How do you store your funnels?
mroneeyedboh
Im looking for a new way to store funnels. I sued to keep a rag in them to keep dust out and help draining, but wondering if there is a different way?
bcoke
Pawlet Vermont
I went back and looked at some of these and needto make one myself.....looking at wood shelf with different size holes with a pvc piping system to a container....simple like all the others but most seem to be annoyed about keeping out the DUST and DEBREE of a shop for that I use the BOWL COVERS found in the saran / plastic wrap areas in supermarkets, dollar stores etc. they look like old fashion rain or shower caps a plastic circle with an elastic band and come in different sizes to fit different size "bowls" [funnels]. easy on and off......done
404
Mass
<del></del>I keep mine in a <del>sandblasting</del> file cabinet. Wash out before each use.
<del></del>
jdl25
I throw them on a shelf and clean them every stinking time I need to put new fluid in something. I guess I should follow this thread.
T_R
Maine
I put the oil funnel in my oil bucket, trans funnel in my trans bucket etc. Our shop has the hanging dispensers and you have to walk over with a bucket to get fluids. Makes sense to just stick the funnel in the bucket.
soj
North Georgia
I keep mine in a huge plastic bag to keep them clean. The bag stays clean inside 'cause I rinse the funnels in the parts washer and wipe 'em dry before I put 'em back in the bag.
jp
brownbagg
I got a wooden dowel stuck in the wall that i slip them over, if oil drips on the slab, well its a garage
stage20
pcola FL
5 gallon bucket. rag in the bottom and a rag in the top of each funnel. serves 2 purposes. holds leaking oil until you get the funnel back in the bucket, then i shove the rag in the top of the funnel to keep dust and dirt out of the funnel. quick shake of the rag and the funnel is ready to go. repeat the process.
RVDan
North America
I usually leave it on the floor and forget about it until I step on it and break it. Then I walk to the dollar store and get one next time I need one.
404
Mass
And we have a winner!:beer:
cdestuck
Altoona, Pa
I hang mine inside the trash can for a day. Then have a wood holder made that I best them inside each other with the bottom one having a wad of paper towel in to **** up any lasting drips
moriboy
Oregon
I put them in a clean garbage bag and throw them on the shelf. Not the the most professional way to store, but they are clean every time I use them. It really bothers me to dump oil in something not knowing if a chunk of something goes in with it.
DTE
North Carolina
We had a laundry tub with a piece of screen about 3 in. from the bottom and just tossed them in there. And then you would have some custom blend for the beaters, any oil is better than no oil !
lonestarky
Lindenhurst IL
Wad up a paper towel and close lightly in the vice with the tip of the funnel inside. Two shots of degreaser. Next day after its drained, into a cut off washer fluid container upside down. Good enough for me.
Sent from my XT1254 using Tapatalk
G-Ram
NWO
A washer fluid jug with the top cut off houses numerous funnels at my shop. A quick shot of brake clean and wipe with a rag and they're clean enough for the girls I go for...
mjoekingz28
Mississippi
Distilled water and a paper shop towel......maybe a shot of car soap....
Is more required?
The tough ones are the small ones that you can't push a paper towel through.
jkwilson
SW Indiana
I keep them in a plastic tote sitting in sections of PVC pipe to drain. I use what collects at the bottom (mix of diesel, oil, ATF, grease) to lubricate farm gates.
vetron
Idaho
i keep my oil changing 'stuff' in a kitty litter bucket. so no worry when a little bit spills out of the funnel. of course when you have 3 cats you have to find uses for lots of kitty litter buckets!
also keep the car wash stuff in one, scrap metal in another, car parts in another, kids counseling fund change in another........
SteveCh
I have to find one of my 300 funnels before I am able to actually use one.
dclassical
I wipe them and then put them on the (small) stack of funnels I have and into an empty old bottle of engine oil. Not the most stable but I only have 5 funnels, so it works for me.
atavuss
I put the funnel in a empty one gallon oil container and use an old coffee can lid to cover the top of the funnel so dirt does not get in.
GN4WHLN
Alta Loma, CA
Quick spray with Purple stuff, water rinse, wipe out with a paper towel and store in a plastic container. They are clean and contaminate free when I need one again.
brycez28
Sheboygan, Wisconsin
I store mine in a larger, cheap plastic tool box. The funnels that are dedicated for oil/transmission fluid are in gallon sized ziplock bags. I put a clean or lightly used shop ran in the funnels when put away.
MushCreek
Upstate South Carolina
I remember one place I worked, the maintenance guy used to keep a 5 gallon bucket of way oil in the grinding room, with about 25 surface grinders in use. He kept the funnel, facing up, in the bucket. It would sit there and accumulate grinding dust for a few weeks, then he would use the funnel to oil up the machines. He never cleaned the grinding dust out of the funnel!
C_F
Utah...SNOW BLOWS!
I wipe mine off, then stack them pointy end up, small to large & leave a rag on top. I only have five, though.
coljar
Belpre, Ohio
I stick them in the holes of the storm drain outside and let the rain water wash them clean to the street...................
I have holes cut in the top of a 5 gal. bucket lid and let them drip in it.
