Boostingaz
Looking great - so much room for activities!! Just don't succumb to the old adage that **** expands to fill the space available!!!
That's impossible not to do haha. We are like fish, can't help it.
It took them till almost 8:00 last night, but they got it done!
Doors look great and the LiftMaster openers are so smooth and quiet! So happy and relieved to have the shop finally dried in and my wife and I can start on the inside build.
How the inside looks now….
Contractor is having the inner building materials delivered sometime next week after Memorial Day. Over the weekend I’m going to get these installed…
My superhuman wife and I hand loaded 36 of these Versa-Lock cap blocks at the local block plant. We’re going to place them at all the man doors as landings to pass code temporarily until we can afford to do our apron pour. Those blocks weigh about 70 lbs each. I was wore out, good thing she’s tougher than I am!
Thanks Mike! Your shop build was the first one I saw that had a 50’ depth instead of the usual 30’-40’ depth. My existing shop is 40’ deep, and that depth is such a waste of space. Too deep for one vehicle and not deep enough for two. Very frustrating when I realized I would have been better off with a narrower but deeper shop than what I had. Very important detail if you are actually wanting to work in a shop instead of just using it for parking cars!
When I replaced the head gasket I had to clean out all the stop leak some master mechanic used trying to “repair” the engine.I’m got that same one at the shop. I can fully attest to the fact you can abuse the **** out of it and it just takes it.
I would offer one piece of advice. While it’s at the shop have them drop a radiator in it. Mines rotten out and needs to be replaced. Problem I got is I need a forklift to lift the counter weight off it to replace it![]()
I have that same starting issue when the bottle gets too hot. So I have one major rule at the shop, never park it outside in the summer. Plus it helps I keep my spare tank in the shop.When I replaced the head gasket I had to clean out all the stop leak some master mechanic used trying to “repair” the engine.
Took the radiator to an old customer who does radiator repair. He boiled out the core, steam cleaned the outside, and then pressure tested it. He gave it a clean bill of health. Engine runs nice and cool with no leaks! Only issue that I have with how the lift runs is that after it runs for over 10 minutes or more it doesn’t like to restart. I think it’s a propane fuel issue, like maybe the vaporizer is needing adjustment. One of the reasons I took it to a professional!
Looks great Sterling.
I too went a bit overkill on lighting in my shop. I have just over 100 ft/candles to the workbench surfaces. The contractor told me it was like an operating room, I took that as a compliment. Even though I had pretty good lighting (fluorescent) in my last shop, I wanted extremely good lighting in this shop as I don't like using drop lights for every job.
I think you will be pleased.
Gary, when we got together a couple months back and I said you looked like you could use a little sun…
and how come we haven’t seen any update out of you for a while?As to updates, I'm notoriously bad about taking pictures until the project is over and then I think about it. As many on here have said, without pics, the thread is worthless!! I'm working on being better on before/after pictures (note to self!!!).Gary, when we got together a couple months back and I said you looked like you could use a little sun…
I was just joking
Btwand how come we haven’t seen any update out of you for a while?
That *****! Didn’t you go with that super whammy stuff that supposed to be rated for hail?As to updates, I'm notoriously bad about taking pictures until the project is over and then I think about it. As many on here have said, without pics, the thread is worthless!! I'm working on being better on before/after pictures (note to self!!!).
Beyond that, we have done a little traveling (week in Cancun with Sis) and dealing with big projects at both the house and lake place. We had a hail storm in April that totaled our 8-month old roof, so we get to go through that process all over again.
I'll get back to posting on my thread soon.
Yes, we did - it's a IKO grade 3 impact resistant shingle. However, with a big enough hail ball thrown from far enough up in the sky, nothing will stop everything.That *****! Didn’t you go with that super whammy stuff that supposed to be rated for hail?
