If I were closer to LaCrosse, I would be all over this for $45.
https://lacrosse.craigslist.org/tls/d/la-crosse-vintage-floor-drill-press/7004864465.html
Looks like someone put a floor length column on a benchtop model.
Me too!!!If I were closer to LaCrosse, I would be all over this for $45.
Yep, but I'd still be all over it.Looks like someone put a floor length column on a benchtop model.
NICEIf I were closer to LaCrosse, I would be all over this for $45.
I'd like to find a decent Craftsman box grinder. I had a 1725 rpm motor on bench with grinder wheels on it. I used it for correct motor when I restored drill press. Using a 3450 motor off a table saw right now but it is too fast. Anything decent around here is costly or too far for me to travel.
Is there something special about the grinder? I have one that is very similar, although the light cover, and other shields are missing. It also vibrates around the table when at full speed. Was about to get rid of it but kept it around to use the motor to power a fan for painting.I picked up this 397.19580 1/3 hp bench grinder today at an estate sale. It was born on July 14 1969.
Missing the rubber feet and one wheel cover. The paint is flaking off the lamp shade and the lower portion of the center band. One rest is worn from the wire wheel. The glass in the shields is good.
Cough.... Gasp....Is there something special about the grinder? I have one that is very similar, although the light cover, and other shields are missing. It also vibrates around the table when at full speed. Was about to get rid of it but kept it around to use the motor to power a fan for painting.
Most of the markings are faded but here are a couple of pictures if it. I pulled the sanding wheel and wire wheel off and it tab very smooth. Put the wire wheel only and still ran well, so thinking the sanding wheel is probably out of balance. Does have some adhesive left on it, but glad I hadn't put it out for the scrappers.
Any suggestions for shields and a replacement light?
Thanks, will head over and start reading!Hello sir! Those are great grinders and will last a lifetime. This thread will answer all your questions, and possibly create more[emoji23]
Try to ask your question on this thread, these guys should have the parts you need!
let's see your craftsman block grinders
https://www.garagejournal.com/forum/showthread.php?t=157794
What is the multi speed attachment on this Dunlap model 80? It doesn’t look factory but appears to be an off brand? Can any one identify it?
My swag would be home made, but I dunno.
That's a 12-1/4" drill press. If Craftsman branded, it would be a model 80 made before 1950. If Dunlap branded, it a Bronze Bearing Drill Press, 1950 or later.
How good are those? Can you replace the bearings with conventional ball bearings?
If there is no noticeable spindle play in the quill, they are decent small drill presses.
I inherited a 12-1/4" drill press that was my dad's and used it for 25+ years before I got my 15-1/2" dp#1. My brother has it now.
My last two acquisitions were 12-1/4" machines. Both have good sleeve bearings.
It's not practically possible to convert these to ball bearing.
Makes sense... I thought maybe the bearing holes were the same size but guess not. I will have to see if the seller even wants to sell separately. It is listed with about 15 other vintage wood working machines and is just posted as one big lot.
They are $150 - 200 easy around here. Only the occasional deal pops up.
Sent from my Pixel XL using Tapatalk
Looking for parts help. Recently got my dads old drill press.
Model 150 1963 103.24511
I need the feed return spring pn 38989
Any suggestions
Thanks
Tim
Smokeshow has been a terrible influence, of late. Or a good one depending on your perspective.
This DP100 can home with me a couple months ago. Most importantly is the Atlas table lift that came with it. The seller listed it on CL for $125 but because of my work schedule, it was going to be 5 days before I could meet the seller. Because of that, I offered the seller$150 if he would hold it until the weekend. He agreed
Brian
Looking at a Craftsman benchtop DP. Seller wants $100. Model number 10323640. It is grey with craftsman logo and machined strip on the top. It has two handles with knobs. From my quick research this looks like a model 80 or 100. My question is does this one have bushings or bearings? I am going to look at it today. Will I be able to determine bushings/bearings without tearing too far into it? Any input on this is appreciated.
Kirk
The 23640 is a 13-1/2" model with ball bearings. The spindle pulley ball bearings and quill ball bearings in a 13-1/2" drill press are identical to the 15-1/2" drill press.Looking at a Craftsman benchtop DP. Seller wants $100. Model number 10323640. It is grey with craftsman logo and machined strip on the top. It has two handles with knobs. From my quick research this looks like a model 80 or 100. My question is does this one have bushings or bearings? I am going to look at it today. Will I be able to determine bushings/bearings without tearing too far into it? Any input on this is appreciated.
Kirk
Thank you so much for replying back. From what I’ve read throughout this and other threads $100 is about the right price for a working DP. Would you guys agree?
I don’t have pics of it but it is complete and runs. The paint is chipped. Not sure what, if any, accessories it will come with. The guy has been difficult to communicate with the last few days so we will see how it goes.
I picked up a model 150 pretty cheap on GSA auctions recently, but it has a base on it unlike any I've seen before, and wanted to see if anyone could shed any light on it. The column had also been changed out to a non-standard column (shorter and too thin-walled), but I've got a donor column (and base) from another rust-bucket I found locally on FB marketplace. This base is about 1 inch narrower in both directions (16 x 22 vs. 17 x 23) than the normal floor base, but the interesting thing is that instead of a shoe-type set-up, it uses cam locks that are pretty much identical to the table and head frame locks.
I believe that’s an Atlas base.
Did the seller get back to you?
I am looking for a bench top model here in Portland now that I have gotten rid of a ton of stuff this summer! I am hoping to find a nice one with original paint like franklee seems to always find!
