How to remove broken exhaust manifold bolt
Burt Shaver
Iroquois, Ontario Canada
You're not going to get anything hot enough with a Mig pak 140 to do any damage.
You're smart to weld the flat washer in first since there is some distance between the surface and the stud.
I would be filling that gap from the top of the broken stud to the surface first, and then the washer? Correct
Burt Shaver
This is why you should break free one bolt and then retighten it, then break free the next and retighten it and repeat until all have been broken free then loosing them similar to a torque sequence.
Take them all out the last one will alwas break.
Especially on exhaust manifolds.
I did crack them in sequence. Reverse of tightening sequence. Still broke 3 of them. I think 2 of them might have already been broken
no704
OP says 3 bolts broke, how does your logic apply?
Not saying it would work every time, just a good practice. And of course a good soak with your favorite penetrating oil before hand. Also a good practice to tighten the bolt before trying to back it out. Very dependent on case by case. Just suggesting practices that might help others avoid posting this same question.
Burt Shaver
After re reading your post, I get it now. That’s a real good idea
no704
But did you retighten the others? Sometimes this is unavoidable, especially with rust, I’m just posting to potentially help others in this situation. For what you have I would recommend taking the head to a machinist as you already have the head off. I would try the welding approach, especially with an Al head as the steel weld should not stick to the Al head. Ya might want to coat the area around the weld with some anti splatter spray or even just some Pam cooking spray. Unless you’re very confident in your skills, do not use an EZ-out bolt extrater as it’s much more difficult to remove after you break it off in the hole.
partsguy5768
Many bolts are already broke off before you put a wrench on them. Aluminum heads with cast or steel manifolds equals different growth rates in a heating cycle overtime breaking the bolt off or bolt being stretched when you put on wrench breaking the head off. Go lift the hood on nearly any l.s motor or others with 125k plus miles on them and you will find plenty of broken bolts on the exhaust manifolds. Very common. On cast iron to cast iron you are dealing with the issue of rusted stuck bolts. Fe ford series legendary for breaking the bolts off because of rust etc...
Burt Shaver
At this point I think about my biggest question is will spatter stick to the head? From why I’m reading I don’t think it will but would covering the mating surfaces with foil tape protect it from the spatter or would spatter burn through the foil tape? I could also cover the bulk of the head with some flat stock and then put some foil tape right around the bolt in welding on
Burt Shaver
Just going to run through what my plan/steps will/would be. Going to clean up the broken bolt first with some brake and parts cleaner, then with wire deemed but I have that I used to clean coil pack tower contacts with. 2. Going to cover the rest of the head with some flat stock and foil tape around the hole.3. Using a mig oak 140 but with the flux core wire, was going to use a fairly high heat setting and slow wire speed to fill the 1/8” gap on top of the stud 4. Clean the flux off while it’s still hot, set the washer in top and weld center of washer, clean up flux, set nut in and weld nut from center. Let it cool somewhat and then gently start trying to work it back and forth with a wrench. Spray some penetrant at this time if I want.
no704
That sounds like a good plan. The splatter should not stick to the Al but could melt into it a little. Even just a damp rag placed around the area should prevent that. Make sure that whatever cleaning fluid you are using is non chlorinated as that can be very dangerous.
PCustoms
VT
No clue why I can't quote your post, but Sorry forgot that pic was in OP...
no704
Before you try welding onto the broken stud. IF you can actually get a good CENTER punch on it give it a couple good hits with a punch and lots of lube and try a lh drill.
I personally really like WD-40 for aluminum.
Jswain
Calgary, AB
If you use brake clean wait awhile before welding. Degreaser followed by isopropyl alcohol prob healthier.
All good except don't use fairly high heat and slow wire speed. Wire speed = heat, without it you'll just melt back to the tip.
Set it for ~ the max so it punches into the stud, maybe once setting below max. If the washer is nice and thick I'd leave it set high for the whole process. When you weld the nut sometimes its difficult to start the weld down at the bottom of the inside of the nut, pretty much set the nozzle right into the nut. If you're melting away the washer/nut then turn it down one tap
Burt Shaver
I think I’m going to look for a slightly thicker washer than the one I had set aside
Burt Shaver
Set it for ~ the max so it punches into the stud, maybe once setting below max. If the washer is nice and thick I'd leave it set high for the whole process. When you weld the nut sometimes it’s difficult to start the weld down at the bottom of the inside of the nut, pretty much set the nozzle right into the nut. If you're melting away the washer/nut then turn it down one tap
It is non chlorinated brake and parts cleaner if that makes a difference
CraigStu
Blacksburg, Va
Do you have the capability of using gas vs flux? I am far from a good mig welder as I use tig but I have rented a flux mig a couple of times. My impression was that, in trying to do a series of individual tack welds, at each tack it took a second or two for the flux to melt and do it's thing. That made the first second or so of the weld pretty ugly. Maybe it was just me but after the last time renting that is when I decided to bite the bullet and buy the tig.
Indexmill
Central NC
There is only one absolute requirement to the drill/easy out approach; Do Not break a drill nor an extractor. Do not break the tool. The other important key is to drill the first hole on dead center of the bolt/stud. Following these rules, this method has to work...
knightfire83
Welding that far down in an aluminum hole, would almost certainly damage the material in the hole.
Heads are off, take it to a machine shop. Best $20 you'll ever spend.
Burt Shaver
Got it out😊. Using the Lincoln Mig Pak 140 on settings 1.5C to build up the stud. That part went perfectly, wasn’t able to to weld the buildup to the washer, my son in law said that’s because the washer I got was stainless steel? Is that correct? We were able to get it out by just continuing to build the stud up till it was about 1/4” above the surface and turned it out with vice grips. Did it damage the threads? Yea, I would say it did a bit, I looked at after with a magnifying glass and it looked like the top 2 threads that were showing may have gotten slightly damaged. I’m not concerned about the 2 damaged threads in this situation, after we were done we threaded in an old stud and it threaded smooth as butter. The new gaskets are going to be Remflex graphite gaskets that only require 20 ft pounds of torque and there’s still 14 or so good threads so I’m calling this a victory. If the stud were broken off deeper, I would try putting some copper tube down the hole before building the broken stud up. I would love to hear from the guys that know, what could have been done better, and if the stainless washer did in fact cause me issues? Thanks for all the responses
partsguy5768
Nice job! One only gets better with experience and you had no big issues with no experience. Its the way to go in many cases.
DGersic
DeKalb, IL
It’s possible to MIG weld stainless, but yeah, you should be using just regular steel washers and nuts. Remove as much of the Zink plating as you can before welding on them.
Jswain
Calgary, AB
If I never wanted to weld anything else ever again, I'd still keep a mig welder around for broken bolts.
Should have no problems welding to stainless washer, do you have a picture of it?
Burt Shaver
I will see if I have the washers I tried to use, I had tried to tack 2 together because they were relatively thin. If not I have many more of that size. I will post a pic or 2 tomorrow
Baumeister
MO
I would not use the weld method on a bolt broke that far down. if its close to flush with the top then yes as you can weld to both the new bolt and the broken stud.
I'd use drill bits and easy outs. Yes you need to drill straight but if you ruin the threads they have spring looking things to fix it. Forget the name but readily availble.
Start with the small one and give it a try. If it does not move drill bigger. Once you remove the center of the bolt you'd be amazed how many come out.
I bought a oxy torch specifically for heating studs on my f150 exhaust manifolds. I also got a few special tools that help grab onto the stud before it breaks.
Heli-Coil is the spring repair. I guess they're still around. Haven't used one for a long while. Drill bit size is not shown (part # bla bla) so you have to use their kits. Works well, though.
575cat
IMG_3140.jpegFor a little background, when I was taking the exhaust manifold off the right bank head of a 2016 Ram, 3 bolts broke, 2 were above deck height and this one is about 1/8” below deck height, so not deep at all. I’ve watched a few you tube video’s and originally was going to buy a good punch, some good drill bits and a set of easy outs but then I was warned that things could go wrong and I could damage the aluminum head, so then I got to watching videos about building up the stud with weld, then welding a washer to what I built up, and then weld a nut to the washer. I’ve never done this before and I’m really not much of a welder so I want to make sure I’m not going to destroy this head, if there is much chance at all that I will destroy it, then I will just pay someone to extract it, although as easily as the rest came out, I think it’s going to come out rather easily. I’ve already found a washer that has a center hole smaller than the diameter of the broken stud and a nut, but I’m unsure of a lot of things. Can I do this with flux core? Do I basically lay tack welds on top of each other, cleaning the tack weld in between? Or do I keep a hot puddle and just keep going till it’s slightly above the deck height? If I have a large puddle will it melt the aluminum threads? Or again am I just laying quick little tacks, trying not to let the puddle hit the threads? In one video I watched, it said that the weld would not stick to the aluminum but again just not sure of the finer details. I need some guidance, even if that guidance is don’t do it. I do plan on practising first with one of the broken studs in a vice, and see if I can build that up but…
nothing new there ive done many o many o times many deeper , I expect them to break or I just torch the manifold off and go after em , if someone has tried to drill they can have it its already boogered
Burt Shaver
When you fill them up with weld when they are deep, do you run a copper pipe down to protect the threads or just fill it up?
Shadowdog500
Down the shore
I’m glad you were able to get it out.
Here is a link to the first South main Auto video I ever saw 10 years ago with the same exact problem. He welded them just like you did. It was the same week that Eric the car guy tried to drill a broken stud out and wound up getting the drill sideways and drilled through the water jacket.
