how to use a thread file
bonneyman
Desert SW
I've got a couple. Rarely did they work on steel bolts, but I had alot of plastic fittings on drain pans that would have been a pain to replace (or a long wait time) that the tools got me through. I think they'd work good on brass and aluminum fittings, too.
OccupantRJ
Eastern North Carolina
Welcome.
That would be me.
On a square thread file the numbers on it are the various thread pitches available to use. Physically place one side of the file to the threads until they properly match. Once matched, push the file across the threads to correct damaged areas of thread. Push forward only, not a sawing back and forth action.
^ What @OccupantRJ and @WILD-BILL said.
Only two things I would add.
I often do much better using a thread gauge, rather than trial and error with various sides of a thread file, to get the right pitch. I find the thread gauge blades to be a cleaner more viewable fit than the teeth on the file.
I've had good results with thread chasers (dies, or restorers), too.
I like to start gently, trying to push first rather than cut, but take 2-3 passes to get it right. I do lots of work on old WW tools, and weird thread sizes are the norm.
Another good tool is a Japanese saw Feather File. Can be used to cleanup a single thread at a time, which can make the thread file work easier
cherrybomb
Near Madison Wi.
Pictures and where did you purchase?
john.k
Reforming the threads often makes a lot more sense than cutting steel away in expensive components ........not hitting threads with a hammer is the ultimate cure
