dlcwent
Member Emeritus
Rod, I assume that is NOT a biting insect?? Ugly little thing ( unless you're another Green Grocer Cicada)
Good luck on the QST this coming weekend.
And summer is here. Found this Green Grocer Cicada out the back the other morning.
View media item 65488
Cheers GB.
GB, you are in for a treat this summer. That insulation will make a huge difference. When the outside air temperature is 32*C (90*F), my white steel garage doors that face west have a surface temperature of 57*C (135*F). With 2-inch foam panels installed, the inside temperature stays cooler than the outside air temperature for most of the afternoon.Once it's all in I'll fully re-adjust the door to counter for the extra weight. Also curious as to why the door does not have a stiffener on the second from bottom panel, anyone else with a panel door have all panels with stiffeners ? Might look into getting one for that panel as it will hold the insulation in.
Cheers GB.![]()
GB, when I re-did the kitchen in our last house, I used Formica laminate. For the countertops I used 1/16-inch laminate and for the cabinet doors and frames I used 1/32-inch laminate. It's available in 4-foot wide and 5-foot wide sheets in 8- 10- and 12-foot lengths. I used a carbide-tipped scoring tool to scribe a line through the face of the laminate and snap the sheet. A little file work and it was good to go. WARNING - when laminate breaks, it leaves an edge that is sharper than a razor so don't skip the filing.I was thinking of covering with 3mm (1/8") melamine laminated mdf panels unless I can find some vinyl panels or something. Only thing is all the horizontal panels are over 1200mm (4') wide, so just over the standard size sheets to rip down which will just mean more waste as I can only cut 2 panel sections from an 8x4 sheet.
Nice one mate, should make a huge difference. My door is north facing but still cops a lot of heat in the afternoon. Unfortunately, being a roller door, my options for insulation are greatly reduced (and more expensive!)
Looks great GB. Maybe you should leave it uncovered. I suppose it'd add a lot of light And yeah Terrick, let's see a little more of that machine.
GB: so you moved your big mill and shop stuff to put in a play area for your little ones? you just chalked up more DAD OF THE YEAR POINTS that is for certain. they are only little once and when you move your stuff back in it's place maybe you'll have an assistant in the garage wanting to learn and help.
Yes today it was about 30C (86F). I did a quick and dirty measurement between outside the door and inside and about 3 degrees cooler inside - but noticably more comfortable and did not have the "baking" sensation. The foil on the insulation was warm to the touch where as the steel door panels was hot at 40C (104F) so it's definitely working and reducing the radiated heat.the insulation looks great and can you tell a difference already inside your garage besides the added light from the reflection?
Looks great all finished!!
Anth, I have the same issue..................a roller door x 2
Looks great GB..
Regards
Hey guys, of you that have a roller door, we hung that foil coated bubble wrap on the inside of thick hessian carpet underlay. You just have to be careful because the door gets bigger when you roll it up!
When setting the length you will notice that when rolling it up the underlay will hang down about 6 inches when the door is up, just one of those maths things. It did not worry us at the time because the door opening was 10' high.
Maybe the foil wrap will be enough for you.???
Guys, I was looking at mine roller door last night and its going to be quite a challenge to insulate it..
Regards
1/2 Cup,
You may want to look at paints or coatings to keep application thin but still get some reduction in heat transfer through the door. Not sure if anyone makes affordable coatings for the home owner but any reduction in thermal transfer and increased reflection on the out side would help. The other thought is possibly some sort of retractable awning that could be lowered when sun angle is at its worst to shade the door from direct sun load.
rmalkow, I really need to do a bit of research on this one.
Thanks for the tip..
An awning is a distinct possibility as well.
Regards
Great job on the garage door![]()
Grumblebums
"An iced nip of scotch, some classic old Kreator on the ipad player thingy and a roll of this stuff..."
I never took you for a heavy metal guy? Kreator![]()
Nothing like a challenge. Thermal coating is a good idea as is the awning.
How does one adjust a roller door to balance the extra weight ? I don't ever recall seeing a tensioner on one.
GB, my doors have a spring to adjust the tension. The issue I have is clearance when its fully up, it will take some fiddling to get that right.
Regards
For the rollup doors, I think rmalkow2 is on the right track. LizardSkin makes a spray-on thermal insulation commonly used in the automotive field. It's a water-based coating that can be sprayed with a bed-liner gun and it's sold through lots of outlets, including Summit Racing. They make it in black or white. White would be my choice for the inside of a garage door.
https://www.summitracing.com/parts/liz-13012/overview/
There's also a thermal spray company doing business in Australia. Their web site doesn't mention using their products on roll-up doors but it might be a good place to start.
http://www.thermatec.com.au/
Sorry to hijack your thread GB, but since we're on the subject of roller doors, I thought I'd chime in again. Last year during summer I did some research and found that an aussie company (we're a cluey bunch) has patented a roller door insulation product. I got a quote at just under $300 +postage for my door, which is 5m wide and probably about 3m tall. That price included everything needed for a DIY installation, too.
http://www.allinsulation.com.au/garage-door-insulation/
Naturally, after a lot of umming and ahhing, the weather cooled down and I didn't go ahead with it, but now that it's heating up I'm thinking about it again (funny how that works!) One thing that is stopping me (apart from my bank account), is that I'm wondering if I should spend the same amount of money on a 5m x 5m canvas sail over the driveway, which might have similar results by taking direct sun off the roller door, and also give me a shady place to wash the car?
Lyndon, the blue underlined bold words are all the links to the relevant sites - took ages to do that on the iPad
30mm was $25 a sheet of which I ordered 4 sheets. You are welcome to steal a sheet to play with if you like. I guess you will do your kinchrome box with it ?
Would the plastic Amazon tray set be too "light duty" for drill bits ?
GB.
I'm in this boat as well, my roller doors face north east and get blazing hot on a summers day until a bit after midday... But if the price wasn't too much more and i could make it aesthetically pleasing then I think I'm inclined to install a carport in front of the garage instead. 2 birds 1 stone, or something like that? I quite like your canvas sail idea too anth...
