x2!
I like this idea. Now, what common household item is 0.010"?
Beer can?![]()
JZ - If you don't get to the root cause, after following the procedure in my PM, feel free to send the 3/4-HP Block to me.
I'll move it to the top of the Que and see what in the world is making it behave like it is.
I have some 3/4-HP Blocks that I can swap-out parts to see if a different field coil ***'y, and/or arbor, and/or housings, and/or relay, and/or, ....?
BTW - I'm thinking of posting that procedure here, if you're OK with that.
I'd like to get others input on it.
I just need to figure out how to format the indents, for readability.
Agreed on all points, Drives. You guys at GJ have got me hooked with the friendly, helpful atmosphere
While it was fresh in my mind I went ahead and tore my 3/4hp block back down and tried the improved shim method.
- With one clamshell off, loosen four armature bolts. This allows it to move relative to the clamshell it is mounted to.
- Stuff 0.010" shims on all four sides of the rotor between it and the armature.
- Tap the armature with a rubber hammer to equalize.
- Snug the four armature bolts down.
- Install the other clamshell half. Install 3 long bolts loosely.
- Tap housing with soft hammer to equalize.
- Snug the 3 long bolts down.
- Reach in with pliers and pull out the four shims.
Now the block has no start up noise AT ALL. Just the gentle, soothing hum of magnetostriction, no grinding / growling in the least.
JZ: These old blocks seem to be the best grinder in this catagory and price range and dont look too bad either.
Reach in where and pull out the shims?![]()
No, not your fault.Hey Dr Block,
Sorry if I wasn't clear -- the shimming process fixed the issue on my 3/4hp block.
Many thanks for the offer to have a look. I really appreciate that.
is on my part.
Let me know if you need the diagram on the inside of the bottom cover.I was putting my 397.19440 back together. I can not locate my diagram I made of the electrical. Was hopi g someone has a good picture. I tried searching this thread but my head is about to explode with all these blocks.
They grow on you, don't they?!Anybody care to advise me about buying this block for $15 ?
poor pictures of a grinder in poor condition but...
No light, no eye shields...
I have a half horse block on its original cast iron stand in much better condition for a user, so why am I even considering this piece of ....
seller says it runs
)Thanks, I moved it. You're right the other thread is a much better fit, I had no idea it even existed!Pd: not saying we all dont like your old craftsman grinder,but its not a block. Probably more like yours in the vintage grinder thread that most of us post our older grinders on.
Good luck with the restoration.
Nice looking family!Here's a couple of mine ...
Parts are available for mot of it, eye shield kit (non OEM), bearings, wheels, tool rests (may take a while, or make your own), power cord, cap if it has one. Just about the only thing not available (and it maybe, over on OWWM) would be the centrifugal start-up switch, but with careful dis-assembly, it will be fine.
It would make a nice wire wheeler for cleaning nuts, bolts, and the other endless bits 'n pieces that always seem to need a light touch.
$15 is a good price.
You can leave the 1/2-HP to heavier duty jobs.
Got a 1/2hp block torn down yesterday. Figured some folks would want to see the grisly details![]()
Here, just hold the puppy.Thanks Torqueman
Looking at the ones posted this morning that are much nicer for not much more money makes me want to pass up the $15 dollar one I asked about. I should focus on my vises that need my time.
But you are right about the blocks "growing on you". It certainly is not my personal responsibility to rescue this particular example. I can't read the label but it doesn't look at all like a one horsepower industrial duty model! I can't help myself...I'm gonna email the guy to see what the horsepower rating is
Update: Moral of the story is to never ask the guys on GJ if it is a good idea NOT to buy a tool.
It is mine now.
The Torqueman called it...they grow on you!
Pretty clean innards!
Did the bearings stay on the arbor/shaft, or in the housings?
What are your plans for it?
Looking forward to your posts, as always.![]()
The bearings stayed on the shaft but I was pleased that the new ones pushed into the housings with a big of force... I used some loctite anyway, however.
I used the shim rotor alignment method with great success again. I will make a separate thread detailing that method HERE
It got new Nachi bearings and its start relay contacts cleaned. Just need to make some eye shields for it and pack it away as a Christmas gift for someone![]()
FYI - I had the same problem with a 3/4-HP.If the bearings went in tight, and you installed the spring washers on the ends correctly, Loctite would not be necessary. Those springs do a great job. Great looking grinder---what's the Model Number? I think I have the same one, but can't read the label anymore
Doc: thats exactly how i ended up with my last dog. I sent my wife to go look at a puppy for some friends of ours and Taffy came home with her.
You are a great enabler especially since you help us for free unlike the Vet.
JZ: where's the dirt on that grinder? Thanks for the pick and good luck.
Shift: wear some warm clothes because you are headed to Wonderland and that rabbit hole is pretty deep.![]()
There are editable MS-Word files here, and in my signature line, 1st link.
http://www.garagejournal.com/forum/showpost.php?p=4000529&postcount=3
Now, a word about the files. Save an original. Then edit a copy, because MS-WORD really struggles with these files. I spent more time on the label than any other part of the restore. The 'fields' move around and distort when the text is edited.
If anyone has a friendlier file, that you don't need sophisticated editing skills and expensive sw, please let me know. I'll share it in my link. [emoji106]
Hey Pup,Torque: I'm in the process of reassembling the 1/3hp grinder I got from you early this year. I went back to the above link and only see labels for the 3/4 & 1/2 hp models. Does any one here have a decent scan/file of 1/3 hp models.
I may try myself to scan and edit a new one using inkjet water labels. Then transfer to a new piece of aluminum. I just ordered off ebay aluminum solid rivets.
I "see" said the blind man to the deaf man as he picked up his hammer and saw.
Got it. Thank you. 2nd photo looks promising.Hey Pup,
I have a 20MB Zip file with 6 files for 1/3-HP m-397.19580. If my mail server doesn't choke on it, you should see it soon. I hope one of the pictures can help.
Great idea. Have to pickup a bottle after work tomorrow. I was trying to salvage the copper right angle female connection, however that too was brittle at the crimp and snapped off.Try some liquid electrical tape on the hard to reach area before you put the heat shrink on. Better to over-do it than risk missing a spot.
