How many ratchets do you own?
shop guy
London, Ontario
Give it time, you've only been here a few months. This place will cause you to go out and buy more tools, a bigger tool box and want a bigger garage. It happens to us all.
Yeah, no doubt. I've already upgraded a few things since joining this site. It kind of goes against my normal personality, I'm the type of guy to use the same old tool or fishing rod or whatever until it can't be used anymore. However I find myself wanting some nicer ratchets after browsing these threads haha.
Duct Tape Man
Shenandoah Valley, VA
I gathered up the ones I have at home and in the garage, turns out I have 38 ratchets here. I have about 25 at work, so maybe 63 or so. Pictured:
3 ea Armstrong: 1 x 1/2-drive, 1 x 3/8-drive, and 1 x 1/4-drive
12 ea Craftsman: 4 x 1/2-drive, 6 x 3/8-drive, 1 x 3/8-drive stubby, and 1 x 1/4-drive
2 ea Crescent: 1 x 1/2-drive, and 1 x 3/8-drive
1 ea Duro: 1 x 3/8 drive
1 ea Husky: 1 x 3/8-drive
1 ea Indestro: 1 x 1/2-drive
1 ea MAC: 1 x 3/8-drive
1 ea Plomb: 1 x 1/2-drive
3 ea Powr-Kraft: 1 x 1/2-drive long handle, 1 x 1/2-drive, and 1 x 3/8-drive
6 ea Proto: 1 x 1/2-drive long handle, 1 x 1/2-drive, 2 x 3/8-drive, 1 x 1/4-drive, and 1 x 5449D dogleg military 1/2-female-drive ratchet
2 ea S-K: 1 x 1/2-drive, 1 x 3/8-drive
1 ea S-K Wayne: 1 x 3/8-drive
1 ea Snap-On: 1 x 3/8-drive
1 ea Williams: 1 x 3/8-drive
1 ea Wright: 1 x 3/8-drive
1 ea unknown-as-of-yet 1/2-female-drive
pi_guy
N/A
Three threads have been merged into one thread now.
No posts have been deleted in doing so except my own that I used to mark the threads for merging.
I see that now, sorry.
Just had my knee replaced with titanium parts less than two weeks ago and could blame the meds.
Not allowed to do work or move weight use power tools or drive I have been checking those things off since I got home.
2oolhound
BC Canada
Thanks for merging these threads Eric!!!
and a job well done. Much appreciated!
Titanium huh? but can it ratchet?
pi_guy
N/A
I am up to 3 questions for the doctor?
What size hammer did you use to pound the parts.
Did you pre drill the hole before you put in parts?
What grit or cutting tool did you use to size bone to fit part.
JuliusPepperwood
California
At work I have,
3x 1/2, craftsman standard and snap on ratchets, 24" and 15"
3x 3/8 ratchets, snap on stubby, snap on fl80, and a standard craftsman
2x 1/4, a duralast flex head and a craftsman
At home I have,
1x 1/2 ratchet, HF standard,
1x 3/8, duralast standard
1x 1/4 craftsman standard
At work I mostly use power tools but My snap on 3/8 stubby is my favorite.
At home my duralast gets used the most, very good ratchet.
rt dak
Putnam County, NY
Like most here, more than I need.
02Xterra
Lynchburg, Va
When I joined this forum in late '15 I had one ratchet.. the bent handle craftsman on the right. Thanks GJ! Haha
Sent from my VS986 using Tapatalk
48548
Phoenix
The Armstrong's look great....
See, my count is not even 14 years worth at your rate! And I've been buying them... well; for a LONG time! (Possibly longer than you have been alive...)
DGersic
DeKalb, IL
Quick mental count says 9.
4 - 1/4". 3 of them are Craftsman and came as part of a set. One SO I found on the road.
4 - 3/8". 3 Craftsman, two in the garage, one in the basement, because I hate moving tools between shop areas. One Sidewinder, which is not a great ratchet, but is handy as an angle drive T handle.
1 - 1/2" Craftsman.
Non pro, weekend wrencher. Definitely not a collector. I like tools, but I buy them to use, not to look at.
Jd34
Every one of those brands you mentioned should be able to be exchanged at the store... If it's a USA craftsman you can probably find a rebuild kit on eBay.
I didnt know about rebuild kits. Much appreciate that tid bit of info. Several of my craftsman ratchets are hand me downs from my late father so no way would I want to turn them in and exchange them for new ones.
Thanks again! :thumbup:
I have several ratchets from different makers (craftsman, master craft, Pittsburgh , kobalt ect... )but I just wished they would halfway work. I have worn them down and they slip a lot- very frustrating.
I need new ones :(
Also, the often only need a cleaning and an appropriate lube (Fine tooth gears don't like heavier greases, the old 24 tooth ratchets were fine with..)
EOC_Jason
Bentonville, AR
Yeah, like Outlaw said, you might want to open them up and take a look inside. Often they are just gunked up and need to be cleaned & re-lubed. The teeth / pawl do get worn if used a ton and that's what the rebuild kits are for. Out of my 30+ ratchets I've had maybe 3 that needed actual rebuilds... And those were from estate sales where the guys were mechanics that used them daily I'm sure.
If you have a Sears Hometown or Sears Hardware (the smaller independently owned stores), you can try talking to the owner and see if they still have any rebuild kits in the back. Many of them kept them instead of tossing them out as per Sears directive.
Finky198
North East
Tell me about it...
I just looked thru the pages in my 06/15 post I listed 11 total. My recent post 22 in total :D
Yes this place has an serious effect... :spit: And your right about it too a T. Cause the shop and box got bigger as well... It's all good. :evil:
ARAMP1
Memphis, TN
Your bright & shiny chrome ratchets are being dulled by those old, un-finished ratchets. Please send all Plomb ratchets to me for proper disposal.
Brian
I have several 1/2" drive Plomb ratchets and decided to powdercoat one during the last rebuild. It came out pretty good. It's pretty hard to get a good picture of it with the shine.
Tonyuk
Scotland
God knows where you all find the space to store that many ratchets, i have 10 max;
4 @ 1/2"
3 @ 3/8"
3 @ 1/4"
And some of them haven't been used in years.
Sam'sAutoParts
Northeast PA
Here is my work box with my ratchets, I actually counted 18 with the 3/4" drive that isn't pictured. I also have to two wrenches that I don't count.
There is 11 stuffed into this drawer, I know someone's OCD is going to hit dangerous levels...I'm almost there but I need a bigger box.
Only six in the socket drawer, just my most used in here, although my go to 1/4 is a TL72 that is in the other drawer. I really like the 1/4" SK in certain situations.
Yammie
Sarasota, FL
Rebuild kits are often available for free at Sears, especially if you run into an older person in the hardware department. If they're busy - and even if they're not - I offer to rebuild the ratchet myself. They're usually VERY happy to have you volunteer!
r_olson_06
SD
Between 8 and 9 hundred is my best guesstimate.
Lots of dupes. Still too many I don't have, even common ones.
You have to do a couple group photos. I bet you can't they them all in 1 picture.
Sent from my XT1080 using Tapatalk
bsg1
so cal
10 ratchets, 1 breaker bar, 1 bit ratchet, 1 cordless ratchet
Looking to add 1 more
I very much understand looking to add 1 more. I've been looking to add 1 more many times over for quite a few years now.
Cummins_Tech
9, at work. Mostly SO, 2 72s, 2 F series and 2 S series, fixed and flex for each, 1 proto 1/2" for when I have to beat on stuff, 1 proto 3/4, and one 1/2" USA Craftsman I kinda just keep as a backup. Haven't NEEDED much more than that at work.
fatfillup
Finksburg, Md
PowderKeg who is a ratchet collector was in the area yesterday and bought 2 from me. Its the 3rd time he has been here and has left with a couple of new specimens each time.
