Hi all,
I recently picked up a Quickjack 5000 from a local, plan to use it with my track/autox Miata. I've used it a couple times now to test it and it works great. To make it even more useful and fast I'd love to be able to keep it on the floor and just drive over and leave it under the car when parked. Issue is the car is pretty low and even at the 3" height, the Quickjack will make contact to the frame rails or chassis brace. Sliding it under the pinch welds from the outside is no problem.
So my first though was running 2 rows of garage flooring, ie Racedeck, so I can gain a little height then pull the Quickjacks onto the Racedeck between the tires. Racedeck looks only to be about .5" tall so not sure if it will be enough but I don't need much height. I've seen other tiles are taller.
Any suggestions for raising the car a bit to be able to drive over the Quickjack?
