Picked this from Offerup today, came with the pedestal and light. $100. Runs perfect. All I did was very minor clean up. Dated May 4, 1966. Paper diagram was inside the bottom cover for dual voltage wiring. I was always curious why this specific model had a somewhat plain label, no crown top logo or anything.
And of course they used the wheel to grind aluminum...![]()
Yes Outlaw, quite a bit it seems. Dressing the wheels will be on my list.
Harley: I'll let the other members who can change bearings in their sleep chime in and tell you about replacing them so your grinding wheels will stop a bit quicker.
as far as pictures when I first joined I used an online service to host my pics, but shortly after they changed the methods and I didn't want to re invent their wheel so I just download my pics as small thumbnails that you can click on twice to make full size. click on this thumbnail for example.
if you are posting from your laptop or computer just click on the paper clip above where you write your words in your post and you'll get a pop up menu. then click the browse button and find the pics you want to post and you can post up to 7 pics per post. after you've picked out your pictures upload them, close that pop up and hit the save button on your post and the pics should be in your post.
if you have more questions you can send me a PM or I think there are help threads on GJ'S forum too.
good luck!!
These all look like block grinders to my eye. Is there a 'pre pre block grinder' thread? Maybe 'grinder that doesn't look like a block' thread?These all look like block grinders to my eye. Is there a 'pre pre block grinder' thread? Maybe 'grinder that doesn't look like a block' thread?
How do you date YOM on block grinders. I picked a freebee 1/4hp up today @ recycle ctr that has a crown top badge and a push on/off switch.
It does run but filthy and missing to outside wheel guards.
Harley - welcome to the Block grinder thread and Block grinder ownership.There is some numbers stenciled on the bottom tin cover, I'll have to take a closer look at them. When I had it test running it took forever for the wheels to finally stop. I was actually thinking the switch would turn it on but not off. Pulled the plug just in case.
I'll see what I can do about pix, I've never tried to upload any here and I don't have a hosting service.
You bought this with stand for $100 just like the picture shows ? The stand alone is worth that if not more. I got one exactly like yours. Will update pictures when completed.
I couldn’t find the answer I was looking for but are the arbor/shafts identical in block grinders? Like will a 3.5amp arbor be identical to a 6.2amp? If I’m describing it wrong it’s the shaft thing that sits inside the coiled wire part.
The arbors vary from model to model, and Torqueman has a chart for that.
I would not expect the ROTOR to be the same across different amperes, because the STATORs are longer/wider on higher-hp models than lower ones. I would expect the shaft to be longer as a result, so the ARBORs would also be wider-spaced.
Also, the shaft diameter, and therefore the arbors vary by model, with lower-hp models tending to 1/2” and higher-hp models tending to 5/8”.
