Electric Lift Table Project
D45
NW INDIANA
I work on portable generators, mowers and snowblowers
I picked up this old lift table
Guy said the motor smoked and stopped working
I'm going to degrease the entire thing first
The wiring is a mess and the ground on the wall outlet plug is missing
I need to decide whether to see if the 1/3 hp Dayton engine is able to be rebuilt or if I should source a replacement motor
Comments?
D
D45
NW INDIANA
Here's the 115v Dayton motor
5K339AA
1/3 HP
D
D45
NW INDIANA
This motor says 115/230volt
So I assume it's just dependent on how it's wired
I only have intentions of using a standard wall outlet for power, so would this mean a replacement motor would be cheaper?
I need to remove the motor and see how it's attached and mounted
mike93lx
Richmond, VA
That looks super useful.
A single voltage motor may be a little cheaper, but make sure you match up the rpm and mount. Yes, changing voltage is just done with wiring and a plug.
If you have a local motor repair shop, they might have a replacement or can rewind it. May also get lucky and it will start up. Sometimes motors can have a little smoke left in the when some is let out
930dreamer
Amarillo,TX and Stinnett,TX
Most motors are dual voltage rated/ capable.
D
D45
NW INDIANA
I am going to degrease and clean the entire thing first, it will make working on it much easier and cleaner
It's really dirty!
I wonder how the motor shaft looks, will it be a simple gear driven assembly direct to the shaft?
BigNuge
Live Free or Die
It's really dirty!
I have a hydraulic lift table (similar dimensions w/500# rating). It is a godsend when working on generators/snowblowers and whatnot. There is nothing like having the whole machine at a comfortable working height!
D
D45
NW INDIANA
I wonder about the 1/3hp motor and if a 1/2hp would be any better and last longer?
Seems like 1/2hp motors are nearly the same price
I don't want to damage any of the gearing and mechanisms and I guess it doesn't need to be fast at all, slow and steady is probably better with this kind of lift
D
D45
NW INDIANA
I removed the platform
It was held on by a bolt, a quick release pin, and a neat grooved ring almost like a large diameter ring found on a key chain
It is belt driven, by two pulleys underneath
Currently cleaning all the thick caked on grease......that seemed to be too thick and too excessive. This likely could have led to the early demise of the motor since it might have worked too hard?
Anyway, the motor and platform are removed
D
D45
NW INDIANA
The motor is huge and very heavy, surprised it's only a 1/3 hp
If I were to also bet, I say it's not the original motor for this lift table
D
D45
NW INDIANA
The wiring on the motor was so hacked up and remnants of possibly the original wiring
I found a green ground wire that was cut and never connected
I'll get some pics up
isb cornbinder
I built my lift table in 2002. It served double duty as a motorcycle service table and an adjustable height workshop table. My hydraulic table goes as low as 5 inches as tops out at about 40 inches.
I used two hydraulic cylinders to slow the rise speed. One cylinder would have been strong enough. The remote hydraulic unit has a quick disconnect and can be rolled away for a 12 volt booster. TheHydraulic power unit has a built on charger.
D
D45
NW INDIANA
Who knows about electric motors
Here's what I removed
Dual voltage and amps and hp rating is all I know
What does capacitor start motor mean?
D
D45
NW INDIANA
Will a dedicated 110v/115v electric motor work just as good?
I don't understand why I would need a dual voltage 115/230 motor if I plan on using a standard wall outlet in my garage
D
D45
NW INDIANA
Interesting the shaft is Keyed and the pulley uses an Allen to secure itself to the key
Hopefully a new belt isn't hard to find. The pulley looks to need a V groove belt and the belt I took off is flat with 3 ribs
The ON OFF switch is archaic
D
D45
NW INDIANA
The ground on the motor wasn't attached and the 3 prong cord was missing the ground
I reattached the motor ground wire and found and old 3 prong cord I saved
Temporarily wired it up and plugged it in. Hit the switch and the motor hummed
I grabbed the shafted and turned it by hand and the motor turned on. Was smooth and no concerning noises
I then looked more closely at the motor and it does state Capacitor Start Motor
On the side of the motor are two wires with connection tabs. There's a dirt outline on the motor, where I believe a Capacitor should be mounted and wired in. Right or no?
I'm thinking, and hoping, that if I can find a Capacitor the motor should turn on and start rotating by itself?
Any help sourcing the right one?
D
D45
NW INDIANA
The motor shaft is 2-3/4" long
The shaft is 5/8"
The pulley looks old but it cleaned up very well
D
D45
NW INDIANA
Is this area and wires for the capacitor
D
D45
NW INDIANA
Any help with the capacitor?
60hz?
Two tab?
Any will work or do I need something specific?
LXCam
Since it’s a Dayton you can reach out to the Grainger help line and they’ll hook you up with the right capacitor and hopefully a replacement cover.
  • Like
Reactions: D45
Pinemarten
Washington
I have a different Dayton motor for my lathe. That is where the capacitor mounts on mine.
The outline of the cover looks like mine as well.
I think Grainger should be able to help you out.
  • Like
Reactions: D45
D
D45
NW INDIANA
I can't even find a parts diagram or wiring diagram for this motor
Dayton 5K339AA
cannuck
Rural SK
Dayton 5K339AA
Wiring diagram (key) for the motor is on the data plate you have shown. You need the wiring diagram for the lift to verify how the reversing switch is to be wired.
D
D45
NW INDIANA
What guage replacement 3 wire appliance cord will suffice?
10 AWG?
12 AWG?
14 AWG?
larry4406
Northern Virginia
I think I have a Dayton motor at home with a start capacitor. I will check and report back regarding capacitor and motor specs.
D
D45
NW INDIANA
Google say
You can measure capacitor through MFD ratings. An MFD or micro-Farad is a technical terminology used to describe the level of capacity in a capacitor. Therefore, the higher the MFD ratings of a capacitor, the more electrical current your capacitor can store.
285 MFD Capacitor(238 MFD, 125V Start Capacitor & 20 MFD, 240V Run Capacitor)
Start Capacitor 233 to 280MFD, 110V AC, Run Capacitor
125V Start Capacitor, 20 MFD, 240V Run Capacitor), 285 MFD Capacitor(238 MFD)
Alot of options........
So since I plan on operating the motor at 110v-115v, do I need a two tab *** MFD start Capacitor?
A run capacitor shouldn't be needed for this motor......right?
I saw one 1/3hp unit had a 519 MFD Capacitor
