Electric Lift Table Project
D
D45
NW INDIANA
The cover arrived and fit well
I'll get some pics up soon
Hopefully I'll get the motor mounted this week and find a V belt to connect both pulleys
Then will focus on wiring the motor to the switch, wiring the switch to the power cord, and fabbing a cover for the drum switch
Should the motor be grounded to the lift frame?
D
D45
NW INDIANA
Capacitor did snap firmly into the cover
I used some cardboard to prevent the Capacitor from sagging any inside the cover
I also added a 90° 1/2" fitting to run the wires from the switch inside the flexible metal jacket
D
D45
NW INDIANA
Does the motor have to be grounded to the lift frame?
Or is running the power cord ground to the motor sufficient?
D
D45
NW INDIANA
Handy Lift (Janco) wants $27.41 for the belt plus shipping
I'm hoping to find it locally for substantially cheaper
On the invoice they list it as:
Gates V-Belt 11350
D
D45
NW INDIANA
I think my local independent true value has a good selection of small pulley v belts
I'll stop there on Saturday
D
D45
NW INDIANA
They also want $45 plus shipping for the parts tray that sits on top of the vertical frame
I'm going to buy a larger magnetic parts tray for $15 shipped
D
D45
NW INDIANA
The motor definitely isn't original
Two of the four mounting holes don't line up
I'll mark and drill two more holes so the motor is properly secured with all four mounting bolts
D
D45
NW INDIANA
Mounted the motor today after modifying some of the mounting holes
I removed the second pulley, that is mounted to the vertical threaded lifting post, to clean and inspect
Blows my mind that the PO was running a flat ribbed belt with two V groove pulleys
I also adjusted the electrical fitting at the motor to run horizontal rather than vertical
D
D45
NW INDIANA
Goal this week:
-Find a proper V groove belt
-Reinstall both pulleys
-Buy and install flexible metal conduit
bpwoodworking
Really cool project!
Personally, I have not seen MC used in a continuous flex situation. On a machine where the conduit will flex all the time and is subject to possible pinch situations I have used type A liquid tight. It keeps out dust and is heavy enough to be fairly crush resistant, probably more-so than metal which is likely to cut through the wire if its crushed.
I've used the spiral type also flexible conduit but it tends to split along the spiral when flexed continuously so I prefer the type A style. It's nylon lined PVC.
D
D45
NW INDIANA
Thanks, it's a fun project so far and much cheaper than buying one new for $1,500 + (which I would never do)
The flexible metal conduit will not be moving or in motion with the lift table
It's merely running from the motor to to F/R/S switch that will be mounted near the top of the vertical post
I'm actually going to see if I can use rigid conduit and hard pipe the electrical wiring
D
D45
NW INDIANA
I went alittle on the heavy duty side for the power cord and will be using a 12/3
However, what size wire should I run between the motor and the F/R switch........14G or 12G stranded?
Wire length will be about 4 feet
D
D45
NW INDIANA
From what I have read, as a general guideline, you can typically fit around 6 to 7 12 AWG wires with THHN insulation in a 1/2 inch conduit
I will need to run a toal of 5 wires from the motor to the switch
I think 12G might be better than 14G, just a guess so
Jim_No_Garage
Millington NJ
@D45 - There was a similar lift table at a Rental store I worked at 25+ years ago. Is there any manufacturer tags on the actual lift? I like the design as it sits low to the floor.
Cheers
Jim
mike93lx
Richmond, VA
14 is more than enough
bpwoodworking
I wouldn’t run rigid conduit to a motor. Personally I still think liquid tight conduit is most appropriate.
D
D45
NW INDIANA
Suggestions taken, picked up some 1/2" liquid tite and fittings
I wish I could have found it sold locally, by the foot......had to buy a 25' roll and 8 fittings for $22 shipped on Amazon
D
D45
NW INDIANA
Time to get some stranded 14G today
bpwoodworking
That’s a great price! I usually buy on McMaster, nice thing being that they will do small quantities but the prices can sometimes be high.
D
D45
NW INDIANA
I opted for stranded 12G, bought four different colors and 8 feet of each (probably only need 4 feet)
Blown away it's so expensive!
0.85 cents a foot and I need to run 4 wires, oh well
D
D45
NW INDIANA
I need to add another wire for the drum switch ground
I initially only bought 4 lengths of wire, should have been 5
D
D45
NW INDIANA
New leveling feet installed with a rubber grip base, rather than the sliding plastic feet
D
D45
NW INDIANA
Trying to figure out belt lengths today
Definitely a 1/2" wide v-groove
The flat ribbed belt that the PO used wasn't proper for the pulleys
22, 23, 24, and 25
24" looks the best but it also has a tad too much slack........I'll run it and see
D
D45
NW INDIANA
This belt fit the best and without having the ability to adjust the tension before or after install, this is the only length I was able to fit on both pulleys
D
D45
NW INDIANA
It's all done.......raises and lowers really good and smooth!!
It's very quiet overall, much better than I ever expected
Total cost so far, including the initial purchase is around $300
I just need to find a cover for the Furnas drum switch
D
D45
NW INDIANA
Would Kydex be a good material for the drum switch cover? I've looked alot and can't find a replacement
Kydex seems to be easy to work with and mold when heated up and retains it's form when cooled
D
D45
NW INDIANA
The switch cover is basically would jave Two sides, two 90° bend and the top
The switch has two threaded holes to secure the cover
Motorman55
South Jersey
Interesting the shaft is Keyed and the pulley uses an Allen to secure itself to the key
Hopefully a new belt isn't hard to find. The pulley looks to need a V groove belt and the belt I took off is flat with 3 ribs
The ON OFF switch is archaic
The allen set screw keeps the pulley from walkingin/out on the shaft.
Firebrick43
West central Indiana
I would say so if you buy the correct thickness. Some of it for holsters is very thin. If you get some that is .093 or .125” thick I would think it would be excellent to make a cover.
  • Like
Reactions: D45
D
D45
NW INDIANA
There's a small groove in the switch (near the lever) that I need to measure, to see what thickness of kydex or sheet metal will fit in to the area
I think there is a threaded hole between the two ground screws for the cover to be mounted or it could be for a third grounding screw
D
D45
NW INDIANA
I could likely use that center threaded hole and use a threaded rod with a nut, to secure the rod to the switch
then mount the cover using the treaded rod with another nut......like a stem
D
D45
NW INDIANA
Going to look for a material in this thickness for the switch cover
