Bandito1984
- Joined
- Apr 7, 2013
- Messages
- 3
hello folks! first timer on this board.
my jack is an Allied (Silmar, CA) 2 1/4 Ton, made in china. purchased new about 20 years ago.
well, i did what most have probably done fooling around with their jack. i had a great idea to service this jack, which never gave me any problems until now.
my plan was to replace the hydro oil. i only opened up the far left and center ports, not the far right port, as pictured. then i turned over the jack to drain the oil out but did not notice the check valve steel balls that dropped onto the grass. i then reassembled the jack best i could, not knowing at that time of course the check valve steel balls were missing. added oil and the jack would not function properly. oh, after all that i found the proper oil drain/fill hole on the master cylinder.
i researched this site and others trying to find out what i had done wrong. i recovered the check valve steel balls and installed them in the order as pictured below but the jack still does not function properly:
1. still not sure if i added enough oil or even added it correctly. i've come across different procedures on the web.
2. after closing the valve the jack will not pump up/raise normally. only raises about 1 inch. during troubleshooting it was also doing a see-saw action.
3. with the valve closed i can raise the jack by manually lifting the scissors mechanism that the car rests on. it does hold pressure and will not lower when standing on it. the jack will lower when the valve is opened. this part of the jack appears to be functioning properly.
4. not sure if i have the spring and check valve steel balls in the correct order. there is also one steel ball (same size as the small one pictured) in the center port valve under the spider wheel gear.
anyway...hELp!
thank you!
anyway...hELp!
thank you!
LOL
