Let's show our wood (screwdrivers)
I picked this up at the flea a few days ago. Had to have it. Cleaned up well. It looks to me like the rings were jammed on as a fix to prevent it from further splitting. Square shank with a WRIGHT marking and what might be a part number ("L8 - V"), but I am not sure if that's the hand tool company or the aircraft company. It has a lot of character. Shown with my equally rustic-looking Nashua Paper Box Company screwdriver with the "Grover Handle", which has a similar repair.
misterbill
Wow, I'd say that one was "fully depreciated". I think Tin has this 1940 catalog https://www.garagejournal.com/forum/attachment.php?attachmentid=1076468&stc=1&d=1606855978 it might have some further info in it if you can get his attention.
For those who really get off on screwdrivers, and custom fitted screwdrivers, you may get a kick out of this book (droolworthy preview here)
No ties to it, other than I know of a few of the collectors whose work is shown.
Mintgrun
Kingston, Wa.
I wonder if the two-ring handle could have been made that way (as a replacement). I'm thinking they may have intentionally split it, in order to hollow out the halves for the square shank and then drove the rings on to hold it together.
No idea. Honestly, I was hoping for more answers and theories than questions! :) But you can see how deformed it is, right? How it's thicker in the middle between the rings? That the rings were each jammed on, one from one end, and the other from the other end, is unmistakable.
My uncle Tuffy was a hooper!
Tom, below are more photos. As you can see, it is split on two sides of the handle, or "in halves", sort of, at the end where the shank is installed. I am not convinced the somewhat jagged and uneven separation is planned, but I am open to all comments. Note, though, that it is not split all the way through the handle into halves on the other end. While that end is a mess with chips and other splits, the splits on either side of the handle in the middle do not continue past the ring near the end.
By the way, the wood is very hard. Despite the split and chips on the **** end, this thing is anything but fragile. I know it sounds almost counterintuitive to its looks, but it's very robust. My money is on it lasting 100 more years.
Mintgrun
Kingston, Wa.
Thank you for the additional photos. I'd zoomed in on the others, hoping for more clues, but I couldn't see the cracks continuing either. My next guess is that they drilled a round hole that was undersized and hammered the shank into the wood, which caused it to split and the rings kept it from coming apart. It's funny that they chose to make the handle oval shaped and not round. If not for the Wright marking, I'd have guessed that the whole tool was hand made. Guesses are all I have to offer. Thank you for humoring me.
Tom
Totally with you on that. I try to imagine the handle whole and freshly made, without the rings, without the split, and without the **** end all mangled, and even then its shape, no ferrule, etc, just doesn't seem like it matches the age or style of the shank! But I am eager to be proven wrong by a catalog.
And myself! My photo folder names for tools without a clear identification (brand, model, etc) on my laptop are often mnemonic, something instantaneous that will stick with me for future recall. This tool is in a folder called "Wright Colonial Screwdriver". It's not THAT old, obviously, but it looks it! :)
Farmer J.
UK, Cornwall/Hertfordshire.
How would they have put the rings on so tight? Just curious about the procedure.
Hang some metal rings with a snug fit on the small branch of a tree in springtime, they will soon be a perfect tight fit. Later in the season trim the branch off, remove the bark, drill a hole in the end and drive or press the shank in. :D
I picked up this Matchless screwdriver at an estate sale on Monday. It was a little difficult to remove the red paint. I didn’t find a part number, unlike my other Matchless screwdrivers. I may do a little more work on the tip but for now I’m letting it be.
-DonA2B24184-6514-4B5A-A6CD-499484759D59.jpegE0648F9E-A858-4D47-97D1-B58CAE8C1583.jpeg23FED077-12BC-4AB3-856D-30499C704D74.jpeg6CAF9C8A-AC41-416D-82DB-DBA160186764.jpegE35BC9B6-A204-4BD5-92C3-8F85533847A0.jpegB763B76F-A6D5-4A4B-9C29-43FACF0DF38F.jpeg
Ole Slewfoot
Freedom, CA
As usual I forgot to get a true before picture.
So here's one I found in a crusty old box my buddy dropped off in our shop after I degreased and wire wheeled it (including the wood). It was broken off, reground, and also severely bent, and clearly spent long periods immersed in puddles.
Took a few different pulls to get about straight, but it wasn't 12 tons of bent.
Sanded to 400, and wire wheeled the metal a bit more. Gotta stop and let the water from degreasing dry before I slop some finish on.
LesserSon
PA USA
I was poking through an antiques spot yesterday, and probably would have purchased these if they had been priced. I’ll check on them another time. Last August, Lugz presented a gray&red handled driver here with no logo. Here’s one with. 1AC31C7A-3B1E-48FC-B7B1-6C8395DDF16C.jpeg
This lightly used handle stamped 9-1/2“ Tobrin perfect handle screwdriver arrived in the mail today. These match the specifications for a GMTK correct 41-S-1385 Extra Heavy Duty Screwdriver 5" Blade.D5C13995-98E0-45D4-8120-A3B90D0EC72A.jpegE2EF2756-C910-4C7C-ADE5-EADDE5EA592B.jpeg49787B27-725F-46FE-962A-D9E69AF20EFF.jpeg
AntiqueBen
Found this old 10 1/2" Stanley turn screw today. The stamp says Patented June 6, 71. When I looked up this patent on DATAMP (patent 115,582), it appears to be Stanley's first screwdriver patent in 1871. My question is, I don't see this particular Stanley logo on the Stanley logo list? Is there any Stanley buffs out there that knows anything about this logo?
I added the new Tobrin driver to the keeper box and took a couple pictures of the perfect handle screwdrivers. From top to bottom are two HD Smith originals, a Lenox, five Tobrins, two prewar and two postwar Irwins. I’m not sure who manufactured the bottom driver 5566F39E-BA60-42AE-BE2A-19F151F7ACE8.jpeg
I’m not sure who made this Perfect Handle screwdriver with the 2“ blade but my best guess is Tobrin based on the triangle size marking.
-DonE33673B7-AEA9-4DDD-B39C-B4F05D86E400.jpeg98FD63C0-A6A1-43DB-B1FA-C80E9EF600C0.jpeg
AntiqueBen
I picked up this Stanley #25 screwdriver. I've never seen one this long, it's 16 1/2" long. I'm thinking about just leaving the patina instead of making it all shiny. I don't quite understand what DATAMP means about the patent 1,839,835. It says only a few #25's had this patent? Would the #25 been manufactured before the Philips came out?
LesserSon
PA USA
No. DATAMP says models 25, 45, and 55 are only a few of the many screwdrivers Stanley made under this patent.
This patent was granted about four years before the patent for Phillips, but I don’t see the relevance, because this patent covers the way the shank is held in the handle, not how the tip fits a screw.
Speaking of large screwdrivers, I found this two fister at a Berkeley moving sale this morning. Here it is after some cleanup. I had to straighten the blade as well. 2EE4E3FC-F692-43BD-B3B6-1BEBA9DD98F7.jpeg6CB33C33-C93F-4BD1-9070-C65CD5594969.jpegI couldn’t find any indication of who manufactured it.
Leviton
Oregon
I bought this because I had never seen a wood-handled screwdriver marked "Tiger" before. The ugly ferrule polished up to a nice brass color with a little bit of elbow grease.
I wasn't having much luck identifying the maker until I came across an almost identical screwdriver on e-bay. The difference was that the e-bay screwdriver also said "Made In Japan".
Nice looking screwdriver and I was surprised it was not U.S. made.
