Thanks guys!
So last week I had a speed run to SC and had a chance to stop by and check on cousin JB at his upholstery shop. One of the side projects he was working on is a lowered Radio Flyer wagon for his nephew..
He has limited metalwork equipment in his shop and I noticed the rear tire mounts had a small amount of flex under load. I have a bit more equipment for such tasks, so offered to make him a set that was a bit more stout. I happened to have a piece of 3/16 stainless that would serve the purpose. Two pieces were cut out, clamped together, and filed/sanded to be identical parts. The press brake was used to add the bends.. This shows the difference in thickness....
Then 1/2" holes were drilled to accommodate the 1018 steel rod for the axle shafts.. The rod was pushed about 2/3 in, tacked, and checked for perpendicular. Then TIG fusion welded and fillet welded using 312 rod.
Drill the mounting holes and these will be ready to ship back to SC.
I have been out of the Golden Elixer/liquid crack known as Throwback Mountain Dew for quite a while now as our local Pepsi distributor stopped carrying it. As I left JB's shop I saw a Piggly Wiggly food store and thought that the perfect place to stop and check inventory. As luck would have it, SC folks have a much better palate for cool liquid refreshment and still have it on the shelf. I bought all they had..
Now being the resourceful type, I did a location search for all the Piggly Wiggly's heading north. I stopped at a qty of 20, figure that will hold me until the next trip to JB's..
And with the shop inventory restored, all is right with the world..
