MongoTom
We rebuilt our garage in 2012 (www.garagejournal.com/forum/showthread.php?t=130860 and http://www.garagejournal.com/forum/showthread.php?t=160397) and have since added a four post lift.
This last December we finally added the boiler and now have heat. The system looks like this:
If that link doesn't work, you can go here to see the photo or download it in full size: https://tomsnewgarage.shutterfly.com/pictures/71
I wanted simple, so it's an electric system, not gas. The boiler is an Electro Mini-Boiler Radiant Series, model EMB-S-5, 240v, 4500 watts, 15000 BTU. The garage is 25X25 inside, with 2X6 construction and open cell foam insulation. There's 2" of insulation under the floor.
So, you want to know the facts. What did it cost to build, does it do the job and what does it cost to run? With assistance from someone who knew what they were doing, it cost me a bit under $3,000. I have the thermostat set to keep the slab between 55 and 60 degrees. The boiler is set at it's lowest setting or 90 degree maximum. At those settings, the air temp in the garage has remained in the 50's and it's quite comfortable when working in just coveralls. This has been the coldest, nastiest winter in the 30+ years that I've lived in Ann Arbor. Many days in single digits, and many wind chills far below zero. Our gas bill was 30% greater than a year ago at this time and was the highest we've ever seen. It's been cold! As cold as I hope any month ever gets here. So, how much to run it? My electric bill for the last month was $390 and that was 142% higher than a year ago (maybe $160?). I figure for this one awful month, it cost me a bit over $200 to run. Barring the start of another ice age, that should be the worst case scenario.
Am I happy with it? Absolutely. Would I do anything differently? I don't think so. Let me know if I've left out any important information or if you want to know more about the system.
