shaggyant - How big is the hole that you're trying to cover in your sheetrock? Diva Light and Greentek are both made by James Industries. Exceeding 16400 Lumens at 16ft mounting height is not ideal unless you put them on dimmers. You'll far exceed the recommended 93fc @ workplane (depending on qty and layout - naturally).
Hello again,
Does anyone have any recommendation on these 2 flat panel LEDs?
I don't know if I need the 7500 lumens over the 6500 one. I'm going to have 10 of them in my garage.
6500 Lumen flat panel
vs
7500 lumen flat panel
Wish I could help more I ordered the 9000 Lumen @ 4000K and really like them. I noticed they are now back ordered.
I installed 11 in my 32x30 garage with 10 foot ceiling.
Those highbay lights will be very bright in metaj's 8' ceiling garage. Maybe it is what you need for car detailing?
8 feet!!! OMG NO! Must have a diffuser at that height. Plus 20,000 Lm is seriously wrong at 8ft mounting height. I assumed a 15'-20' install height.Those highbay lights will be very bright in metaj's 8' ceiling garage. Maybe it is what you need for car detailing?
Terrible lighting for detailing. You will see each individual LED point light source reflecting back at you. Real eye damage is possible here.
metaj - you might get a kick out of this thread (link)
Best value is the 4ft strip lights in post 1 of the best light fixture sticky. They are only 3" tall with bulbs. Install continuous rows end to end to increase fc at workplane and reduce shadows.metaj said:My garage is actually 25x24 with an 8 foot ceiling. I do detail cars, but I'd like a little extra light. I only want ceiling lights, no wall lights. I know I want LED for sure, and I'd like a a slimmer light. My ceiling is 8 foot and I don't want bulky lights because I'll lose head room.
1. is the layout for lights ok
2. what recommendation for fixture and bulb can you give
3. flat white is what i need to use? (will do some more digging myself since i feel so needy already)
The Lithonia sb232 is a fluorescent fixture. Standard 2-lamp 4ft LED strip light works well. Like this:I have started reading this thread and I have a relatively small garage and was wondering if the lithonia sb232 was still recommended for a garage with 8’ ceilings? I’m thinking of mounting 8 total, 4 above each bay. Garage size is 19’x21’x8’. Standard two car garage.
Any details on that fan? looks close to what I'm looking for if it goes nice and slow.Looking for lighting layout help on my shop @Platonic Solid. Thank you in advance for the help!
Shed is 28 x 48 with a 15.5 ft ceiling with a mezz per the attached PDF dimensions. Floor to bottom of Mezz is about 7.5 ft.
Will be mostly used for mild fabrication, tig welding, detailing, and some auto restoration/ customizing. Would like to have in the 80 - 100fc range for lighting. (Existing lighting will be on a motion detector so only used for quick in and out's of the shop.
Would like to run either of the 2 lights copied below for most of the space and looking for recommendations for under mezz lighting for workbench/ fabrication area.
Please advise on what layout/ recommendations would be ideal.
https://greenlightdepot.com/collect...0w-with-lens-and-w-o-lens?variant=36041819012
https://greenlightdepot.com/collect...5w-with-lens-and-w-o-lens?variant=40725028676
