rattle_snake
Back to work on the TC adapter. Needs machining down the body to clear shift rail. Found a 1.25 boring bar which seemed about right.
one pass, slow.
still not a lot of room for linkage hardware.
Instead of 2nd pass I milled a flat in shifter arm and welded a captive nut at reduced height.
The mods needed to the TC side.
-shifter rail
-idler nut
-bearing retainer and bolts.
-shifter linkage clearance in rear/low
There are 2 clocking options, down (can't use) or up. Up puts front output flange up 1". Clearance to crossmember was very tight, 1/4" after some grinding to get TC down from hitting cab. So this is good and can drop trans/TC mount down and have more room in both places. Although I'm sure this will lead to more modifications.
one pass, slow.
-shifter rail
-idler nut
