mustangmccance
- Joined
- Sep 8, 2009
- Messages
- 832
Does this count? Power angle for my quad plow using a linear actuator. Works like a charm..
what size linear actuator is that and where did you get it. that would be nice.
what size linear actuator is that and where did you get it. that would be nice.![]()
Here's a roller stand that I made for supporting material while being cut in my horizontal bandsaw. [img said:http://farm4.static.flickr.com/3393/3548086962_ac7ba718a7_b.jpg[/img]
Jaysin
I thought that I would add a few of the tools and things I have built.
Hydraulic press I built to operate my Northern Tools press brake and press bearings and whatnot.
Jaysin
Unfortunately I was in too much of hurry to take pic's at the time.....the part was about 1 1/2" thin wall (1/16") square tube with a bunch of holes for a pin to go though near one end. It was chrome plated and I feared it would look bad if put any heat to to it. So I used a press to straighten the overall bend out of it, then pushed the out the low spot in the middle of where the bend had been with the homemade tool until the second piece, which telescoped through this one for storage, would fit easily (drop right through). Good enough for a quick no-cost repair!Neat idea. Do you happen to have any shots of the tubing you fixed?
heres a pinch bolt removal tool I made for my passat.
And its used for removing this.
JaysinSpaceman,
I would like some details as to how you raise and lower roll height. I sure do like that stand. How does the threaded rod move up and down.
That's a nice piece of work, especially in 15 hours. There are probably people here (myself included) who might like to duplicate. Could you provide some detail photos and explanation of the design / constructionHere's one of my latest contraptions.
A 5' sheet metal brake, now with hydraulic power.
All the steel was drops from previous jobs. The hydraulics are from my Hossfeld bender. Took about 15 hours to build it.
The brake. It bolts to my layout table.
The hydraulics. Simply un-pin the cyl from my bender and pin it to the brake.
The results. It'll bend 16 ga up to 5' wide, up to 95 degrees.
