Boosted1
Looking good Justin. I like the sleeves and boxed frame.
Yes, doing the boxing in stages and will terminate with a tapered end. Where exactly not sure. Currently back to the body mounts. Might go one more section then cab would need to come off.Is there a plan for a similarly tapered plate at the rear? The boxed to not boxed transition needs to be gentle or you risk cracks where the torsional stiffness changes dramatically.
Thanks. Enjoying this phase of the build.Looking good Justin. I like the sleeves and boxed frame.
Thanks. That's the idea, solid and rigid. Kinda the opposite of most CV IFS installs. Not that quick and easy is bad, just not my style.Coming along nicely. That's going to be stout.
Thanks Mike!Looking good Justin.
Thanks.Nice work and those welds.....
Thank you. I've had some time to think about it. It's not the first one so I already know how to screw it up. The frame being bent doesn't help. Welding itself warps things. Have to just take it one step at a time, adapt as needed.you are making it look easy and we know it is definitely not.
I can't work in chaos. The bed of the truck is chaos, filled with all the parts and pieces. But that is not the workspace.Am I the only one who is blown away by how clean Justin's workspace is?
Beautiful! and the clean shop. OMGThanks.
'those welds', is that a good thing or ?
