So I came across a green '70's era, Craftsman 328-12001 jack today for $15. And I picked it up for him. I've broken it down into the major components--I removed the handle, removed the wheels and the return spring, and finally pulled the pump out. But the problem this jack has is that before I disassembled it, the handle could not be rotated CW or CCW. And the problem was not in the handle, but in the valve body/pump. Any ideas what the problem is before I try to pull it apart?
This is not the correct order of these parts, but you can see what came out of it.
I just went out and removed the "star" thingy by unscrewing it from the valve body. It has a needle valve and not a ball. But is it supposed to move downward and upward as the star is turned? The star rotates but the needle valve doesn't move up or down. I don't understand how the needle is supposed to seat if it doesn't move up and down.
Thank you Hiball,
I also have a Michelin-735 I plan on opening up and replacing the u-cup and piston rings. I will be giving you a call once I have the measurements. I won't start that project until after the holidays, but I will post some pictures.
Ok, I figured it out. The previous owner had simply jammed torqued the handle so tightly the needle was stuck. I freed it up and now the needle does move up and down when the star is turned. THIS IS A GREAT PLACE!!
Sure wish this kind of info was still out there in the thread for Snap-On jacks......
I was referring to this thread.
http://www.garagejournal.com/forum/showthread.php?t=40489
Just wishing that specific model info was still in circulation is all.
Hiball, do you think I can break that big nut on the end of the cylinder loose with my Milwaukee 1/2" impact wrench? Supposedly the wrench will torque to 300 ft. lbs. I've got a 55mm impact socket that will fit the nut.
I believe 300ft lbs should handle the tank nut, but Leary of impact torque numbers.Update:12 hours later it held. Didn't move a millimeter! Thanks Again to all.Hi FIVE to Hiball for your help. Got the new piston seal u-cup and cleaned everything real good. Assembled the jack, went through bleed procedures. Appears to work great. Put a real load on it today and will see if it holds or leaks. But so far so good! Thanks Again!!![]()
UPDATE: Well I finally tracked down, ordered and received the seal kit directly from Shinn Fu (took a while to get it shipped).
Do you have that seal kit part number/cost? My 90145 jack is exhibiting the exact same behavior.
First post hello all, Thanks to Hiball I was able to rebuild my jack last night. I didn't take any pictures during the process but it cost me 80 cents for the rubber parts. I went to a local hydraulic shop in Forest Park,Ga near my house. I brought my seals and we matched them up. The process was pretty painless and it works great now (it was leaking). I have had the jack for about 10-15 years. The one I rebuilt was the blue one in the first picture. The red one I picked up on craigslist today for $25 its going to get the same treatment. The main problem with that one is the casters are missing all the ball bearings? I didn't read all 43 pages of this thread so I hope this question hasn't been answered already. Has anyone replaced these before and how do you decide what size to use and a source? or does anyone have a set they want to get rid of? Thanks again in advance
Just for Clarification, I'm referencing the bearing size, Assuming you where wanting to rebuild the current set if the races where in good enough shape.
Hiball, I pulled the main ram out of the cylinder and the seal at the end was completely broken apart and degraded. Is this the way the new seal goes back on?
