
What I was really after was freeing up a wall cavity.......
So this brings the question to you all. I want to get some sort of hardware wall set up. I have the trinity hardware rack but I also have kids......
My youngest loves! nothing more than to while I am not looking swap items. I can't tell you how many times I've grabbed what I thought was an 18g nail or vice versa and thrown them in a gun to quickly find out there are not. I've become very proficient at taking apart nail guns to un-jam them.
So I want some sort of slat wall or similar that will accept or has bins as an option so that I can get everything up out of little hands reach.
All ideas welcome!
loganb
Omaha, NE
Assuming those have the same lip on the back as Akro bins, lot of options on this thread
I personally have done the u shape shelf standards on a 1x before...easy and available at any hardware store. There are some z clip hanging extrusions that can work as well. Have also seen some flat like 1/16" steel mounted with standoffs to give a lip to hook the bin on if you want to drill holes in metal
Boostingaz
Indiana
Some great ideas there, thanks!
I started following some links and post #1 here is super clean and sounds like what you did.
loganb
Omaha, NE
Yup, just found a Pic of what was done
LXCam
I’ve done 1” x 1/8” flat bar spaced a 1/4” off the wall for bins before. For the width of that space it’d be what I’d do.
Boostingaz
Indiana
The Trinity bins are a little different but I think would still work on that. I'll grab a pic when I'm out in the shop after the kids go down.
