I cleaned everything back up and took a closer look. The nut seems to mate okay. Does it look like the first teeth on the left side on the top and middle jaws are broken? I know it’s hard to see but there’s only a sliver of metal on the top one which would be #1.Are the jaws in the same relative positions as they were before disassembly?
Do the split nut halves mate together properly?
In photo 3337, the middle jaw, is that grease on the far right tooth or is that a defect on the tooth?
Have you tried tightening with the key?
Those look normal to me. I have the same picture:I cleaned everything back up and took a closer look. The nut seems to mate okay. Does it look like the first teeth on the left side on the top and middle jaws are broken? I know it’s hard to see but there’s only a sliver of metal on the top one which would be #1.
So if that’s the case, does Jacobs still sell a repair kit for a 633C?
That doesn't look too bad to me.A couple of things, there’s some slight burs on the body and the jaws on 1 & 2 twist as the move downward. A jaw inserted in 3 remains flat all the way down. I’m wondering if that has any effect?
This information sure was helpful...This is what the gears "should" look like. The gear on the left with the long bushing rides over the top of the shaft. The gear to the right is actually pinned to the shaft that connects to the handle. You can see the hole where the pin is in. Just below that is the actual bottom of the gear. (Lift #4 pics)
This is all I am left with. This is the bushing and right at the top edge the pot metal gear sheared right off. I need this bushing because it is keyed inside. At the bottom of this bushing you will note a scar from a set screw.
That scar is caused from the collar set screw that secures it under the gearbox. You can see the bushing extends from below the gearbox, and then that collar is raised up and screwed down onto it.
The top of the gear should look like this.
So the trick will be, trying to mesh the two gears perfectly otherwise they won't really turn.
Glad to help.This information sure was helpful...
And thanks to Hoorn, Frank Lee, 11b30b4 for all the detailed info...
Jeff and Hoorn did a very nice job on those videos!Special thanks to 11b30b4 for the recent 3 videos on the Atlas table & Head lift accessory...
I've never seen any marketing for these other than in Atlas and Craftsman catalogs. I did sell two to the same guy for his Delta machines.How did Atlas market this item... I noticed on Vintage Machinery, it seems to be predominately on Atlas and Craftsman presses...
I may have also noticed it being used on a few Delta Rockwell presses... Was this a catalogue item Atlas marketed towards any DP with 2-3/4" columns?
I don't believe the green paint is original. Take a close look around the edges of the patent plate. I've never seen the inside painted.Mine arrived today in a green color... And pulling the crank cover off, I noticed a few things... The internal surface of the crank plate is painted green... Both gears are in pristine condition... The crank gear is Zymak... The ACME gear is steel (magnetic)...
Looking closely, the castings don't appear to have seen a repaint... I'm curious as to the green paint color... The two previous colors reported have been dark and light gray...
It's really not difficult to remove when using the right technique. On the last few of these I had, I drilled and tapped those patent plate mounting holes for 4-40 screws.I'm reluctant to pull the Patent plate to see what color might be underneath...
The clean inside is another clue that it was repainted. Usually the original grease is dried out and nasty.I'm not even sure if this unit has even seen any actual use... The internal surfaces seem very clean...
That was a very good deal!I paid $150.00 for the lift and I was hopeful the gears weren't trashed...
I don't have any lock cylinders, but I do have handles only.The only items missing are the two lock handles, which I'll need to acquire...
I don't recall ever seeing that shade of green anywhere.I have a benchtop Craftsman 150 DP and a Delta DP220 floor model... I'd really like to see this mounted on the Delta...
My plans are to clean out the old grease and reassemble with new lube, and pretty much leave the paint undisturbed...
Any ideas about the origin of the green color?
Frank Lee referenced an additional YT video on your channel that I missed... Just now found it... A most excellent presentation by you and Hoorn...Snips, congratulation and 150 is a great price IMO. thanks for the mention but Hoorn and FrankLee do all the heavy lifting, I just cobble stuff together and slap a video on YT.
Your YT videos have been great resource with my rebuilds... Keep up the good work...Snips, congratulation and 150 is a great price IMO. thanks for the mention but Hoorn and FrankLee do all the heavy lifting, I just cobble stuff together and slap a video on YT.
The blue paint is plenty scratched and nicked up. The spring looks like it was either replaced, wound clockwise at some time or both. It was detached from the pinion shaft.An outstanding example, well preserved 1940s Craftsman blue. From the front, motor looks like it's in decent shape as well.
Case in point.I've never seen the inside painted.
A few minutes with a couple pair of needle nose pliers fixed that.The spring looks like it was either replaced, wound clockwise at some time or both. It was detached from the pinion shaft.
No, unfortunately.Does it have the third puley?
Uggg... That's going to be fun to correct...
A couple things...Hello guys! I picked up a 150 a few weeks back that I’m in the process of cleaning up and refreshing. It has a Jacob’s 633C chuck that I’m having some trouble getting off the quill. The chuck key isn’t cutting it for removal of the collar so I picked up a spanner after the suggestion from JeffsShop on YouTube (also directed me here for some input). I have to file down the pin to fit the collar hole better but before cranking on it on wanted to get some opinions here. Was able to wrench the key pretty hard and the chuck just isn’t moving like at all, solid as rock wall. I have a hex key in the chuck and have that clamped into a vise. In the pictures I’m showing the collar at both ends of where it’ll travel with the force I’m using with just the key. Thanks for any input!
Ok so it really is just a matter of force? Maybe heat…. JeffsShop mentioned being careful not to strip the threads on the retaining collar so I just wanted to make sure once I get the pin in my spanner filed down to size I didn’t rip the threads apart. I can pull it out of the vise. That’s how I initially started but it seemed like it might be less cumbersome in the machine. I hadn’t really attempted the removal in the machine yet as the key seemed useless. I just got a spanner the other day and hadn’t had time to fiddle yet. The chuck binds a bit midway so I’m hoping can sort that out once I get the dang thing out. I am a bit nervous about pulling it off. Currently it has very little run out, I fear I’ll add that. lol.A couple things...
If you're using the turned-down end of the chuck key, yeah, that rarely works.
Sometimes it takes considerable force to remove the chuck. I prefer to remove the quill/spindle assembly from the head casting and use a vise mounted to a bench. IMO, it's much easier. I also made a longer pin spanner to get more leverage.
https://www.garagejournal.com/forum...keys-etc-1946-1984.489080/page-6#post-9869508
Also, sometimes a previous owner will use a retaining compound on the taper to attach the chuck. Those are a pita and usually require heat to remove.
The threads can get damaged on the earlier 6A chucks with the separate thrust nut. Wedges should be used for those. The collar on the 633C chuck has more threads than the 6A thrust nut and is designed for chuck removal.Ok so it really is just a matter of force? Maybe heat…. JeffsShop mentioned being careful not to strip the threads on the retaining collar so I just wanted to make sure once I get the pin in my spanner filed down to size I didn’t rip the threads apart. I can pull it out of the vise. That’s how I initially started but it seemed like it might be less cumbersome in the machine. I hadn’t really attempted the removal in the machine yet as the key seemed useless. I just got a spanner the other day and hadn’t had time to fiddle yet. The chuck binds a bit midway so I’m hoping can sort that out once I get the dang thing out. I am a bit nervous about pulling it off. Currently it has very little run out, I fear I’ll add that. lol.
Thanks!
Excellent solution on the tool!I started on my disassembly of the Atlas lift as well...
I built a non destructive drive screw remover...
It only works if the mfg. used through holes for the drive screws and there is access behind and some room...
Factory light gray was behind the cover, confirming the green paint was not original...
Also noted...
Right image: keyed shaft bevel gear was one piece all steel...
Left image: Crank bevel gear is Zamak pined to a steel shaft...
My lift is #9 and I don't recall what the splined gear material was for the earlier lifts. I'll have to review some photos again. My current lift is clearly from the early '40s.@Snip's very innovative panel screw removal tool for tight areas.
Your keyed shaft metal bevel gear confirms that it was indeed made by Atlas at some point during the manufacturing of these head and table lifts.
I have I had seven lifts run through my workshop and of those, I too also found a metal bevel gear.
My thoughts exactly on the gear failures. IMO, the drill press gears had more stress, especially after A) the columns got rusty and the tables were harder to move, and B) those zamak table lock cylinders stuck to the columns.Post in thread 'Craftsman Drill Press' https://www.garagejournal.com/forum/threads/craftsman-drill-press.227480/post-9439354
In my case, the hand crank bevel gear was also zamak. Also of note, it was from a lift with original light gray paint as well.
I speculate that later model lifts were having metal keyed shaft bevel gears introduced. Since it's the same part for both tools, either the Craftsman / Atlas lathe apron gears were having occasional failure or the lifts, or both, and Atlas sought to correct this by using stronger material.
Based solely on photographs, I believe only two of my nine lifts had a steel miter gear on the splined sleeve; much fewer than I expected.My lift is #9 and I don't recall what the splined gear material was for the earlier lifts. I'll have to review some photos again. My current lift is clearly from the early '40s.
