How do I cut bottom plate flush with drywall?
Daniel Dudley
I painted to match the floor, and put the baseboard over it. Looks fine. A lot of guys would cut that with a sawzall and have no problem. Trust me when I tell you I had no problem wielding a paintbrush. It hasn't been a problem for me. If I wasn't handy with a sawzall, I'd get a flush cut saw and a Multi tool to finish, If it wouldn't split off.
gungatim
west mich
You guys evidently never owned a sawzall. They can't cut flush to anything.
maybe a sawzall doesn't, but my craftsman version does. you can mount the blade on the outside for cutting flush. not to mention a very long blade is flexible enough to cut flush if you hold it properly and put a bend in it. have done this many times doing the same thing as the OP.
flat350
illinois
They do make offset adapters and offset flush cut blades for recip. saws that give you lots of different options with blades.
bullnerd
Jersey
No way anyone here can cut that with a sawzall and not eff up the drywall!
No way, nope. I have done it 10,000 times and you guys just don't have the skill, just forget about it. I know all about all this stuff.
tthornto
I agree, using a sawzall even with one of those flush cut adapter would tear up at least a little bit of drywall. But if you hold the saw almost horizontal with only a slight angle the portion of drywall that it messes up will be hidden behind the baseboard where it will never be seen.
ScottsGT
Lake Wateree, SC
Biscuit cutter with the depth set just enough to almost cut all the way through. Either make 87,000 plunges, or lock it and drag it.
But I would just stack trim up and keep it. That way no rolling tools can run through the sheetrock. Or just wainscot the garage with 3/4' ply and smaller trim at the bottom.
MoonRise
I'd say just leave the bottom plate alone.
Take some 1x or 2x (whatever thickness is needed) and mount it to the drywall above the bottom plate, mount your 1x4 baseboard to that 1x/2x, add some molding (quarter round, or whatever) on top of your 'thick' looking baseboard, done.
Or take some 2x, route or cut a rabbet to clear the 'proud' bottom plate, install the 2x as the baseboard. Route a 'fancy' edge on the top of the 2x before installation if desired. Done.
PelicanPines
Don’t cut any of it , put a 1x2 on the drywall above the plate that sticks out, then a 1x4 over that on floor. Leaves a larger ledge but could look okay in a garage. You could also put a 1/2” reveal between the two base boards for a different look. Beats cutting the plate.
PC Custom you beat me!
This... avoids the moisture etc...
DFB
Southern VT/Western Mass
Does anyone know of a toe kick saw that can cut 1.5" depth?
You can do it with that 3/4 cut Toe Kick saw just not all at once
Make a side cut the depth of the blade 3/4 down from the top edge then a top cut 3/4 in and remove that piece
Then another 3/4 deep top cut should remove the bottom piece that's left
Then repeat until you get to the wall :D
Like I said more work than I want to do :thumbup:
There actually are other multi toothed saw blades for angle grinders drill chuck arbors to use on wood similar to that chainsaw blade.
Can't say I have EVER seen anyone use one though
A bunch of them on Ebay
Cheap enough too :wtf:
https://www.ebay.com/sch/sis.html?_...l Power Tool 110MM 28T&_id=352032670648&rt=nc
Colin Len
Long Beach CA
I would use a 2x4 and notch out one edge to fit over the plate. you can use a dado blade for this or maybe a router. I would then cut the top outside edge at a 45.
Jay D.
I like this idea, although perhaps with a 2x6 for a slightly taller base molding when it's finished. Might have to do that in my garage when I get around to redoing the drywall since I have this same issue of 2x6 sill plate + 2x4 walls (house was built in 1942).
dfiler2
NW Minnesota
Galvanized metal wainscoting would even it out, I believe cutting it would be a pain and has the potential to cause other problems.
RTBS
UT
Bosch makes a flush cut trim saw that might work6a2c93b4b37e45429fdca9172fe2f0a3.jpg
the gypsy
Montreal, Quebec, Canada
Maybe multiple cuts with a circular saw similar to cutting dadoes set at the proper depth. laying on its' side. But not to destroy your saw You should use some kind of wood spacer as a sled. Use different thickness wood to raise the saw off the floor and and clean the rest with a chisel and route the rough work with an offset router base. Just thinking out loud...
N.B. I think this is an awful lot of work. Knowing myself I would buy the offset saw mentioned previously on one of the posts.
egdede
I can plunge cut with a sawzall but typically that is done with what you are cutting being elevated on saw horses or something of that sort. There is concrete underneath. You must have a much steadier hand than me to think it would be "easy peasy" to plunge cut 100 linear foot directly on top of concrete while at an angle to clear the drywall.
The flexed blade is flat against the wall. The wall serves as the guide. The hardest part is learning how to penetrate such that the blade skims along the top of the concrete; plunging too deep causes chatter and a crooked cut. I must admit, I do make it look easy!
johnyg
boca raton fl
sometimes if you cant find the right tool to do something its because it should not be done.build it up and forget about it.
NUTTSGT
Northern Central Ohio
Well if you are intent on doing it, I think maybe an old school cross cut saw (think lumberjack saw) would cut a section at a time. You could put a piece of sheet metal against the drywall to protect it as you cut.
Do a few feet at a time and move along the wall as you go. I think the length of the saw and it would be flexible enough to get it done yet cut fairly straight.
BADSIX
oregon coast
yep, a 2x6 would be a good choice
Jay D.
P
pedaltheglobe
Makes no logical sense. I'm simply ripping a 2x6 down to a 2x4 or 2x5. Most buildings have a 2x4 sill plate. By your logic they are all built incorrectly. Many tool options have already been mentioned. Thanks everyone!
cdestuck
Altoona, Pa
Makes no logical sense. I'm simply ripping a 2x6 down to a 2x or 2x5. Most buildings have a 2x4 sill plate. By your logic they are all built incorrectly. Many tool options have already been mentioned. Thanks everyone!
A lot of ideas and jibber grabber here. You have to let us know what you do and perhaps some pics
straps57
Good call except go with a rip saw. Cross cut is for against the grain.
wrenchguy
NW Indiana
so whats next???? u got a anchor bolt in the way? good luck with ur project.
P
pedaltheglobe
Yea because its typical for sill plates to be anchored at their edge and not their center [emoji23][emoji23]🤣
I will post a few pics when the project is finished.
Sent from my SAMSUNG-SM-N920A using Tapatalk
andrewordrew
Atlanta, Georgia, USA
This thread is great reading. I envision a nation of people dead-set that their way is best. Every possible outcome is realized...
One dude is sitting in tattered lawn chair with no shirt on staring at the problem.
One dude is just beating the **** out of the problem with dull tools.
Another person has already trimmed it twice over with preprimed 1x and is on to the next project.
Another person is quarter-sawing white oak (for the moisture resilience, natch) and will have it finished like a fine bungalow in 2 months.
Then there’s me, sitting around doing nothing and laughing about how the world does or doesn’t use a sawzall.
God Bless America.
manwithtools
Lebanon, TN
God Bless America.
This is why we need a like button.....:thumbup::thumbup::thumbup:
rayra
Escaped from Los Angeles
Because it will look like excrement if you try and cut it in place.
The easiest tool would have been to cut the stock down to the thickness of the drywall using a table saw, before mounting it. But if you have water trouble you shouldn't be putting even pressure treated down against the floor and then drywall in contact above it. It's going to wick. The whole idea of such a 'baseboard' install should be to use something that won't take water. or deliberately leaving a gap between the drywall and the water-wicking 'baseboard'
'pressure treated' lumber isn't a water-proofing. It's a poison against insects and mold.
johnyg
boca raton fl
by my logic a 2x4 is used for the sill and not a 2x6 to be trimmed later.if the latter was true im sure there would be a sill trimming saw to do this.dont mean to be pissy but when i saw that chain saw disc thing it was just wrong.desperate times call for desperate measures,but not a chain saw against concrete. im sure you could have already built up a nice base board by now and not endangered yourself.
AZ Pete
Central Arizona
those blades will still not make a flush cut because of the arbor nut. A biscuit saw will not cut flush either. Just trim it out with a 1"x and save all of the aggravation.
DFB
If that's the case one could just relief the back of the trim board to clear what was little protrusion was left
But I whole heartedly agree save the aggravation and just trim it out as it stands :thumbup:
