Wired up the supper-cool signal containing "peep" mirrors today:
Hardest part was threading the wire into the slotted arm, then through this retainer:
I'm a details guy and this rubber protector didn't sit right on the arm:
So I cut the one side a bit:
So it would better hug the chrome arm and further protect the paint:
Once installed on the door, it was time for some garage-selfies!
There's a few ways you can mount these mirrors, so the owner can decide which way suits him later down the road:
With the mirrors in place I measured out the wires. I ended up running a peice from the turn signal wire under the dash, through to door post and connecting it inside the door.
Next I ran the speaker wires and tucked everything up for the upholsterers:
Once it's back from the upholsterers, the window garnish moldings will all need to be installed. But way before that they need to be sanded out and painted, so today I sanded them out and put some high build primer on them:
I've had a few things to re-check on my list since initially mocking up the car and the gas pedal was one of them. The way everything lined up, the pedal was pulling the throttle cable down and to the side. Time to fix that:
Drilled a second hole to lower the connection point:
Chamferred the hole:
Then I took a little material off so the clevis wouldn't bind:
Now to remove the grinder marks and make it all smooth-like:
then polish it back to a shine:
Good enough for under the dash!
After getting all that done on the 40, I decided I'd better continue to show the Camaro some love....
Once again, my door caddy came in handy:
When I was pulling up the carpets, I found something else I'd never seen before:
These large diameter bolts, cut off flush with the floor:
Anyone know what they are?? At first I though maybe it was where they attached the body for dipping, but what's with the FRESH cut marks??
here's another item that I'd heard of - but never seen before: assembly line signatures!
With the parcel shelf cover removed, we can see it was an original light green car:
And that whoever hacked them up to install the speakers was either a hack, or McGiver!
If this old girl could talk!!
She'd say - can you fix me?
And I'd say: "Don't worry sweetheart, I'm a doctor...."
