endangeredspecies
Thanks guys!
I was trying to check level. The column is at such an angle that the table isn’t level. So the pulleys aren’t either. I’ll check into that in a bit.
Belt is new. (3 years old, but unused .) I got the Gates Hi-PowerII (A43), which was recommended elsewhere on this thread. Will definitely look into the toothed ones now that I know how easy it is to install and adjust.
First order of business was 1/4” holes in 1/8” aluminum with M42 bits. 2 different sources put recommended RPM in the 4500- 5,000 range. Seemed awfully high - and super fast in general. But I’m trying to do it right.
Next up is drilling bit holders in walnut with HSS. Looks like recommendations put me in the 1500rpm range (depending on diameter), so I’ll adjust level, slow it down, order a belt, and see how it goes.
