Between 265 & 485 SQ/FT Grumblebums Corner
G
Grumblebum
Wollongong Australia
GB, I must confess to never being in Hare and Forbes front door either, their online is enough to make me drool.:drool:
https://www.machineryhouse.com.au/
What breed of cold cut saw is it?
I did not part the motor from the drive on mine although I should replace the motor bearings at some point.
Cheers
It's an old Makita, here is the thread I started for it 1/2 Cup (sadly a while ago - but you can't rush these things) :)
http://www.garagejournal.com/forum/showthread.php?t=333630
Cheers GB :beer:
G
Grumblebum
Made up some brackets today to facilitate hanging up some of the garden items I've been making in recent times.
Don't know how I lived without a brake before, soooo much easier.
View media item 82688
Tightend up a little for these ones in the vise brake.
View media item 82689
Pre-drilled some holes to suit pop rivets.
View media item 82690
If you remember the garden shelving and vertical planters I made a while back, here they are finally mounted. Wifie was able to plant out the terracotta pots today with some new succulents she was recently gifted. That thread of grass will be sorted soon, it photo bombed there :)
There is some tie wire through the bottom of each pot so that it does not blow around and fall. It had come over all overcast by the time I took a picture, was nice in the earlier sun.
View media item 82691
There are still 3 more of the timber vertical planters growing out, so they will hang in this area soon too, it's a spot away from hot afternoon sun with some shading from our big olive tree.
View media item 82692
Thanks for stopping by.
Cheers GB.
G
Grumblebum
GB, awesome work.:thumbup:
So 1/2X2=1
X2=2
Great work, but the guard on your drill press seems to be stuck up.:scared:
Fence treatment is really coming along nicely.
Thanks guys. That guard is borderline more trouble than it's worth. The ones on my eyes were in place though...
Here's enablement by 1/2 Cup, this is going to be a super handy tool.
View media item 82799
And enablement by Andy & Kai, just need to work out what bench is best to mount it. Might setup a lock close spring or something to stop certain young people testing on small fingers though.
View media item 82800
Going to spend a few evenings getting the shop cleaned up (there is a thread by that name somewhere). Might take a before pic even :headscrat
Cheers GB.
G
Grumblebum
It's Tetris Time...
Have been doing some tidying up done during the evenings this week (will show the before picture at the end of this little process perhaps :dunno:)
I've been trying to get to the point where I can build an organiser cabinet to suit these suckers as I’m sick of pulling them out from down in the corner base cabinet. Anyway these won’t be enough now and it appears that the big Green Box store has changed brands/models and the now exact looking unit has grey tabs instead of the orange. One of these has a broken corner too somehow. I figure I’m going to make a rack to hold 20 in two stacks of 10. Hopefully that sorts all my hardware storage for the time being. We’ll see…
View media item 82861
Ended up moving this afternoon/evening the long overhead cabinets across onto the west wall. Originally I was going to make new overheads for this wall and a corner cabinet going back around the corner.
There is about 5" between the door frame and the end of the cabinets there so I'll be able to use that space for perhaps some rattle can storage.
View media item 82860
Now I’m left with this north wall bench area. I’ve mocked up the screens (have just removed the shelf the existing screen was on and added the second screen to facilitate some day job projects I need to work on) and will make up a frame to encase the small parts organisers etc hopefully tomorrow. Once that is done I can continue down that bench making the tray holder cabinet (I’m going to sit it on the benchtop so wall mounted weight won’t be an issue).
From there I can work on some basic overhead cabinets/shelving here. The existing 2 door will slide to it’s left about 9”.
View media item 82862
Cheers GB :beer2:
oldironfarmer
Terlton, Oklahoma
Hmmm, mine has a pin to hold it in the down position, which could be locked. I don't see the hole for a pin in yours, I'll get a picture if you like. Those knives will trim fingers off easily. You might make a wooden yoke to choke the shear open and lock it in place.
G
Grumblebum
Thanks Andy, will work out something for it. :thumbup:
Got a little further with the reorganization today.
The workstation plinth came up pretty good, happy with how it turned out. I might use some of the old fence railings I have to make a thin top for it.
Ignore all the cords and **** in the middle, it will get tided up in due course. Bit hard to see in the picture but the little cubby in the middle is where the data/power points are.
View media item 82906
Also got started on the organizer cabinet. Did a run to the hardware to look for the extra caddy’s I needed, but found that the current model of what I have is more square rather than rounded (which I prefer). So then of course they only had 8 on the shelf and I need 24 (originally was going for 2 stacks of 10, but with the measurements I can go 2 stacks of 12 and the top of the cabinet will be the base for the overhead storage to sit on) so I nipped a bit further into town to the other green box store and alas they only had 8 also. So I’ve got 16 of the 24 needed. There is another store a bit further away and wifie has to go that way tomorrow so she may be able to call in for me and see what they have left.
I was going to use some old framing brace I have left to do the angle mounts for each tray, but tested tonight and it’s not going to work very well. So i’ll have to get some aluminium angle to cut the mounts. That’s going to be 12 lineal meters.
View media item 82907
And a shot of the north bench area at close of play.
View media item 82908
Not sure what time I have tomorrow, we shall see.
Cheers GB.
rmalkow2
Brighton, MI
Looking like a productive task and creation of a very handy work bench. It will be a real future time saver to have all your bits and small parts organized and in one area to find what you need for a given project. And with two screens I see you will stay well informed on GJ happenings.
G
Grumblebum
That's so beautifully clean
GB, neat, real neat in fact..:thumbup:
That's way too tidy! Nice work.
Thanks guys, if only I could manage to get a 68.5mm spacer cut I might be able to finish installing the rails and tick the organiser rack off. Firing up the table saw at night is a bit much, will try's to do a cut in the morning and have a crack again tomorrow night.
It's cleaner than it was when I started. The mess is just 180 degrees out of frame at the moment :eyecrazy: I did do a before pic which I might share at the end of this little tetris session.
Hopefully a couple of computer related parts arrive tomorrow and I can see if the old apple screens will both run together - they are older but different models and there are some quirks with the compatability of the old lightning and mini display port connections. Anyway will see what happens.
GB
drivesitfar
GB: I always like checking in on you and seeing what you are up to. I always liked your metal fencing and showed my bride your new flower pot design. she liked it, but thought that you might want to change to glazed pots or maybe some other material cause she says clay pots will need to be watered almost daily if it's not raining.
I agree some sort of safety mechanism on your new shear might be a good idea or maybe building a hitch mount for it to attach to a bench so you can put it up high on a shelf when not in use. here's a link to the vise and grinder stand thread in case you might want to see some of the member's ideas on how to make a hitch mount for a stand or bench.
https://www.garagejournal.com/forum/showthread.php?t=252799
I hope you don't mind that I posted a few pictures of my favorites to maybe give you and others some ideas?
love the new bender too!
cheers
  • wilton tradesman on hitch mount with 90 degree elbow to get to bench height.jpg
G
Grumblebum
cheers
Drives, thanks for popping in. No worries with the photos, I think I'll end up down another rabbit hole in that thread, will be sure to check it out - so many good ideas here, just not enough time...
We do have a misting kit to hang over that area of vertical garden and will set the timer accordingly. I'll mention the glazed pots to wifie. I'm sure some will update over time (although I have wire tying them in place to prevent them being blown off). We chose that fence line as it's on the western side of the yard, and will be protected from the hot afternoon summer sun we get.
as I was scrolling down, I took another look, and I really like the plant shelves.
Thanks xtremek. They were pretty easy to make. Did you see the earlier posts on them ? (or have a look in my gallery). I was eyeing off an old sheet of mesh at my parents place the other day leaning against a shed, so might grab that and make some hangers for my mother also.
Finally got this little project done tonight. Cut a correct width spacer before heading to the office this morning and got it finished off tonight.
Very happy with it, it's going to be a time saver for sure. I think everyone should make one of these for their shop.
View media item 83055
Thanks for stopping by. Have a couple of small mothers day projects to get stuck into now before Sunday.
Cheers GB :beer2:
rmalkow2
Brighton, MI
GB,
Nice that you found enough of all the same type storage bins. The completed double stack looks great and I bet hold a lot of small parts. Are there labels coming for each tray or is your memory good enough to remember what's in each one?
Bob
xtremek
St. Johns, Mi
..... They were pretty easy to make. Did you see the earlier posts on them ? (or have a look in my gallery). I was eyeing off an old sheet of mesh at my parents place the other day leaning against a shed, so might grab that and make some hangers for my mother also.......
I'll be honest, I've been so busy I can't do justice to GJ anymore. Heck, I haven't been to Andy's, Bob Heine's, or Lyndon's thread in at least a week. Life is getting way too hectic, but my wife says I can't retire anytime soon.:lol_hitti
taumac
Brooksville, Fl
Don’t worry..... I’ve been away for awhile and only posting here and there. I just don’t seem to have much time to keep up.
taumac
Brooksville, Fl
Great project GB. When coming over to help me organize my place? LOL. I already got the bins just need a label maker and lots of spare time which I don’t seem to have much of lately. It’s gunning Bob asked about labels. I can’t remember where all the tools are in my boxes but I need labels on the bins.
G
Grumblebum
GB,
Bob
Lol, there is some amounts of label printing in my future RM. I actually like this model tray (same brand/size as before) better now that I've played with them - it's a bit more refined.
Kirk, I hear you - I was only barely looking in here between end of November and about March. Once you get behind it takes forever to get caught up again.
Ditto G. You got away in the camper at least so that is good :thumbup:
We can make you one on castors. Lots of labeling to do. Just on the benches now there are 24 organizer trays, 44 trays in the grey plastic organizers, and 65 trays in the black/metal small parts organizers. Wow, that's the first time I've counted that.
Started on a small project tonight (more about it tomorrow'ish). Same as the pencil cases I made before just a bit deeper.
View media item 83080
And started on this cupboard, this has been the hardware cupboard since I setup this area so is a pain to get out what I need. The new trays will really help with this (I hope :dunno:). It's about 2' deep into that back corner.
View media item 83079
Almost Saturday :rocker:
GB
G
Grumblebum
The wooden pencil cases I made around Xmas time happened to be the correct dimension length and width wise to suit the doterra essential oils that wifie is into (they are actually pretty good and great to use in a water diffuser at night). So for Mother's Day I just made a couple a bit deeper to accommodate the height of the vials.
6mm marine ply scrap that I rescued from the office skip, and a few coats of water based polyurethane.
View media item 83095
14 vials fit perfectly :thumbup:
View media item 83096
Cheers GB :beer:
anth
Australia
Great work! Love the organiser shelf/rack.
Ahh Doterra, great in theory, until you happen to check the bank statement and think of all the tools you could have bought with what they sting you for tiny little bottles of ointment!
oldironfarmer
Terlton, Oklahoma
I'm not much on snake oil, but my wife was getting unable to walk even with her walker, knees popping loudly. Doctors offered no help. Essential oils relieve the popping and makes her mobile. Price is not an issue.
G
Grumblebum
GB you have scored some points there well done.:thumbup:
Thanks 1/2 Cup, points were scored :) and it was a good mothers day.
There you go making the rest of us look bad.:thumbup:
Perhaps :headscrat Andy but I can't do casting and blacksmithing - at least not yet :bounce:
Thanks anth. Let's just say I don't question wifie's purchases and she doesn't question mine :lol:
I use the doterra "ice blue" cream/ointment on my back from time to time and it works a treat. We've have good success with the oils in the vaporizers - especially for the kids when they get the sniffles or can't get to sleep.
OIF and G, I think seeing anyone who you care about in pain is awful, and yes you tend to try "other" things to help them.
Terrick, I agree mate.
All, knocked this out today. Used some old decking board offcuts that I've had under the house for probably 10 years. And a bit of pegboard offcut.
View media item 83176
View media item 83177
The boards are 22mm thick, so had I gone 1/2" ply or similar I should have been able to get a neat 4 cans wide I think. Might do another one dedicated to spray can storage later on and keep this one for lube cans etc. (and no the glitter cans are not mine)
View media item 83178
Now have somewhere to hang some garage trinkets :beer:
View media item 83179
Still needs to be sanded and painted, but at least it's functional for now.
Cheers GB.
G
Grumblebum
Thanks for the comments guys. Sorry it's been a while since last updates. Life and work and all that...I've been slowly trying to get caught up on my subscribed threads again.
It's starting to get a spring feeling in the weather already, so have the garage door up and been starting to get a bit of tidy up done. If I can get all the horizontal surface areas back to normal after this weekend I'll be happy as the garage has pretty much reverted to a dumping ground over the last couple of months.
I have surplus to my needs a Black & Decker 1600W heat gun if anyone can use it. It's brand new in the case but has been sitting in a shed for several years, I've just wiped the dust off the case and given it a quick test run. PM me your address if interested and I'll pop it in the post.
View media item 85789
Have had a couple of scores that were managed though my BIL. Basically a gentleman who was known through my family passed away and his shed had to be emptied out as his wife (in her 80's) was selling the property and moving on.
We were able to save and old Aussie made (HR Cousens Castle Hill Sydney) table saw, bench drill and radial arm saw and a second Ryobi radial arm saw. I believe the gentleman had used these to make a number of church pews along with several buildings in the area he lived including a nursing home back in the day.
So basically we saved these items from going to the dumpster, the gentleman's son was not interested. All equipment works it just needs a bit of TLC restoration. The old radial arm saw sounds so quiet and smooth they don't make them like that anymore for sure. Dad and I are thinking of setting up a 20' shipping container as a small wood shop on his property (the sheds are all full lol). Pics at a later date.
Ok back to getting some jobs done.
Have a good weekend GB :beer2:
shortykorte
Tallahassee, Fl
Looking good all around. Seems we’ve been in the same busy boat. You’re going to like having the bin storage. Are you using a Mac Mini? That’s what I have for a desktop.
I see the one wall needs some painting in the future. Might I suggest trading out your paint duties with Gerard’s need for labels?
I like the vise brake. Used my last weekend. Can you post a pic of the blue brake and how it’s mounted? I’d like to get a shear like that.
