Guess I better bring it up since no one else has. What about the Instinct Diamond tip screwdrivers? Only a few bucks more than ACRs and …. Made in Czech Republic I think.
I have the tips for my ratcheting drivers. Pretty great, but haven’t had enough use to say for sure. Not sure I care for hex shanks.
I’m never sure about the Diamond tips.
Max Baumann (of P B Baumann / P B Swiss) told me that he had done a lot of tests with these. When new, they are really effective, but quickly become less so.
Viewed under an electron microscope, he could see that the diamonds protrude when new, giving the grip. With use, they get pushed into the steel, and twisted till the flat part of the stone faces out, hence become less effective.
If you like diamond drivers then the Snap On is obviously a Wera “Kraftform Diamant” blade, with an Instinct handle. If you’re not getting a Snap On blade you might as well just buy the Wera.
If you go with the view that the diamonds work when new, then one option is to get some of the fluid that adds grip. This usually contains small industrial diamonds suspended in an oil.
I bought some of this (maker now unknown as the label came off) years ago at a shooting show. It really does work, and I don’t know why it’s not better known outside engineering / defence circles.
Edit - think it was this. The bottle is the same.
Another option would be to go for the Vessel “Jawsfit” which also seem to increase grip considerably. Mine have not worn yet!
