555
I've only done it once and used a battery charger and a plastic tub like nearly everyone else. It did a nice job but was a very slow process. I've had better luck removing rust with vinegar.
I wish we were closer, I'd be happy to see you get it..... Doc: i still love that Parker with the swiveling dynamic jaw. i've never seen one in person so if you want to put it in your suitcase i'll buy lunch and beverages if you show up at my door with it.
cheers
Maybe dumb question, couldn't go through all the pages of this post. I have a lot of steel C-channel which I think will make excellent anodes. Question, should I remove the blackish finish of these steel pieces? Believe its an oxide finish, not sure.
IMG_1205 by don long, on Flickr
IMG_1182 by don long, on Flickr
IMG_1204 by don long, on FlickrDon't keep going. After all the rust is gone it will start damaging the metal. The bubbles will keep going as long as you have voltage and an electrolyte.Hi all
I have in the past used other methods of de-rusting but now for the first time I am trying electrolysis. I am using the recommended rebar and Arm & Hammer Super Washing Soda, 12V 2 Amp etc. All is going well but I am not sure how long each piece needs to be processed.
I guess this is a loaded question as obviously the length of time depends on how bad the corrosion is. In my case (a 50lb Reed 204 vise manufactured around 1914) it appeared to be just surface rust (see photo). I first processed the vise static jaw housing for like 6 hours last night which after rinsing it looked reasonably clean and free of rust. I then dried and left it over night.
This morning in day light I noticed there were few spots that could do with some more processing. So I started with a new solution and to my amazement after 7 hours now, still rusty crud/scum seems to be bubbling up to the top.
I really want to get going and I have not even gotten to the dynamic jaw/bar and swivel base and screw etc. At this rate it will take 3-4 days or may be even longer.
Is there any good indicator (eg no more bubbles or the amps drop to near zero, etc) when a piece is done? Am I over doing it?
Thx much in advance for any advice
007
If you are not getting all the rust it could be the orientation of the anodes.
Sent from my SM-G900T using Tapatalk
Fretters, it's good to see you back.It won't cause any damage to the metal, regardless of how long it's in there.
Gman', most of the rust you see in the solution is from the anodes. The process is finished when you decide you're happy with the result.
I will take your word for it about the damage or lack of. I am basing it on what I saw on a pipe wrench (Stilson) which accidentally got left for a week or so.
Well 1st off, I use carbon electrodes, and things always look black as the ace of spades anyway when they come out. But in this case they were also covered with what looked like lesions, sort of like you get on aluminium when it is getting corroded. As for the current, well it started off about 1 amp, but apparently someone knocked off the connections accidentally and re-connected the way they thought it was. So it's possible that polarity was reversed for a day or two. Then he disconnected again when I didn't show up for a couple more days. Anyway the clips were in about the right areas when I got there, ie positive and negative close to the correct places on my lash up.Cheers.Did you happen to turn the supply off? What happened to the Stilson you left in there? Curiosity has me now.
Even with no current passing, an alkaline solution should keep the piece fairly safe.
I use a lightbulb in series with the power supply to limit the current, so even a dead short can do no harm.
Sent from my SM-G930T using Tapatalk
I don't recall right now, but I think it is just a sidelight or turn signal bulb.Interesting idea!
What are the specs on the bulb you use? It obviously can't have too much resistance or your current flow through the tank would drop substantially.
I tried a few until I got an acceptable current.
You may want to reconsider the SS for an Anode:
Done right electrolysis is safe and procures NO haz Waste or hexavalent waste. If you want a "Clean" anode use graphite. Available cheaply...
Galvanized puts off toxic stuff. I wouldn't use it. Plain ole bailing wire or coathanger shoud do the trickSo I’m getting ready to do a project. I set up my tank and have my solution ready. Then I realized the om
Nay wire I have to hang my rusty object with is galvanized wire. Is this going to be an issue? I was hoping to save myself a trip to the store.
Sent from my hammer and chisel using Tapatalk
