I hate it when roofers stagger step shingle install vs row at a time.Roof is done, the door and one window are in.
Hired the same guy to roof this as did my other shed. $500 labor, felt plenty fair to me.
Three guys knocked it out in about 2.5hrs
All the shingles were from the same lot, but there is still a difference in some that you can see in the first Pic. I'm sure it will fade, but it will bug the **** of of me in the meantime
I have the framing for the octagonal window ready to go in, just need to settle on placement and find an hour or so to finish it.![]()
Yeah, I hear you. It will fade with time and is really only visible when I look over while driving by.I hate it when roofers stagger step shingle install vs row at a time.
Stagger step is easier for them (less movement) but it concentrates the shingle batch and this problem seems to be much more prevalent now a days. Thus you get the blemish you have. Row install they are blended way better but more movement labor but you don't get the blemish.
We have torn off a few roofs at the roofers expense over the past couple of years that did not blend. You would think they would forbid the stagger step method....
When I started 25+ years ago, the stagger step method was not a technique and this problem never existed.
Mike - In our climate we just install the drywall ceiling, then we blow to R43 with cellulose. We caulk seal any ceiling penetrations. We don't do poly.Trying to decide what to do for the interior ceiling.
I think I want to insulate, in an attempt to control temps during the summer. I'll keep a dehumidifier out there, but am not planning to air condition.
I'm thinking blown in cellulose (diy). If the specs are right, 10 bales should get me around R38 and would cost $200, plus the machine rental.
Should I install a layer of 6 mil poly, before my ceiling covering? I'm thinking that will either be drywall or T&G pine. I'll install baffles before closing up the ceiling.
Walls will stay open for now. I'm going to caulk any gaps and the plan to pain the interior with a semi gloss off white to brighten it up and make it easier to keep clean.
Any advice or thoughts?
Thanks Larry. There's 16' of GAF ridge vent, so we are good there. I am thinking of using these vents with bafflesMike - In our climate we just install the drywall ceiling, then we blow to R43 with cellulose. We caulk seal any ceiling penetrations. We don't do poly.
T&G pine you will have small gaps along the T&G. Not sure how to stop air movement thru this....
We also use glue along the top double top plate before applying drywall to the walls. This acts like a gasket preventing drafts in the stud bays from going upwards to the attic.
Make sure your insulation baffles extend fully into the ventilated soffit and your ridge vent is proper.
Perhaps forgo the T&G pine and install batten strips on the ceiling to create a nice accent. Or perhaps use a bead board but you will need to contend with the seams.
I'd love to not have to strap this ceiling. 24OC won't work?I like my t&g. Install and done. But did require 16" o.c.
Not a big fan of beaded trim, but an edge and center V groove could work. Problem is finding it at a price I'm willing to pay for a shed.Edge and center pine, with a whitewashed finish
Very nice little shed and progress. I remember when I built my shop. The Smartasses (complimentary) folks on here came to my help in droves. This is a great place and community of talents. I praise the help that is given here.
Looks great, Bill. Do you think it really wouldn't work on 24 centers?The company I bought it from (Johnson Pine) and others selling same were very clear. I had trusses 24" o.c. and added joists in-between. off strong backs. 10 mil poly and 20" of cellulose. This was very close to 5/8" thick, like most finished t&g today.
Looks great Mike!Got back at it today after a bit of a break. I was hoping to have it done by now, but c'est la vie.
Decided to save some time and money and use smartside t1-11 instead of lap. It's about a grand cheaper and goes up a lot faster. I don't love the look, but it will be fine.
Sides and back done today, front will be tomorrow. Then paint, then trim, which I will prepaint
Thanks.Looks very nice, I have the same shingles on my garage. I assume you will put gutters up, put screens in them because with all those trees they will fill up with **** every spring and fall.
Yes on both.Mike - what is the plan for covering the ZIP at the bottom? Tuck under a piece of Z-flash and add a trim board?
Are you gonna parge the block and then paint it?
I hear you on not wanting to work on a project!Thanks. Pool got opened 3/30 and the kids swam that weekend. I've had it at 80 degrees for a while now, so I want to use the pool and not work on a project
Might pick up some of the trim this weekend. Windows/doors, corner boards and fascia would make a big difference
